Problème classe vb.net - VB/VBA/VBS - Programmation
MarshPosté le 03-07-2016 à 05:26:22
Bonjours voilà j'ai essayer plusieur theme pour ma form mais tous mes theme me mes sa :
http://prntscr.com/bo44bh Donc je sais pas comment faire. Le theme que j'ai enregistrer et dans une classe voilà le theme :[spoiler] [cpp]'[INFO] 'ThemeBase Creator: Aeonhack 'Site: ********* '[DATE] 'Created: 08/02/2011 'Changed: 12/06/2011 '[VERSION] 'ThemeBase Version: 1.5.4 ' '[INFO] 'Theme Creator: Novi 'Theme Name: CarbonOrainsTheme '[DATE] 'Created: 7/14/2013 'Changed: 7/26/2013 'Released: 7/27/2013 '[VERSION] 'Version: 1.1 '[CREDITS] 'Thanks to Mavamaarten for the tut =)) 'Thanks to Aeonhack for the important ThemeBase154 '--------[/CREDITS]------------ #Region "Imports" Imports System, System.IO, System.Collections.Generic Imports System.Drawing, System.Drawing.Drawing2D Imports System.ComponentModel, System.Windows.Forms Imports System.Runtime.InteropServices Imports System.Drawing.Imaging Imports System.Windows.Forms.TabControl Imports System.ComponentModel.Design #End Region #Region "THEMEBASE" MustInherit Class ThemeContainer154 Inherits ContainerControl
#Region " Initialization "
Protected G As Graphics, B As Bitmap
Sub New() SetStyle(DirectCast(139270, ControlStyles), True)
_ImageSize = Size.Empty Font = New Font("Verdana", 8S)
MeasureBitmap = New Bitmap(1, 1) MeasureGraphics = Graphics.FromImage(MeasureBitmap)
DrawRadialPath = New GraphicsPath
InvalidateCustimization() End Sub
Protected NotOverridable Overrides Sub OnHandleCreated(ByVal e As EventArgs) If DoneCreation Then InitializeMessages()
InvalidateCustimization() ColorHook()
If Not _LockWidth = 0 Then Width = _LockWidth If Not _LockHeight = 0 Then Height = _LockHeight If Not _ControlMode Then MyBase.Dock = DockStyle.Fill
Transparent = _Transparent If _Transparent AndAlso _BackColor Then BackColor = Color.Transparent
MyBase.OnHandleCreated(e) End Sub
Private DoneCreation As Boolean Protected NotOverridable Overrides Sub OnParentChanged(ByVal e As EventArgs) MyBase.OnParentChanged(e)
If Parent Is Nothing Then Return _IsParentForm = TypeOf Parent Is Form
If Not _ControlMode Then InitializeMessages()
If _IsParentForm Then ParentForm.FormBorderStyle = _BorderStyle ParentForm.TransparencyKey = _TransparencyKey
If Not DesignMode Then AddHandler ParentForm.Shown, AddressOf FormShown End If End If
Parent.BackColor = BackColor End If
OnCreation() DoneCreation = True InvalidateTimer() End Sub
#End Region
Private Sub DoAnimation(ByVal i As Boolean) OnAnimation() If i Then Invalidate() End Sub
Protected NotOverridable Overrides Sub OnPaint(ByVal e As PaintEventArgs) If Width = 0 OrElse Height = 0 Then Return
If _Transparent AndAlso _ControlMode Then PaintHook() e.Graphics.DrawImage(B, 0, 0) Else G = e.Graphics PaintHook() End If End Sub
Protected Overrides Sub OnHandleDestroyed(ByVal e As EventArgs) RemoveAnimationCallback(AddressOf DoAnimation) MyBase.OnHandleDestroyed(e) End Sub
Private HasShown As Boolean Private Sub FormShown(ByVal sender As Object, ByVal e As EventArgs) If _ControlMode OrElse HasShown Then Return
If _StartPosition = FormStartPosition.CenterParent OrElse _StartPosition = FormStartPosition.CenterScreen Then Dim SB As Rectangle = Screen.PrimaryScreen.Bounds Dim CB As Rectangle = ParentForm.Bounds ParentForm.Location = New Point(SB.Width \ 2 - CB.Width \ 2, SB.Height \ 2 - CB.Width \ 2) End If
HasShown = True End Sub
#Region " Size Handling "
Private Frame As Rectangle Protected NotOverridable Overrides Sub OnSizeChanged(ByVal e As EventArgs) If _Movable AndAlso Not _ControlMode Then Frame = New Rectangle(7, 7, Width - 14, _Header - 7) End If
InvalidateBitmap() Invalidate()
MyBase.OnSizeChanged(e) End Sub
Protected Overrides Sub SetBoundsCore(ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal specified As BoundsSpecified) If Not _LockWidth = 0 Then width = _LockWidth If Not _LockHeight = 0 Then height = _LockHeight MyBase.SetBoundsCore(x, y, width, height, specified) End Sub
#End Region
#Region " State Handling "
Protected State As MouseState Private Sub SetState(ByVal current As MouseState) State = current Invalidate() End Sub
Protected Overrides Sub OnMouseMove(ByVal e As MouseEventArgs) If Not (_IsParentForm AndAlso ParentForm.WindowState = FormWindowState.Maximized) Then If _Sizable AndAlso Not _ControlMode Then InvalidateMouse() End If
MyBase.OnMouseMove(e) End Sub
Protected Overrides Sub OnEnabledChanged(ByVal e As EventArgs) If Enabled Then SetState(MouseState.None) Else SetState(MouseState.Block) MyBase.OnEnabledChanged(e) End Sub
Protected Overrides Sub OnMouseEnter(ByVal e As EventArgs) SetState(MouseState.Over) MyBase.OnMouseEnter(e) End Sub
Protected Overrides Sub OnMouseUp(ByVal e As MouseEventArgs) SetState(MouseState.Over) MyBase.OnMouseUp(e) End Sub
Protected Overrides Sub OnMouseLeave(ByVal e As EventArgs) SetState(MouseState.None)
If GetChildAtPoint(PointToClient(MousePosition)) IsNot Nothing Then If _Sizable AndAlso Not _ControlMode Then Cursor = Cursors.Default Previous = 0 End If End If
