Rewrite + coppemine + ovh = erreur 403
Rewrite + coppemine + ovh = erreur 403 - PHP - Programmation
Marsh Posté le 17-05-2008 à 19:58:44
Bonjour j'ai installé coppermine avec succes mais le pluggin url rewrite plante sous ovh et j'ai droit a des acces denied
voici le code du ht access
## Coppermine Photo Gallery
## Copyright (c) 2003-2006 Coppermine Dev Team
## v1.1 originaly written by Gregory DEMAR
## This program is free software; you can redistribute it and/or modify
## it under the terms of the GNU General Public License as published by
## the Free Software Foundation; either version 2 of the License, or
## (at your option) any later version.
## Coppermine version: 1.4.9
## $Source$
## $Revision: 3231 $
## $Author: nibbler999 $
## $Date: 2006-08-16 15:05:39 +0200 (Mi, 16 Aug 2006) $
Options FollowSymLinks SymLinksIfOwnerMatch
RewriteEngine on
# Uncomment the following line if your webserver's
# URL is not directly related to physical file paths.
# Update "YOUR_COPPERMINE_ROOT" (just / for root)
#RewriteBase /YOUR_COPPERMINE_ROOT
# Rewrite index urls
RewriteRule index-([0-9]*)\.html index.php?cat=$1 [NC]
RewriteRule index-([0-9]*)-page-([0-9]*)\.html index.php?cat=$1&page=$2 [NC]
# Rewrite thumbnail urls
RewriteRule thumbnails-([a-z0-9]*)-([\-]?[0-9]*)\.html thumbnails.php?album=$1&cat=$2 [NC]
RewriteRule thumbnails-([a-z0-9]*)-page-([0-9]*)\.html thumbnails.php?album=$1&page=$2 [NC]
RewriteRule thumbnails-([a-z0-9]*)-([\-]?[0-9]*)-page-([0-9]*)\.html thumbnails.php?album=$1&cat=$2&page=$3 [NC]
RewriteRule thumbnails-([0-9a-z]*)\.html thumbnails.php?album=$1 [NC]
RewriteRule thumbnails-search-(.*)\.html thumbnails.php?album=search&search=$1 [NC]
# Rewrite displayimage urls
RewriteRule displayimage-([a-z0-9]+)-([\-]?[0-9]+)-([\-]?[0-9]+)\.html displayimage.php?album=$1&cat=$2&pos=$3 [NC]
RewriteRule displayimage-([a-z0-9]+)-([\-]?[0-9]+)\.html displayimage.php?album=$1&pos=$2 [NC]
RewriteRule displayimage-([0-9]+)\.html displayimage.php?pos=-$1 [NC]
RewriteRule slideshow-([0-9]+)-([\-]?[0-9]+)-([0-9]+)\.html displayimage.php?album=$1&pid=$2&slideshow=$3 [NC]
RewriteRule slideshow-([a-z]+)-([\-]?[0-9]+)-([0-9]+)-([0-9]+)\.html displayimage.php?album=$1&cat=$2&pid=$3&slideshow=$4 [NC]
je vous demande un gros coup de main car j'y comprend pas grand chose, merci a vous
Marsh Posté le 17-05-2008 à 20:06:02
Nous ne sommes pas le support officiel de Coppermine :jap:
Sinon essayes de remplacer la première ligne par Options Includes ExecCGI -Multiviews FollowSymLinks Indexes
Message édité par WiiDS le 17-05-2008 à 20:08:25
"I can cry like Roger. It's just a shame I can't play like him" - Andy Murray, 2010
Marsh Posté le 17-05-2008 à 20:51:41
je sais que c'est pas le forum coppermine d'ailleur j'ai fait une demande chez eux et j'ai eux un acceuil comment dire .... pas tres agreable
je te remerci pour ta reponse car s marche ! ! ! merci beaucoup
j'aime bien comprendre ,es que tu pourrais m'expliqer en quelques mots se que sa change? merci beaucoup
Marsh Posté le 17-05-2008 à 20:54:41
Je n'ai strictement aucune idée de ce que ca peut changer :D, j'ai fait une recherche Google avec les termes "erreur 403 htaccess OVH" et suis tombé sur cette solution, comme quoi Google est notre ami :jap:
Marsh Posté le 17-05-2008 à 20:57:22
ben ecoute j'ai fait a peu prés la meme recherche j'avais pas trouvé, google est ton ami mais pas encore bien le mien apparement lol
Marsh Posté le 19-05-2008 à 01:06:18
RE bonjour a tous, j'ai une autre question voila maintnant une page de galerie sincrit de telle maniere
http://www.mike-photogalerie.fr/thumbnails-1.html
j'aimerais savoir si il etait pas possible que le thumbnails soit remplacer par le nom de la galerie?
merci a tous
