Nextview EPG comment lui programmer une exportation automatique
Nextview EPG comment lui programmer une exportation automatique - XML/XSL - Programmation
Marsh Posté le 19-03-2005 à 11:46:57
la programation je connais pas je ne sais pas le langage que ca peut etre
je voudrais lors du lancement de ce soft qu'il m'export  un fichier au format XML dans un dossier
il me l'export mais je dois le faire en manuel voir:(les deux dernieres lignes)
exemple du fichier de configue:
# Nextview EPG configuration file
# This file is automatically generated - do not edit
# Written at: Wed Mar 16 11:19:41 2005
[VERSION]
nxtvepg_version = 0x207C6
nxtvepg_version_str = 2.8.0pre4
rc_compat_version = 0x207C2
rc_timestamp = 1110968381
[ACQUISITION]
prov_freqs =
acq_mode_cnis = 12036
acq_mode = external
epgscan_opt_ftable = 0
[DATABASE]
piexpire_cutoff = 240
prov_selection = 12036 255
prov_merge_cnis = 12036
prov_merge_netwops =
prov_merge_cftitle =
prov_merge_cfdescr =
prov_merge_cfthemes =
prov_merge_cfseries =
prov_merge_cfsortcrit =
prov_merge_cfeditorial =
prov_merge_cfparental =
prov_merge_cfsound =
prov_merge_cfformat =
prov_merge_cfrepeat =
prov_merge_cfsubt =
prov_merge_cfmisc =
prov_merge_cfvps =
[CLIENT SERVER]
netacq_enable = 0
netacqcf_remctl = 0
netacqcf_do_tcp_ip = 0
netacqcf_host = localhost
netacqcf_port = 7658
netacqcf_ip =
netacqcf_logname =
netacqcf_max_conn = 10
netacqcf_fileloglev = 0
netacqcf_sysloglev = 3
[TV CARDS]
hwcf_cardidx = 0
hwcf_input = 0
hwcf_acq_prio = 0
hwcf_slicer_type = 0
hwcf_wdm_stop = 0
tvcardcf_count = 1
tvcardcf_0 = 278791022 39 3 1
tvcardcf_1 =
tvcardcf_2 =
tvcardcf_3 =
tvcardcf_4 =
tvcardcf_5 =
tvcardcf_6 =
tvcardcf_7 =
[TV APP INTERACTION]
set wintvapp_path {C:/PROGRAM FILES/K!TV/CHANNEL}
set wintvapp_idx 2
set xawtvcf {tunetv 1 follow 1 dopop 1 poptype 0 duration 7}
set wintvcf {shm 1 tunetv 1 follow 1 dopop 1}
set ctxmencf_wintv_vcr 0
[NETWORKS]
set cfnetwops(0x00FF) {{0x2F04 0x2F0A 0x2F05 0x2F06 0x2F01 0x2F03 0x2F02} {}}
set cfnetwops(0x2F04) {{0x2F01 0x2F02 0x2F03 0x2F04 0x2F0A 0x2F06 0x2F05} {}}
array set cfnettimes {}
set cfnetjoin {}
[DATABASE EXPORT]
set dumpdb_filename C:/XMLTV/prog.txt
set dumpdb_pi 1
set dumpdb_xi 1
set dumpdb_ai 1
set dumpdb_ni 1
set dumpdb_oi 1
set dumpdb_mi 1
set dumpdb_li 1
set dumpdb_ti 1
set dumptabs_filename {}
set dumptabs pi
set dumphtml_filename {}
set dumphtml_file_append 0
set dumphtml_file_overwrite 0
set dumphtml_sel 1
set dumphtml_sel_count 25
set dumphtml_type 3
set dumphtml_hyperlinks 1
set dumphtml_text_fmt 1
set dumphtml_use_colsel 0
set dumphtml_colsel {}
set dumpxml_filename C:/XMLTV/Program.xml
set dumpxml_format 0
Marsh Posté le 19-03-2005 à 20:00:07
merci!  dite loi au moin le langage que c'est