MyBase.OnMouseLeave(e) End Sub
Protected Overrides Sub OnMouseDown(ByVal e As MouseEventArgs) If e.Button = Windows.Forms.MouseButtons.Left Then SetState(MouseState.Down)
If Not (_IsParentForm AndAlso ParentForm.WindowState = FormWindowState.Maximized OrElse _ControlMode) Then If _Movable AndAlso Frame.Contains(e.Location) Then Capture = False WM_LMBUTTONDOWN = True DefWndProc(Messages(0)) ElseIf _Sizable AndAlso Not Previous = 0 Then Capture = False WM_LMBUTTONDOWN = True DefWndProc(Messages(Previous)) End If End If
MyBase.OnMouseDown(e) End Sub
Private WM_LMBUTTONDOWN As Boolean Protected Overrides Sub WndProc(ByRef m As Message) MyBase.WndProc(m)
If WM_LMBUTTONDOWN AndAlso m.Msg = 513 Then WM_LMBUTTONDOWN = False
SetState(MouseState.Over) If Not _SmartBounds Then Return
If IsParentMdi Then CorrectBounds(New Rectangle(Point.Empty, Parent.Parent.Size)) Else CorrectBounds(Screen.FromControl(Parent).WorkingArea) End If End If End Sub
Private GetIndexPoint As Point Private B1, B2, B3, B4 As Boolean Private Function GetIndex() As Integer GetIndexPoint = PointToClient(MousePosition) B1 = GetIndexPoint.X < 7 B2 = GetIndexPoint.X > Width - 7 B3 = GetIndexPoint.Y < 7 B4 = GetIndexPoint.Y > Height - 7
If B1 AndAlso B3 Then Return 4 If B1 AndAlso B4 Then Return 7 If B2 AndAlso B3 Then Return 5 If B2 AndAlso B4 Then Return 8 If B1 Then Return 1 If B2 Then Return 2 If B3 Then Return 3 If B4 Then Return 6 Return 0 End Function
Private Current, Previous As Integer Private Sub InvalidateMouse() Current = GetIndex() If Current = Previous Then Return
Previous = Current Select Case Previous Case 0 Cursor = Cursors.Default Case 1, 2 Cursor = Cursors.SizeWE Case 3, 6 Cursor = Cursors.SizeNS Case 4, 8 Cursor = Cursors.SizeNWSE Case 5, 7 Cursor = Cursors.SizeNESW End Select End Sub
Private Messages(8) As Message Private Sub InitializeMessages() Messages(0) = Message.Create(Parent.Handle, 161, New IntPtr(2), IntPtr.Zero) For I As Integer = 1 To 8 Messages(I) = Message.Create(Parent.Handle, 161, New IntPtr(I + 9), IntPtr.Zero) Next End Sub
Private Sub CorrectBounds(ByVal bounds As Rectangle) If Parent.Width > bounds.Width Then Parent.Width = bounds.Width If Parent.Height > bounds.Height Then Parent.Height = bounds.Height
Dim X As Integer = Parent.Location.X Dim Y As Integer = Parent.Location.Y
If X < bounds.X Then X = bounds.X If Y < bounds.Y Then Y = bounds.Y
Dim Width As Integer = bounds.X + bounds.Width Dim Height As Integer = bounds.Y + bounds.Height
If X + Parent.Width > Width Then X = Width - Parent.Width If Y + Parent.Height > Height Then Y = Height - Parent.Height
Parent.Location = New Point(X, Y) End Sub
#End Region
#Region " Base Properties "
Overrides Property Dock As DockStyle Get Return MyBase.Dock End Get Set(ByVal value As DockStyle) If Not _ControlMode Then Return MyBase.Dock = value End Set End Property
Private _BackColor As Boolean <Category("Misc" )> Overrides Property BackColor() As Color Get Return MyBase.BackColor End Get Set(ByVal value As Color) If value = MyBase.BackColor Then Return
If Not IsHandleCreated AndAlso _ControlMode AndAlso value = Color.Transparent Then _BackColor = True Return End If
MyBase.BackColor = value If Parent IsNot Nothing Then If Not _ControlMode Then Parent.BackColor = value ColorHook() End If End Set End Property
Overrides Property MinimumSize As Size Get Return MyBase.MinimumSize End Get Set(ByVal value As Size) MyBase.MinimumSize = value If Parent IsNot Nothing Then Parent.MinimumSize = value End Set End Property
Overrides Property MaximumSize As Size Get Return MyBase.MaximumSize End Get Set(ByVal value As Size) MyBase.MaximumSize = value If Parent IsNot Nothing Then Parent.MaximumSize = value End Set End Property
Overrides Property Text() As String Get Return MyBase.Text End Get Set(ByVal value As String) MyBase.Text = value Invalidate() End Set End Property
Overrides Property Font() As Font Get Return MyBase.Font End Get Set(ByVal value As Font) MyBase.Font = value Invalidate() End Set End Property
<Browsable(False), EditorBrowsable(EditorBrowsableState.Never), DesignerSerializationVisibility(DesignerSerializationVisibility.Hidden)> Overrides Property ForeColor() As Color Get Return Color.Empty End Get Set(ByVal value As Color) End Set End Property <Browsable(False), EditorBrowsable(EditorBrowsableState.Never), DesignerSerializationVisibility(DesignerSerializationVisibility.Hidden)> Overrides Property BackgroundImage() As Image Get Return Nothing End Get Set(ByVal value As Image) End Set End Property <Browsable(False), EditorBrowsable(EditorBrowsableState.Never), DesignerSerializationVisibility(DesignerSerializationVisibility.Hidden)> Overrides Property BackgroundImageLayout() As ImageLayout Get Return ImageLayout.None End Get Set(ByVal value As ImageLayout) End Set End Property
#End Region
#Region " Public Properties "
Private _SmartBounds As Boolean = True Property SmartBounds() As Boolean Get Return _SmartBounds End Get Set(ByVal value As Boolean) _SmartBounds = value End Set End Property
