Script PopUp en Script Pop-Under
Script PopUp en Script Pop-Under - HTML/CSS - Programmation
Marsh Posté le 26-05-2006 à 18:58:52
Bonjour voici un script qui permet d'afficher 1 fois par jour une pop-up :
  1. <SCRIPT LANGUAGE="JavaScript">
  2. var nbJour = 1;
  3. var urlPopunder = "gagner_argent.php";
  4. var windowProp = "width=800,height=600,location=yes,toolbar=yeso,menubar=yes,scrollbars=yes,resizable=yes";
  5. function GetCookie (name) {
  6. var arg = name + "=";
  7. var alen = arg.length;
  8. var clen = document.cookie.length;
  9. var i = 0;
  10. while (i < clen) {
  11.  var j = i + alen;
  12.  if (document.cookie.substring(i, j) == arg)
  13.   return getCookieVal (j);
  14.  i = document.cookie.indexOf(" ", i) + 1;
  15.  if (i == 0) break
  16. }
  17.
  18. return null;
  19. }
  20. function SetCookie (name, value) {
  21. var argv = SetCookie.arguments;
  22. var argc = SetCookie.arguments.length;
  23. var expires = (argc > 2) ? argv[2] : null;
  24. var path = (argc > 3) ? argv[3] : null;
  25. var domain = (argc > 4) ? argv[4] : null;
  26. var secure = (argc > 5) ? argv[5] : false
  27. document.cookie = name + "=" + escape (value) +
  28. ((expires == null) ? "" : ("; expires=" + expires.toGMTString())) +
  29. ((path == null) ? "" : ("; path=" + path)) +
  30. ((domain == null) ? "" : ("; domain=" + domain)) +
  31. ((secure == true) ? "; secure" : "" );
  32. }
  33. function DeleteCookie (name) {
  34. var exp = new Date();
  35. exp.setTime (exp.getTime() - 1);
  36. var cval = GetCookie (name);
  37. document.cookie = name + "=" + cval + "; expires=" + exp.toGMTString();
  38. }
  39. var exp = new Date();
  40. exp.setTime(exp.getTime() + (nbJour*24*60*60*1000));
  41. function getCookieVal(offset) {
  42. var endstr = document.cookie.indexOf (";", offset);
  43. if (endstr == -1)
  44. endstr = document.cookie.length;
  45. return unescape(document.cookie.substring(offset, endstr));
  46. }
  47. function verifNbOuverture() {
  48. var cpt = GetCookie('cpt');
  49. if (cpt == null) {
  50.  cpt=1;
  51.  SetCookie('cpt', cpt, exp);
  52.  window.open(urlPopunder, "", windowProp);
  53. }
  54. else {
  55.  cpt++;
  56.  SetCookie('cpt', cpt, exp);
  57.  }
  58. }
  59. verifNbOuverture();
  60. </script>
Je voudrais que a la place de la pop-up , ca soit une pop-under.
Je pense que c'est possible et pas difficile :)
Cordialement
Rhyno
Marsh Posté le 26-05-2006 à 19:58:04
Squoi une pop-under ? :heink:
Marsh Posté le 26-05-2006 à 20:19:08
C'est comme une pop-up , mais elle se met directement en background. Et tu ne la vera que quand tu quittera le site. En gros c'est ca .
Personne pour me faire vite fait la mod ?
Marsh Posté le 26-05-2006 à 21:53:32
Et pour moi une bonne crêpe avec du nutella...
Un verre de lait, et une jolie demoiselle...
_ Ce sera tout ?
_ Oui ce sera tout :D
Marsh Posté le 27-05-2006 à 00:35:02
Non non tu as oublié quelque chose dans ta liste.
Un peu moins de connerie .
Le travail que je demande n'est pas gigantesque , de plus pour la personne qui me le fera j'aurais d'autre travaux a lui demander , rémunerés cette fois ci !
Bon xtof_83 j'espere à jamais ;)
Rhyno
Marsh Posté le 27-05-2006 à 02:01:10
Quel est l'interêt d'une pop-under, le but d'une popup c'est quand je clique sur quelque chose d'un site, de voir une information dans une petite fenêtre à part. Si elle est cachée et que je ne la vois que quand je quitte le site ca ne sert plus à rien. :??:
Me: Django Localization, Yogo Puzzle, Chrome Grapher, C++ Signals, Brainf*ck.
Marsh Posté le 27-05-2006 à 04:01:57
Sisi, la pub ça fait toujours chier, Donc, ca sert à qq chose... :sweat:
Nan sérieusement, si c'est "facile, pas gigantesque" pourquoi tu le fais pas par toi même ? Si t'as déjà écris ça, t'es pas bien loin...
Marsh Posté le 27-05-2006 à 09:10:22
J'avais du mal à imaginer qu'un publicitaire, qui donc profiterais de cette petite aide pour se faire de l'argent en emmerdant le monde oserait venir faire coder ses scripts sur un forum ... http://forum-images.hardware.fr/icones/message/icon12.gif
Message édité par 0x90 le 27-05-2006 à 09:10:37
Marsh Posté le 27-05-2006 à 10:44:10
+1
Alors merci d'arrêter de spammer...
Si tu veux un truc tout fait, paye une agence de pub... :D
