[PHP MYSQL] Question simple...
Question simple... [PHP MYSQL] - PHP - Programmation
Marsh Posté le 08-03-2004 à 16:29:41
bonjour a tous !
Me revoici pour une nouvelle question... Voici mon code :
  1. deneb.php
  2. <?PHP
  3. $link = mysql_connect("XXX", "XXX", "XXX" )
  4.         or die("Impossible de se connecter : " . mysql_error());
  5. mysql_select_db("XXX" );
  6. $result = mysql_query('SELECT * FROM BD', $link );
  7. echo '<CENTER><B>Alpha Deneb Cygni (28/44)</B>';
  8. echo '<Table class=table width=569>';
  9. echo '<TR>';
  10. echo '<TD width=49 class=table>ID</TD>';
  11. echo '<TD width=140 class=table>Owner</TD>';
  12. echo '<TD width=140 class=table>Attacker</TD>';
  13. echo '<TD width=150 class=table>Date arrive</TD>';
  14. echo '<TD width=60 class=table>Save</CENTER></TD>';
  15. echo '</TR>';
  16. while ($row = mysql_fetch_array($result)){
  17. echo '<TR>';
  18. echo '<TD><form method="post" action="update.php"><input size="2" type="text" name="id" value="'.$row['id'].'"></TD>';
  19. echo '<TD><input type="text" name="owner" value="'.$row['owner'].'"></TD>';
  20. echo '<TD><input type="text" name="attack" value="'.$row['attack'].'"></TD>';
  21. echo '<TD><input type="text" name="date" value="'.$row['date'].'"></TD>';
  22. echo '<TD><input type="image" src="send.gif" border="0"><BR></TD>';
  23. echo '</TR>';}
  24. echo '</TABLE>';
  25. mysql_free_result($result);
  26. mysql_close($link);
  27. ?>
Autre code :
  1. update.php
  2. <?PHP
  3. $link = mysql_connect("XXX", "XXX", "XXX" ) or die("Impossible de se connecter : " . mysql_error());
  4. mysql_select_db("XXX" );
  5. $id = $_POST['id'];
  6. $owner = $_POST['owner'];
  7. $attack = $_POST['attack'];
  8. $date = $_POST['date'];
  9. echo 'Save !!<BR>Click <a href=index.php>HERE</a> to return at home.<BR>';
  10. //ligne de test :
  11. echo 'id :'.$id.' <BR>Owner :'.$owner.' <BR>Attack :'.$attack.' <BR>Date :'.$date;
  12. mysql_close($link);
  13. ?>
Pour ceux qui ont déchiffrer mon code (Bravo) : si je clique sur n'importe quel send.gif il me renvoie toujours la derniere ligne... Pourquoi ?
Merci par avance a ceux qui se pencherons sur mon probleme.
Message édité par guiotv2 le 08-03-2004 à 16:30:23
Marsh Posté le 08-03-2004 à 16:33:00
et si tu fermais ton <form> ?
Message édité par greut le 08-03-2004 à 16:33:30
Marsh Posté le 08-03-2004 à 16:34:50
====>    :whistle:
Chercher une erreur pendant si longtemps...
Merci greut !  :hello:
Marsh Posté le 08-03-2004 à 16:46:37
mais je t'en prie.
Tant que j'y suis, consulte http://validator.w3.org c'est toujours pratique.
Marsh Posté le 08-03-2004 à 17:21:05
LOL j'adore ces erreurs à la con, c'est le genre d'erreur tu la fais une fois mais pas deux :p
Quoi que :p