Private _Movable As Boolean = True Property Movable() As Boolean Get Return _Movable End Get Set(ByVal value As Boolean) _Movable = value End Set End Property
Private _Sizable As Boolean = True Property Sizable() As Boolean Get Return _Sizable End Get Set(ByVal value As Boolean) _Sizable = value End Set End Property
Private _TransparencyKey As Color Property TransparencyKey() As Color Get If _IsParentForm AndAlso Not _ControlMode Then Return ParentForm.TransparencyKey Else Return _TransparencyKey End Get Set(ByVal value As Color) If value = _TransparencyKey Then Return _TransparencyKey = value
If _IsParentForm AndAlso Not _ControlMode Then ParentForm.TransparencyKey = value ColorHook() End If End Set End Property
Private _BorderStyle As FormBorderStyle Property BorderStyle() As FormBorderStyle Get If _IsParentForm AndAlso Not _ControlMode Then Return ParentForm.FormBorderStyle Else Return _BorderStyle End Get Set(ByVal value As FormBorderStyle) _BorderStyle = value
If _IsParentForm AndAlso Not _ControlMode Then ParentForm.FormBorderStyle = value
If Not value = FormBorderStyle.None Then Movable = False Sizable = False End If End If End Set End Property
Private _StartPosition As FormStartPosition Property StartPosition As FormStartPosition Get If _IsParentForm AndAlso Not _ControlMode Then Return ParentForm.StartPosition Else Return _StartPosition End Get Set(ByVal value As FormStartPosition) _StartPosition = value
If _IsParentForm AndAlso Not _ControlMode Then ParentForm.StartPosition = value End If End Set End Property
Private _NoRounding As Boolean Property NoRounding() As Boolean Get Return _NoRounding End Get Set(ByVal v As Boolean) _NoRounding = v Invalidate() End Set End Property
Private _Image As Image Property Image() As Image Get Return _Image End Get Set(ByVal value As Image) If value Is Nothing Then _ImageSize = Size.Empty Else _ImageSize = value.Size
_Image = value Invalidate() End Set End Property
Private Items As New Dictionary(Of String, Color) Property Colors() As Bloom() Get Dim T As New List(Of Bloom) Dim E As Dictionary(Of String, Color).Enumerator = Items.GetEnumerator
While E.MoveNext T.Add(New Bloom(E.Current.Key, E.Current.Value)) End While
Return T.ToArray End Get Set(ByVal value As Bloom()) For Each B As Bloom In value If Items.ContainsKey(B.Name) Then Items(B.Name) = B.Value Next
InvalidateCustimization() ColorHook() Invalidate() End Set End Property
Private _Customization As String Property Customization() As String Get Return _Customization End Get Set(ByVal value As String) If value = _Customization Then Return
Dim Data As Byte() Dim Items As Bloom() = Colors
Try Data = Convert.FromBase64String(value) For I As Integer = 0 To Items.Length - 1 Items(I).Value = Color.FromArgb(BitConverter.ToInt32(Data, I * 4)) Next Catch Return End Try
_Customization = value
Colors = Items ColorHook() Invalidate() End Set End Property
Private _Transparent As Boolean Property Transparent() As Boolean Get Return _Transparent End Get Set(ByVal value As Boolean) _Transparent = value If Not (IsHandleCreated OrElse _ControlMode) Then Return
If Not value AndAlso Not BackColor.A = 255 Then Throw New Exception("Unable to change value to false while a transparent BackColor is in use." ) End If
SetStyle(ControlStyles.Opaque, Not value) SetStyle(ControlStyles.SupportsTransparentBackColor, value)
InvalidateBitmap() Invalidate() End Set End Property
#End Region
#Region " Private Properties "
Private _ImageSize As Size Protected ReadOnly Property ImageSize() As Size Get Return _ImageSize End Get End Property
Private _IsParentForm As Boolean Protected ReadOnly Property IsParentForm As Boolean Get Return _IsParentForm End Get End Property
Protected ReadOnly Property IsParentMdi As Boolean Get If Parent Is Nothing Then Return False Return Parent.Parent IsNot Nothing End Get End Property
Private _LockWidth As Integer Protected Property LockWidth() As Integer Get Return _LockWidth End Get Set(ByVal value As Integer) _LockWidth = value If Not LockWidth = 0 AndAlso IsHandleCreated Then Width = LockWidth End Set End Property
Private _LockHeight As Integer Protected Property LockHeight() As Integer Get Return _LockHeight End Get Set(ByVal value As Integer) _LockHeight = value If Not LockHeight = 0 AndAlso IsHandleCreated Then Height = LockHeight End Set End Property
Private _Header As Integer = 24 Protected Property Header() As Integer Get Return _Header End Get Set(ByVal v As Integer) _Header = v
If Not _ControlMode Then Frame = New Rectangle(7, 7, Width - 14, v - 7) Invalidate() End If End Set End Property
Private _ControlMode As Boolean Protected Property ControlMode() As Boolean Get Return _ControlMode End Get Set(ByVal v As Boolean) _ControlMode = v
Private _IsAnimated As Boolean Protected Property IsAnimated() As Boolean Get Return _IsAnimated End Get Set(ByVal value As Boolean) _IsAnimated = value InvalidateTimer() End Set End Property
#End Region
#Region " Property Helpers "
