Problème de validation XHTML 1.1 - HTML/CSS - Programmation
MarshPosté le 24-04-2005 à 09:38:47
Pour un exercice, j'ai essayé de passer un document valide en HTML 4.01 strict en XHTML 1.1 A première vue tout me semble correcte, mais le validateur du W3C ne l'entend pas de cette oreille :
1. Line 237, column 7: end tag for "script" omitted, but OMITTAG NO was specified </html> You may have neglected to close a tag, or perhaps you meant to "self-close" a tag; that is, ending it with "/>" instead of ">".
2. Line 31, column 0: start tag was here <script type="text/javascript">
3. Line 237, column 7: end tag for "head" omitted, but OMITTAG NO was specified </html>
4. Line 8, column 0: start tag was here <head>
5. Line 237, column 7: "html" not finished but document ended </html>
6. Line 237, column 7: end tag for "html" omitted, but OMITTAG NO was specified </html>
7. Line 5, column 0: start tag was here <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="fr">
8. Line 237, column 7: missing marked section end </html>
9. Line 32, column 9: marked section started here <!--/*--><![CDATA[//><!--
Et la page en question :
<!-- Insertion du fichier contenant l'entête de la page
Ne pas oublier de remplir les champs titre et description-->
<!--déclaration du format d'encodage de la page (XHTML 1.1) et de la langue (français)-->
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
ton balisage de commentaire est mal foutu, ça pourrit tout le reste
--------------- I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing?
Marsh Posté le 24-04-2005 à 09:38:47
</html>
</html>
<head>
</html>
</html>
</html>
Message édité par bepimaco le 24-04-2005 à 14:00:42
Bepimaco
