Un message d'erreur qui emêche l'utilisation de MySql sur mon pc
Un message d'erreur qui emêche l'utilisation de MySql sur mon pc - PHP - Programmation
Marsh Posté le 21-05-2003 à 12:03:08
Voici les messages d'erreur: Warning: Cannot add header information - headers already sent by (output started at c:\program files\easyphp\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\program files\easyphp\phpmyadmin\header.inc.php on line 23
Warning: Cannot add header information - headers already sent by (output started at c:\program files\easyphp\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\program files\easyphp\phpmyadmin\header.inc.php on line 24
Warning: Cannot add header information - headers already sent by (output started at c:\program files\easyphp\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\program files\easyphp\phpmyadmin\header.inc.php on line 25
Warning: Cannot add header information - headers already sent by (output started at c:\program files\easyphp\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\program files\easyphp\phpmyadmin\header.inc.php on line 26
Warning: Cannot add header information - headers already sent by (output started at c:\program files\easyphp\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\program files\easyphp\phpmyadmin\header.inc.php on line 27
Warning: Cannot add header information - headers already sent by (output started at c:\program files\easyphp\phpmyadmin\libraries\auth\config.auth.lib.php:91) in c:\program files\easyphp\phpmyadmin\header.inc.php on line 29
Erreur
MySQL a répondu:
Can't connect to MySQL server on 'localhost' (10061)
J'ai tout essayer notemment une desinstallation et réinstallation...
Help please
Marsh Posté le 21-05-2003 à 12:38:51
desinstalles easyphp et supprime l'intégralité des repertoires restant dans C:\PragramesFiles\Easyphp\  :o
après tu télecharges la derniere version et tu reisntalles
from here and there -- \o__________________________________ -- la révolution de la terre, en silence
Marsh Posté le 21-05-2003 à 14:08:20
ou tu corriges :
c que du PHP apres tout ...