Protected Function GetPen(ByVal name As String) As Pen Return New Pen(Items(name)) End Function Protected Function GetPen(ByVal name As String, ByVal width As Single) As Pen Return New Pen(Items(name), width) End Function
Protected Function GetBrush(ByVal name As String) As SolidBrush Return New SolidBrush(Items(name)) End Function
Protected Function GetColor(ByVal name As String) As Color Return Items(name) End Function
Protected Sub SetColor(ByVal name As String, ByVal value As Color) If Items.ContainsKey(name) Then Items(name) = value Else Items.Add(name, value) End Sub Protected Sub SetColor(ByVal name As String, ByVal r As Byte, ByVal g As Byte, ByVal b As Byte) SetColor(name, Color.FromArgb(r, g, b)) End Sub Protected Sub SetColor(ByVal name As String, ByVal a As Byte, ByVal r As Byte, ByVal g As Byte, ByVal b As Byte) SetColor(name, Color.FromArgb(a, r, g, b)) End Sub Protected Sub SetColor(ByVal name As String, ByVal a As Byte, ByVal value As Color) SetColor(name, Color.FromArgb(a, value)) End Sub
Private Sub InvalidateBitmap() If _Transparent AndAlso _ControlMode Then If Width = 0 OrElse Height = 0 Then Return B = New Bitmap(Width, Height, PixelFormat.Format32bppPArgb) G = Graphics.FromImage(B) Else G = Nothing B = Nothing End If End Sub
Private Sub InvalidateCustimization() Dim M As New MemoryStream(Items.Count * 4)
For Each B As Bloom In Colors M.Write(BitConverter.GetBytes(B.Value.ToArgb), 0, 4) Next
M.Close() _Customization = Convert.ToBase64String(M.ToArray) End Sub
Private Sub InvalidateTimer() If DesignMode OrElse Not DoneCreation Then Return
If _IsAnimated Then AddAnimationCallback(AddressOf DoAnimation) Else RemoveAnimationCallback(AddressOf DoAnimation) End If End Sub
#End Region
#Region " User Hooks "
Protected MustOverride Sub ColorHook() Protected MustOverride Sub PaintHook()
Protected Overridable Sub OnCreation() End Sub
Protected Overridable Sub OnAnimation() End Sub
#End Region
#Region " Offset "
Private OffsetReturnRectangle As Rectangle Protected Function Offset(ByVal r As Rectangle, ByVal amount As Integer) As Rectangle OffsetReturnRectangle = New Rectangle(r.X + amount, r.Y + amount, r.Width - (amount * 2), r.Height - (amount * 2)) Return OffsetReturnRectangle End Function
Private OffsetReturnSize As Size Protected Function Offset(ByVal s As Size, ByVal amount As Integer) As Size OffsetReturnSize = New Size(s.Width + amount, s.Height + amount) Return OffsetReturnSize End Function
Private OffsetReturnPoint As Point Protected Function Offset(ByVal p As Point, ByVal amount As Integer) As Point OffsetReturnPoint = New Point(p.X + amount, p.Y + amount) Return OffsetReturnPoint End Function
#End Region
#Region " Center "
Private CenterReturn As Point
Protected Function Center(ByVal p As Rectangle, ByVal c As Rectangle) As Point CenterReturn = New Point((p.Width \ 2 - c.Width \ 2) + p.X + c.X, (p.Height \ 2 - c.Height \ 2) + p.Y + c.Y) Return CenterReturn End Function Protected Function Center(ByVal p As Rectangle, ByVal c As Size) As Point CenterReturn = New Point((p.Width \ 2 - c.Width \ 2) + p.X, (p.Height \ 2 - c.Height \ 2) + p.Y) Return CenterReturn End Function
Protected Function Center(ByVal child As Rectangle) As Point Return Center(Width, Height, child.Width, child.Height) End Function Protected Function Center(ByVal child As Size) As Point Return Center(Width, Height, child.Width, child.Height) End Function Protected Function Center(ByVal childWidth As Integer, ByVal childHeight As Integer) As Point Return Center(Width, Height, childWidth, childHeight) End Function
Protected Function Center(ByVal p As Size, ByVal c As Size) As Point Return Center(p.Width, p.Height, c.Width, c.Height) End Function
Protected Function Center(ByVal pWidth As Integer, ByVal pHeight As Integer, ByVal cWidth As Integer, ByVal cHeight As Integer) As Point CenterReturn = New Point(pWidth \ 2 - cWidth \ 2, pHeight \ 2 - cHeight \ 2) Return CenterReturn End Function
#End Region
#Region " Measure "
Private MeasureBitmap As Bitmap Private MeasureGraphics As Graphics
Protected Function Measure() As Size SyncLock MeasureGraphics Return MeasureGraphics.MeasureString(Text, Font, Width).ToSize End SyncLock End Function Protected Function Measure(ByVal text As String) As Size SyncLock MeasureGraphics Return MeasureGraphics.MeasureString(text, Font, Width).ToSize End SyncLock End Function
#End Region
#Region " DrawPixel "
Private DrawPixelBrush As SolidBrush
Protected Sub DrawPixel(ByVal c1 As Color, ByVal x As Integer, ByVal y As Integer) If _Transparent Then B.SetPixel(x, y, c1) Else DrawPixelBrush = New SolidBrush(c1) G.FillRectangle(DrawPixelBrush, x, y, 1, 1) End If End Sub
#End Region
#Region " DrawCorners "
Private DrawCornersBrush As SolidBrush
Protected Sub DrawCorners(ByVal c1 As Color, ByVal offset As Integer) DrawCorners(c1, 0, 0, Width, Height, offset) End Sub Protected Sub DrawCorners(ByVal c1 As Color, ByVal r1 As Rectangle, ByVal offset As Integer) DrawCorners(c1, r1.X, r1.Y, r1.Width, r1.Height, offset) End Sub Protected Sub DrawCorners(ByVal c1 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal offset As Integer) DrawCorners(c1, x + offset, y + offset, width - (offset * 2), height - (offset * 2)) End Sub
