Problème lors de la génération de la javadoc
Problème lors de la génération de la javadoc - Java - Programmation
Marsh Posté le 10-04-2013 à 03:00:09
Salut tout le monde,
j'ai un petit soucis quand j'essaye de générer la javadoc de mon projet... Voici les erreurs que netbeans retourne :
Warning: Leaving out empty argument '-windowtitle'
Generating Javadoc
Javadoc execution
Loading source file E:\JavaWorkspace\java-v2\src\java\Business\Manager.java...
warning: [options] bootstrap class path not set in conjunction with -source 1.6
Loading source file E:\JavaWorkspace\java-v2\src\java\Controller\Controller.java...
error: unsupported encoding: ${source.encoding}
Loading source file E:\JavaWorkspace\java-v2\src\java\Data\ConnexionSingleton.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Data\DbAccess.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Exception\DataException.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Attribution.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Budget.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Demande.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\GroupeUnite.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Personne.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Section.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Statut.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Transaction.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Unite.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddBudgetFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddDemandFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddTransactionFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllAttributionsModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllDemandsModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllDepQuotModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllTradeModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\CenterRenderer.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\ComptaRenderer.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\EtatCellEditor.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\GestionFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\InfoSectionPane.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\LoginFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\Main.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\StateRenderer.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\WindowListenerPerso.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\budgetPreviewPanel.java...
31 errors
1 warning
E:\JavaWorkspace\java-v2\nbproject\build-impl.xml:1133: Javadoc returned 1
BUILD FAILED (total time: 0 seconds)
J'ai viré tous les caractères spéciaux de mes annotations mais rien n'y fait...
Quelqu'un a une solution ou sait d'où ça vient??
Merci ;)
Message édité par t0um le 10-04-2013 à 03:01:31
