Probleme de lecture d'objet[RESOLU] - Java - Programmation
Marsh Posté le 07-09-2006 à 23:25:38
A priori ton code est bon.
Ajoute ois.close() après avoir créer ton objet.
Il faudrait regarder comment tu as créer ton objet avec ObjectOutputStream ?.
http://java.sun.com/j2se/1.4.2/doc [...] tream.html
Any attempt to read object data which exceeds the boundaries of the custom data written by the corresponding writeObject method will cause an OptionalDataException to be thrown with an eof field value of true. Non-object reads which exceed the end of the allotted data will reflect the end of data in the same way that they would indicate the end of the stream: bytewise reads will return -1 as the byte read or number of bytes read, and primitive reads will throw EOFExceptions. If there is no corresponding writeObject method, then the end of default serialized data marks the end of the allotted data.
Primitive and object read calls issued from within a readExternal method behave in the same manner--if the stream is already positioned at the end of data written by the corresponding writeExternal method, object reads will throw OptionalDataExceptions with eof set to true, bytewise reads will return -1, and primitive reads will throw EOFExceptions. Note that this behavior does not hold for streams written with the old ObjectStreamConstants.PROTOCOL_VERSION_1 protocol, in which the end of data written by writeExternal methods is not demarcated, and hence cannot be detected.
Marsh Posté le 08-09-2006 à 10:25:02
Merci pour ta réponse;
Voila comment j'ai créée mon objet avec ObjectOutputStream :
public void SaveTempoWorkSpace(){
 	FileOutputStream fos;
 	ObjectOutputStream oos;
for (int i=0;i<this.getZoneDessin().getPages().size();i++){
fos=null;
os=null;
Page page = (Page)(this.getZoneDessin().getPages()).get(i);
try {
fos = new FileOutputStream("."+this.SEPARATOR+
                              this.getTempoworkSpace()+
                                 this.SEPARATOR+
                                 page.getProjet()+
   this.SEPARATOR+
   page.getNom());
} catch (FileNotFoundException e) {}
try {
  oos = new ObjectOutputStream(fos);
} catch (IOException e) {}
try {
oos.writeObject(page);
try {
oos.flush();
oos.close();
fos.flush();
fos.close();
Marsh Posté le 18-09-2006 à 17:57:12
tu pourrais commencer par faire quelque chose quand il y a une exception
deja, commence par afficher les exceptions a coup de printStackTrace, tu verras si tout se passe bien ou pas. apres on avisera
Marsh Posté le 18-09-2006 à 20:08:13
fos = new FileOutputStream("."+this.SEPARATOR+...
Tu n'essayerais pas de mettre plusieurs objets dans ton fichier ?
Marsh Posté le 19-09-2006 à 14:48:29
java.io.EOFException
 at java.io.ObjectInputStream$PeekInputStream.readFully(Unknown Source)
 at java.io.ObjectInputStream$BlockDataInputStream.readShort(Unknown Source)
 at java.io.ObjectInputStream.readStreamHeader(Unknown Source)
 at java.io.ObjectInputStream.<init>(Unknown Source)
 at ihm.GestionProjet.load_arbo(GestionProjet.java:277)
 at ihm.GestionProjet.load_arbo(GestionProjet.java:258)
 at ihm.GestionProjet.loadJTree(GestionProjet.java:360)
 at ihm.Edit_RDP.<init>(Edit_RDP.java:166)
 at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
 at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
 at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
 at java.lang.reflect.Constructor.newInstance(Unknown Source)
 at org.eclipse.ve.internal.java.vce.launcher.remotevm.JFCLauncher.launch(JFCLauncher.java:56)
 at org.eclipse.ve.internal.java.vce.launcher.remotevm.JavaBeansLauncher.main(JavaBeansLauncher.java:77)
java.lang.reflect.InvocationTargetException
Caused by: java.lang.NullPointerException
 at ihm.GestionProjet.load_arbo(GestionProjet.java:280)
 ... 6 more
IWAV0052E Invocation Target Exception creating ihm.Edit_RDP
voila ce que donne un printStackTrace
Marsh Posté le 19-09-2006 à 14:52:00
lonely a dit :
non lonely  parce que  je change à chaque itération de ma boucle le pramétre d'etrée de fos
Marsh Posté le 19-09-2006 à 15:06:22
voila
Marsh Posté le 19-09-2006 à 15:56:51
Merci souk pour ta réponse mais malheureusement ça règle pas mon problème.
le problème est quand  je crée une instance de  FileInputStream la taille du fichier « fich.dat » passe de 3 ko a  0 ko et par conséquence lors de la lecture de lobjet jai une exception : EOFexception .
Déjà la première exception est : java.io.EOFException
Essaye de relire mon problème
Marsh Posté le 19-09-2006 à 16:56:07
est ce que chaque FilOutputStream est bien flushé et closé ? pas d'exception à ce niveau non plus ?
Marsh Posté le 20-09-2006 à 09:29:05
| souk a écrit : est ce que chaque FilOutputStream est bien flushé et closé ? pas d'exception à ce niveau non plus ?  |
oui, chaque FileOutputStream est bien flushé et closé
Marsh Posté le 21-09-2006 à 14:34:12
Le problème que j'avais, était due  au fait que le paramètre d'entrée de  FileInputStream qui est un String  et qui représente le chemin de mon fichier commençait par un chiffre (un peut bizarre) mais rien qu'on changeant le nom de mon fichier par un autre qui commence par une lettre ça marche.
Je vous remercie pour votre aide.
Marsh Posté le 29-08-2006 à 11:31:29
Voila mon problème :
Jessaye de lire des objets a partir dun fichier, voila la partie du code qui normalement me permet de le faire :
fis = new FileInputStream(fich.dat);
ois = new ObjectInputStream(fis);
page = (Page)(ois.readObject());
mais le problem est quand je crée une instance de FileInputStream la taille du fichier « fich.dat » passe de 3 ko a 0 ko et par conséquence lors de la lecture de lobjet jai une exception : EOFexception .
est ce que quelquun peut maider ?
Message édité par java_B le 21-09-2006 à 14:37:00