Protected Sub DrawCorners(ByVal c1 As Color) DrawCorners(c1, 0, 0, Width, Height) End Sub Protected Sub DrawCorners(ByVal c1 As Color, ByVal r1 As Rectangle) DrawCorners(c1, r1.X, r1.Y, r1.Width, r1.Height) End Sub Protected Sub DrawCorners(ByVal c1 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer) If _NoRounding Then Return
If _Transparent Then B.SetPixel(x, y, c1) B.SetPixel(x + (width - 1), y, c1) B.SetPixel(x, y + (height - 1), c1) B.SetPixel(x + (width - 1), y + (height - 1), c1) Else DrawCornersBrush = New SolidBrush(c1) G.FillRectangle(DrawCornersBrush, x, y, 1, 1) G.FillRectangle(DrawCornersBrush, x + (width - 1), y, 1, 1) G.FillRectangle(DrawCornersBrush, x, y + (height - 1), 1, 1) G.FillRectangle(DrawCornersBrush, x + (width - 1), y + (height - 1), 1, 1) End If End Sub
#End Region
#Region " DrawBorders "
Protected Sub DrawBorders(ByVal p1 As Pen, ByVal offset As Integer) DrawBorders(p1, 0, 0, Width, Height, offset) End Sub Protected Sub DrawBorders(ByVal p1 As Pen, ByVal r As Rectangle, ByVal offset As Integer) DrawBorders(p1, r.X, r.Y, r.Width, r.Height, offset) End Sub Protected Sub DrawBorders(ByVal p1 As Pen, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal offset As Integer) DrawBorders(p1, x + offset, y + offset, width - (offset * 2), height - (offset * 2)) End Sub
Protected Sub DrawBorders(ByVal p1 As Pen) DrawBorders(p1, 0, 0, Width, Height) End Sub Protected Sub DrawBorders(ByVal p1 As Pen, ByVal r As Rectangle) DrawBorders(p1, r.X, r.Y, r.Width, r.Height) End Sub Protected Sub DrawBorders(ByVal p1 As Pen, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer) G.DrawRectangle(p1, x, y, width - 1, height - 1) End Sub
#End Region
#Region " DrawText "
Private DrawTextPoint As Point Private DrawTextSize As Size
Protected Sub DrawText(ByVal b1 As Brush, ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer) DrawText(b1, Text, a, x, y) End Sub Protected Sub DrawText(ByVal b1 As Brush, ByVal text As String, ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer) If text.Length = 0 Then Return
Select Case a Case HorizontalAlignment.Left G.DrawString(text, Font, b1, x, DrawTextPoint.Y + y) Case HorizontalAlignment.Center G.DrawString(text, Font, b1, DrawTextPoint.X + x, DrawTextPoint.Y + y) Case HorizontalAlignment.Right G.DrawString(text, Font, b1, Width - DrawTextSize.Width - x, DrawTextPoint.Y + y) End Select End Sub
Protected Sub DrawText(ByVal b1 As Brush, ByVal p1 As Point) If Text.Length = 0 Then Return G.DrawString(Text, Font, b1, p1) End Sub Protected Sub DrawText(ByVal b1 As Brush, ByVal x As Integer, ByVal y As Integer) If Text.Length = 0 Then Return G.DrawString(Text, Font, b1, x, y) End Sub
#End Region
#Region " DrawImage "
Private DrawImagePoint As Point
Protected Sub DrawImage(ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer) DrawImage(_Image, a, x, y) End Sub Protected Sub DrawImage(ByVal image As Image, ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer) If image Is Nothing Then Return DrawImagePoint = New Point(Width \ 2 - image.Width \ 2, Header \ 2 - image.Height \ 2)
Select Case a Case HorizontalAlignment.Left G.DrawImage(image, x, DrawImagePoint.Y + y, image.Width, image.Height) Case HorizontalAlignment.Center G.DrawImage(image, DrawImagePoint.X + x, DrawImagePoint.Y + y, image.Width, image.Height) Case HorizontalAlignment.Right G.DrawImage(image, Width - image.Width - x, DrawImagePoint.Y + y, image.Width, image.Height) End Select End Sub
Protected Sub DrawImage(ByVal p1 As Point) DrawImage(_Image, p1.X, p1.Y) End Sub Protected Sub DrawImage(ByVal x As Integer, ByVal y As Integer) DrawImage(_Image, x, y) End Sub
Protected Sub DrawImage(ByVal image As Image, ByVal p1 As Point) DrawImage(image, p1.X, p1.Y) End Sub Protected Sub DrawImage(ByVal image As Image, ByVal x As Integer, ByVal y As Integer) If image Is Nothing Then Return G.DrawImage(image, x, y, image.Width, image.Height) End Sub
#End Region
#Region " DrawGradient "
Private DrawGradientBrush As LinearGradientBrush Private DrawGradientRectangle As Rectangle
Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer) DrawGradientRectangle = New Rectangle(x, y, width, height) DrawGradient(blend, DrawGradientRectangle) End Sub Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal angle As Single) DrawGradientRectangle = New Rectangle(x, y, width, height) DrawGradient(blend, DrawGradientRectangle, angle) End Sub
Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal r As Rectangle) DrawGradientBrush = New LinearGradientBrush(r, Color.Empty, Color.Empty, 90.0F) DrawGradientBrush.InterpolationColors = blend G.FillRectangle(DrawGradientBrush, r) End Sub Protected Sub DrawGradient(ByVal blend As ColorBlend, ByVal r As Rectangle, ByVal angle As Single) DrawGradientBrush = New LinearGradientBrush(r, Color.Empty, Color.Empty, angle) DrawGradientBrush.InterpolationColors = blend G.FillRectangle(DrawGradientBrush, r) End Sub
Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer) DrawGradientRectangle = New Rectangle(x, y, width, height) DrawGradient(c1, c2, DrawGradientRectangle) End Sub Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal angle As Single) DrawGradientRectangle = New Rectangle(x, y, width, height) DrawGradient(c1, c2, DrawGradientRectangle, angle) End Sub
Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle) DrawGradientBrush = New LinearGradientBrush(r, c1, c2, 90.0F) G.FillRectangle(DrawGradientBrush, r) End Sub Protected Sub DrawGradient(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle, ByVal angle As Single) DrawGradientBrush = New LinearGradientBrush(r, c1, c2, angle) G.FillRectangle(DrawGradientBrush, r) End Sub
#End Region
#Region " DrawRadial "
Private DrawRadialPath As GraphicsPath Private DrawRadialBrush1 As PathGradientBrush Private DrawRadialBrush2 As LinearGradientBrush Private DrawRadialRectangle As Rectangle
Sub DrawRadial(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer) DrawRadialRectangle = New Rectangle(x, y, width, height) DrawRadial(blend, DrawRadialRectangle, width \ 2, height \ 2) End Sub Sub DrawRadial(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal center As Point) DrawRadialRectangle = New Rectangle(x, y, width, height) DrawRadial(blend, DrawRadialRectangle, center.X, center.Y) End Sub Sub DrawRadial(ByVal blend As ColorBlend, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal cx As Integer, ByVal cy As Integer) DrawRadialRectangle = New Rectangle(x, y, width, height) DrawRadial(blend, DrawRadialRectangle, cx, cy) End Sub
Sub DrawRadial(ByVal blend As ColorBlend, ByVal r As Rectangle) DrawRadial(blend, r, r.Width \ 2, r.Height \ 2) End Sub Sub DrawRadial(ByVal blend As ColorBlend, ByVal r As Rectangle, ByVal center As Point) DrawRadial(blend, r, center.X, center.Y) End Sub Sub DrawRadial(ByVal blend As ColorBlend, ByVal r As Rectangle, ByVal cx As Integer, ByVal cy As Integer) DrawRadialPath.Reset() DrawRadialPath.AddEllipse(r.X, r.Y, r.Width - 1, r.Height - 1)
DrawRadialBrush1 = New PathGradientBrush(DrawRadialPath) DrawRadialBrush1.CenterPoint = New Point(r.X + cx, r.Y + cy) DrawRadialBrush1.InterpolationColors = blend
If G.SmoothingMode = SmoothingMode.AntiAlias Then G.FillEllipse(DrawRadialBrush1, r.X + 1, r.Y + 1, r.Width - 3, r.Height - 3) Else G.FillEllipse(DrawRadialBrush1, r) End If End Sub
Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer) DrawRadialRectangle = New Rectangle(x, y, width, height) DrawRadial(c1, c2, DrawGradientRectangle) End Sub Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal angle As Single) DrawRadialRectangle = New Rectangle(x, y, width, height) DrawRadial(c1, c2, DrawGradientRectangle, angle) End Sub
Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle) DrawRadialBrush2 = New LinearGradientBrush(r, c1, c2, 90.0F) G.FillRectangle(DrawGradientBrush, r) End Sub Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle, ByVal angle As Single) DrawRadialBrush2 = New LinearGradientBrush(r, c1, c2, angle) G.FillEllipse(DrawGradientBrush, r) End Sub
#End Region
#Region " CreateRound "
Private CreateRoundPath As GraphicsPath Private CreateRoundRectangle As Rectangle
Function CreateRound(ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal slope As Integer) As GraphicsPath CreateRoundRectangle = New Rectangle(x, y, width, height) Return CreateRound(CreateRoundRectangle, slope) End Function
Function CreateRound(ByVal r As Rectangle, ByVal slope As Integer) As GraphicsPath CreateRoundPath = New GraphicsPath(FillMode.Winding) CreateRoundPath.AddArc(r.X, r.Y, slope, slope, 180.0F, 90.0F) CreateRoundPath.AddArc(r.Right - slope, r.Y, slope, slope, 270.0F, 90.0F) CreateRoundPath.AddArc(r.Right - slope, r.Bottom - slope, slope, slope, 0.0F, 90.0F) CreateRoundPath.AddArc(r.X, r.Bottom - slope, slope, slope, 90.0F, 90.0F) CreateRoundPath.CloseFigure() Return CreateRoundPath End Function
#End Region
End Class
MustInherit Class ThemeControl154 Inherits Control
InvalidateCustimization() 'Remove? End Sub
Protected NotOverridable Overrides Sub OnHandleCreated(ByVal e As EventArgs) InvalidateCustimization() ColorHook()
Private DoneCreation As Boolean Protected NotOverridable Overrides Sub OnParentChanged(ByVal e As EventArgs) If Parent IsNot Nothing Then OnCreation() DoneCreation = True InvalidateTimer() End If
MyBase.OnParentChanged(e) End Sub
#End Region
If _Transparent Then PaintHook() e.Graphics.DrawImage(B, 0, 0) Else G = e.Graphics PaintHook() End If End Sub
Protected NotOverridable Overrides Sub OnSizeChanged(ByVal e As EventArgs) If _Transparent Then InvalidateBitmap() End If
Invalidate() MyBase.OnSizeChanged(e) End Sub
#End Region
Private InPosition As Boolean Protected Overrides Sub OnMouseEnter(ByVal e As EventArgs) InPosition = True SetState(MouseState.Over) MyBase.OnMouseEnter(e) End Sub
Protected Overrides Sub OnMouseUp(ByVal e As MouseEventArgs) If InPosition Then SetState(MouseState.Over) MyBase.OnMouseUp(e) End Sub
