dojo 1.5 et console
dojo 1.5 et console - HTML/CSS - Programmation
Marsh Posté le 15-08-2010 à 14:56:02
J'essai de faire le tuto démmarage rapide de dojo avec la version 1.5. J'ai fait :
  1. <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
  2. <html>
  3. <head>
  4.  <title>Dojo Toolkit Test Page</title>
  5.  <!– load the dojo toolkit base –>
  6.  <script type="text/javascript">
  7.  var djConfig = {
  8.     isDebug:true,
  9.     parseOnLoad:true
  10.  };
  11.  </script>
  12.  <script type="text/javascript" src="../js/dojo-release-1.5.0/dojo/dojo.js"></script>
  13.  <script type="text/javascript">
  14.  dojo.ready(function(){
  15.    dojo.query("#testHeading" )
  16.    .style("cursor","pointer" )
  17.    .connect("onclick",function(){
  18.     this.innerHTML = "J'ai été cliqué";
  19.    });
  20.  });
  21.  var disableLinks = function(){
  22.    dojo.query("a" ).connect("onclick",function(e){
  23.      e.preventDefault();//arrêter l'événement
  24.      console.log('clicked: ',e.target);//le noeud sur lequel nous avons cliqué
  25.    });
  26.  };
  27.  dojo.ready(disableLinks);
  28.  var mineObj = {
  29.   aMethod: function(){
  30.    console.log('running A');
  31.   },
  32.   bMethod: function(){
  33.    console.log('running B');
  34.   }
  35.  };
  36.  var otherObj = {
  37.   cMethod: function(){
  38.    console.log('running C');
  39.   }
  40.  };
  41.  dojo.ready(function(){
  42.   // run bMethod() whenever aMethod() gets run
  43.   dojo.connect(mineObj,"aMethod",mineObj,"bMethod" );
  44.   // run an entirely different object’s method via a separate connection
  45.   dojo.connect(mineObj,"bMethod",otherObj,"cMethod" );
  46.   // start chain of events
  47.   mineObj.aMethod();
  48.  });
  49.  </script>
  50.  <style type="text/css">
  51.  /* our CSS can go here */
  52.  </style>
  53. </head>
  54. <body><!– this is a Typical WebPage starting point … –>
  55.  <h1 id="testHeading">Dojo Skeleton Page</h1>
  56.  <a class="link" href="http://www.google.fr/">First link</a>
  57.  <a class="link" href="#">Second Link</a>
  58.  <div id="contentNode">
  59.   <p>Some Content To Replace</p>
  60.  </div>
  61. </body>
  62. </html>
Cependant je n'ai pas la console, j'ai essayer avec la version 1.3.2 et là j'ai la console.
Y a t'il une manipultation particulière pour la version 1.5?
Merci.
Merci pour vos conseils.
Marsh Posté le 25-08-2010 à 11:11:22
Tu as trouvé une réponse à ta question ?
Message édité par naeco le 25-08-2010 à 11:11:44
Marsh Posté le 25-08-2010 à 11:21:55
non rien trouvé, quelqu'un à la solution?
