problème minecraft : java head space
problème minecraft : java head space - Java - Programmation
Marsh Posté le 15-09-2020 à 01:40:21
bonjour alors voilà  mon probleme mon gamin n'arrive plus a joué a minecraft
il indique The game crashed whilst initializing game
Error: java.lang.OutOfMemoryError: Java heap space
Exit Code: -1
voici le rapport de plantage :
--- Minecraft Crash Report ----
// You should try our sister game, Minceraft!
Time: 15/09/20 01:21
Description: Initializing game
 at java.util.Arrays.copyOf(Arrays.java:3332)
 at java.lang.AbstractStringBuilder.expandCapacity(AbstractStringBuilder.java:137)
 at java.lang.AbstractStringBuilder.ensureCapacityInternal(AbstractStringBuilder.java:121)
 at java.lang.AbstractStringBuilder.append(AbstractStringBuilder.java:569)
 at java.lang.StringBuffer.append(StringBuffer.java:369)
 at java.io.BufferedReader.readLine(BufferedReader.java:370)
 at java.io.BufferedReader.readLine(BufferedReader.java:389)
 at java.io.BufferedReader$1.hasNext(BufferedReader.java:571)
 at java.util.Iterator.forEachRemaining(Iterator.java:115)
 at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801)
 at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:580)
 at dmb.a(SourceFile:236)
 at dmb.<init>(SourceFile:207)
 at dlx.<init>(SourceFile:428)
 at net.minecraft.client.main.Main.main(SourceFile:177)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Render thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
 Minecraft Version: 1.16.1
 Minecraft Version ID: 1.16.1
 Operating System: Windows 10 (amd64) version 10.0
 Java Version: 1.8.0_51, Oracle Corporation
 Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
 Memory: 1444312880 bytes (1377 MB) / 2147483648 bytes (2048 MB) up to 2147483648 bytes (2048 MB)
 CPUs: 8
 JVM Flags: 9 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xss1M -Xmx2G -XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:G1NewSizePercent=20 -XX:G1ReservePercent=20 -XX:MaxGCPauseMillis=50 -XX:G1HeapRegionSize=32M
 Launched Version: 1.16.1
 Backend library: LWJGL version 3.2.2 build 10
 Backend API: NO CONTEXT
 GL Caps:
 Using VBOs: Yes
 Is Modded: Probably not. Jar signature remains and client brand is untouched.
 Type: Client (map_client.txt)
 CPU: <unknown>
si quelque personne peut m'éclairé car la je bloque merci d'avance
Marsh Posté le 17-09-2020 à 10:17:26
personne pour mon problème...
Marsh Posté le 17-09-2020 à 10:26:18
Ce n'est pas vraiment de la programmation ta question...
De plus une simple recherche Google avec la première ligne de l'erreur et le mot clef minecraft :
https://www.google.com/search?q=min [...] heap+space
Premier résultat :
https://minecraft.fr/forum/threads/ [...] ce.240238/
Qui pointe vers :
https://minecraft.fr/forum/threads/ [...] st-1544666
Ce n'est pas pour me moquer mais pour t'aider lors de ton prochain problème, poser les bonnes questions dans un moteur de recherche pour trouver les bonnes réponses ! ^^
 [:ab614]
D3
Marsh Posté le 17-09-2020 à 21:57:54
merci de ton aide quand même
j'ai déjà essayé les solutions que tu propose au dessus avant même que tu ne l'ai propose
aucun résultat
Marsh Posté le 18-09-2020 à 09:29:27
Dans tous les cas tu auras plus de réponses sur un forum dédié au jeu ou dans ce post hfr : https://forum.hardware.fr/hfr/JeuxV [...] 0752_1.htm
Je penses que personne dans la section programmation ne vas t'aider à corriger l'exécutable du jeu ! ^^
D3