Protected Overrides Sub OnMouseDown(ByVal e As MouseEventArgs) If e.Button = Windows.Forms.MouseButtons.Left Then SetState(MouseState.Down) MyBase.OnMouseDown(e) End Sub
Protected Overrides Sub OnMouseLeave(ByVal e As EventArgs) InPosition = False SetState(MouseState.None) MyBase.OnMouseLeave(e) End Sub
#End Region
Overrides Property Text() As String Get Return MyBase.Text End Get Set(ByVal value As String) MyBase.Text = value Invalidate() End Set End Property Overrides Property Font() As Font Get Return MyBase.Font End Get Set(ByVal value As Font) MyBase.Font = value Invalidate() End Set End Property
Private _BackColor As Boolean <Category("Misc" )> Overrides Property BackColor() As Color Get Return MyBase.BackColor End Get Set(ByVal value As Color) If Not IsHandleCreated AndAlso value = Color.Transparent Then _BackColor = True Return End If
MyBase.BackColor = value If Parent IsNot Nothing Then ColorHook() End Set End Property
#End Region
Private _Image As Image Property Image() As Image Get Return _Image End Get Set(ByVal value As Image) If value Is Nothing Then _ImageSize = Size.Empty Else _ImageSize = value.Size End If
Private _Transparent As Boolean Property Transparent() As Boolean Get Return _Transparent End Get Set(ByVal value As Boolean) _Transparent = value If Not IsHandleCreated Then Return
If value Then InvalidateBitmap() Else B = Nothing Invalidate() End Set End Property
#End Region
#End Region
Private Sub InvalidateBitmap() If Width = 0 OrElse Height = 0 Then Return B = New Bitmap(Width, Height, PixelFormat.Format32bppPArgb) G = Graphics.FromImage(B) End Sub
If _IsAnimated Then AddAnimationCallback(AddressOf DoAnimation) Else RemoveAnimationCallback(AddressOf DoAnimation) End If End Sub #End Region
#End Region
#Region " Offset "
#End Region
#Region " Center "
#End Region
#Region " Measure "
Private MeasureBitmap As Bitmap Private MeasureGraphics As Graphics 'TODO: Potential issues during multi-threading.
Protected Function Measure() As Size Return MeasureGraphics.MeasureString(Text, Font, Width).ToSize End Function Protected Function Measure(ByVal text As String) As Size Return MeasureGraphics.MeasureString(text, Font, Width).ToSize End Function
#End Region
#End Region
#End Region
#End Region
#End Region
Protected Sub DrawImage(ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer) DrawImage(_Image, a, x, y) End Sub Protected Sub DrawImage(ByVal image As Image, ByVal a As HorizontalAlignment, ByVal x As Integer, ByVal y As Integer) If image Is Nothing Then Return DrawImagePoint = Center(image.Size)
#End Region
#End Region
Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer) DrawRadialRectangle = New Rectangle(x, y, width, height) DrawRadial(c1, c2, DrawRadialRectangle) End Sub Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal x As Integer, ByVal y As Integer, ByVal width As Integer, ByVal height As Integer, ByVal angle As Single) DrawRadialRectangle = New Rectangle(x, y, width, height) DrawRadial(c1, c2, DrawRadialRectangle, angle) End Sub
Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle) DrawRadialBrush2 = New LinearGradientBrush(r, c1, c2, 90.0F) G.FillEllipse(DrawRadialBrush2, r) End Sub Protected Sub DrawRadial(ByVal c1 As Color, ByVal c2 As Color, ByVal r As Rectangle, ByVal angle As Single) DrawRadialBrush2 = New LinearGradientBrush(r, c1, c2, angle) G.FillEllipse(DrawRadialBrush2, r) End Sub
#End Region
Marsh Posté le 03-07-2016 à 05:26:22
'Site: *********
'[DATE]
'[VERSION]
'[INFO]
'[DATE]
'Created: 7/14/2013
'Changed: 7/26/2013
'[VERSION]
'Version: 1.1
'[CREDITS]
#Region "Imports"
#End Region
#Region "THEMEBASE"
Sub New()
End Sub
ColorHook()
End Sub
End If
End If
End If
OnCreation()
DoneCreation = True
InvalidateTimer()
End Sub
#End Region
OnAnimation()
End Sub
PaintHook()
Else
G = e.Graphics
PaintHook()
End If
End Sub
End Sub
End If
HasShown = True
End Sub
End If
InvalidateBitmap()
Invalidate()
End Sub
End Sub
#End Region
State = current
Invalidate()
End Sub
End If
End Sub
End Sub
End Sub
MyBase.OnMouseUp(e)
End Sub
Previous = 0
End If
End If
End Sub
Capture = False
Capture = False
End If
End If
End Sub
MyBase.WndProc(m)
If IsParentMdi Then
Else
End If
End If
End Sub
If B1 Then Return 1
If B2 Then Return 2
If B3 Then Return 3
If B4 Then Return 6
Return 0
End Function
Previous = Current
Case 0
Case 1, 2
Case 3, 6
Case 4, 8
Case 5, 7
End Select
End Sub
Next
End Sub
End Sub
#End Region
Get
Return MyBase.Dock
End Get
MyBase.Dock = value
End Set
End Property
<Category("Misc" )>
Get
End Get
_BackColor = True
Return
End If
ColorHook()
End If
End Set
End Property
Get
End Get
End Set
End Property
Get
End Get
End Set
End Property
Get
Return MyBase.Text
End Get
MyBase.Text = value
Invalidate()
End Set
End Property
Get
Return MyBase.Font
End Get
MyBase.Font = value
Invalidate()
End Set
End Property
Get
Return Color.Empty
End Get
End Set
End Property
Get
Return Nothing
End Get
End Set
End Property
Get
End Get
End Set
End Property
#End Region
Get
Return _SmartBounds
End Get
End Set
End Property
Get
Return _Movable
End Get
_Movable = value
End Set
End Property
Get
Return _Sizable
End Get
_Sizable = value
End Set
End Property
Get
End Get
ColorHook()
End If
End Set
End Property
Get
End Get
Movable = False
Sizable = False
End If
End If
End Set
End Property
Get
End Get
End If
End Set
End Property
Get
Return _NoRounding
End Get
_NoRounding = v
Invalidate()
End Set
End Property
Get
Return _Image
End Get
_Image = value
Invalidate()
End Set
End Property
Get
While E.MoveNext
End While
Return T.ToArray
End Get
Next
ColorHook()
Invalidate()
End Set
End Property
Get
End Get
Dim Data As Byte()
Try
Next
Catch
Return
End Try
Colors = Items
ColorHook()
Invalidate()
End Set
End Property
Get
Return _Transparent
End Get
End If
InvalidateBitmap()
Invalidate()
End Set
End Property
#End Region
Get
Return _ImageSize
End Get
End Property
Get
End Get
End Property
Get
End Get
End Property
Get
Return _LockWidth
End Get
_LockWidth = value
End Set
End Property
Get
Return _LockHeight
End Get
_LockHeight = value
End Set
End Property
Get
Return _Header
End Get
_Header = v
Invalidate()
End If
End Set
End Property
Get
Return _ControlMode
End Get
_ControlMode = v
InvalidateBitmap()
Invalidate()
End Set
End Property
Get
Return _IsAnimated
End Get
_IsAnimated = value
InvalidateTimer()
End Set
End Property
#End Region
End Function
End Function
End Function
Return Items(name)
End Function
End Sub
End Sub
End Sub
End Sub
Else
G = Nothing
B = Nothing
End If
End Sub
Next
M.Close()
End Sub
If _IsAnimated Then
Else
End If
End Sub
#End Region
End Sub
End Sub
#End Region
#Region " Offset "
End Function
End Function
End Function
#End Region
#Region " Center "
Return CenterReturn
End Function
Return CenterReturn
End Function
End Function
End Function
End Function
End Function
Return CenterReturn
End Function
#End Region
#Region " Measure "
End SyncLock
End Function
End SyncLock
End Function
#End Region
Else
End If
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
Else
End If
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Sub
DrawTextSize = Measure(text)
DrawTextPoint = New Point(Width \ 2 - DrawTextSize.Width \ 2, Header \ 2 - DrawTextSize.Height \ 2)
Select Case a
End Select
End Sub
End Sub
End Sub
#End Region
End Sub
Select Case a
End Select
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
Else
End If
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Function
End Function
#End Region
End Class
Inherits Control
Sub New()
End Sub
ColorHook()
End Sub
OnCreation()
DoneCreation = True
InvalidateTimer()
End If
End Sub
#End Region
OnAnimation()
End Sub
PaintHook()
Else
G = e.Graphics
PaintHook()
End If
End Sub
End Sub
InvalidateBitmap()
End If
Invalidate()
End Sub
End Sub
#End Region
InPosition = True
End Sub
MyBase.OnMouseUp(e)
End Sub
End Sub
InPosition = False
End Sub
End Sub
State = current
Invalidate()
End Sub
#End Region
Get
Return Color.Empty
End Get
End Set
End Property
Get
Return Nothing
End Get
End Set
End Property
Get
End Get
End Set
End Property
Get
Return MyBase.Text
End Get
MyBase.Text = value
Invalidate()
End Set
End Property
Get
Return MyBase.Font
End Get
MyBase.Font = value
Invalidate()
End Set
End Property
<Category("Misc" )>
Get
End Get
_BackColor = True
Return
End If
End Set
End Property
#End Region
Get
Return _NoRounding
End Get
_NoRounding = v
Invalidate()
End Set
End Property
Get
Return _Image
End Get
Else
End If
_Image = value
Invalidate()
End Set
End Property
Get
Return _Transparent
End Get
End If
Invalidate()
End Set
End Property
Get
While E.MoveNext
End While
Return T.ToArray
End Get
Next
ColorHook()
Invalidate()
End Set
End Property
Get
End Get
Dim Data As Byte()
Try
Next
Catch
Return
End Try
Colors = Items
ColorHook()
Invalidate()
End Set
End Property
#End Region
Get
Return _ImageSize
End Get
End Property
Get
Return _LockWidth
End Get
_LockWidth = value
End Set
End Property
Get
Return _LockHeight
End Get
_LockHeight = value
End Set
End Property
Get
Return _IsAnimated
End Get
_IsAnimated = value
InvalidateTimer()
End Set
End Property
#End Region
End Function
End Function
End Function
Return Items(name)
End Function
End Sub
End Sub
End Sub
End Sub
End Sub
Next
M.Close()
End Sub
If _IsAnimated Then
Else
End If
End Sub
#End Region
End Sub
End Sub
#End Region
#Region " Offset "
End Function
End Function
End Function
#End Region
#Region " Center "
Return CenterReturn
End Function
Return CenterReturn
End Function
End Function
End Function
End Function
End Function
Return CenterReturn
End Function
#End Region
#Region " Measure "
End Function
End Function
#End Region
Else
End If
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
Else
End If
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Sub
DrawTextPoint = Center(DrawTextSize)
Select Case a
End Select
End Sub
End Sub
End Sub
#End Region
End Sub
Select Case a
End Select
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Sub
End Sub
End Sub
End Sub
End Sub
Else
End If
End Sub
End Sub
End Sub
End Sub
End Sub
#End Region
End Function
