XHTML (Dublin Core) + XSLT -> RDF
XHTML (Dublin Core) + XSLT -> RDF - XML/XSL - Programmation
Marsh Posté le 08-08-2008 à 22:15:37
           j'aimerais savoir comment transformer un document XHTML annoté en "Dublin Core" (RDF) en utilisant XSLT. J'ai presque trouvé la solution mais j'éprouve encore quelques difficultés. Voici mon fichier xhtml source:
  1. <?xml version="1.0" encoding="ISO-8859-1"?>
  2. <?xml-stylesheet type="text/xsl" href="Test.xslt"?>
  3. <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
  4. "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
  5. <html xmlns="http://www.w3.org/1999/xhtml">
  6. <head>
  7. <link rel="schema.DC" href="http://purl.org/dc/elements/1.1/" />
  8. <meta name="DC.title" content="le titre de mon document" />
  9. <meta name="DC.description" content="http://mondocument.org" />
  10. <title>Un petit document</title>
  11. </head>
  12. <body>
  13. <p>Test</p>
  14. </body>
  15. </html>
Et ceci est mon fichier XSLT:
  2. <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:xhtml="http://www.w3.org/1999/xhtml">
  3. <xsl:output method="html" version="1.0" encoding="ISO-8859-1" indent="yes"/>
  4. <xsl:template match="xhtml:link">
  5. </xsl:template>
  6. <xsl:template match="xhtml:link">
  7. <html>
  8. <body><pre>
  9. <?xml version="1.0" encoding="ISO-8859-1" ?>
  10. <rdf:RDF
  11. xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" >
  12. <xsl:if test="substring-before(@rel,'.') = 'schema' ">
  13. <xsl:for-each select="../xhtml:meta[substring-before(@name,'.') = substring-after(current()/@rel,'.')]">
  14. <rdf:Description rdf:about="http://mondocument.org">
  15. <<xsl:value-of select="substring-after(./@name,'.')"/>
  16. xmlns="<xsl:value-of select="../xhtml:link[substring-after(@rel,'.')=substring-before(current()/@name,'.')]/@href"/>">
  17. <xsl:value-of select="@content"/>
  18. </<xsl:value-of select="substring-after(./@name,'.')"/> >
  19. </rdf:Description>
  20. </xsl:for-each>
  21. </xsl:if>
  22. </rdf:RDF>
  23. </pre></body>
  24. </html>
  25. </xsl:template>
  26. </xsl:stylesheet>
Et mon problème est que j'obtiens ceci:
  1. <?xml version="1.0" encoding="ISO-8859-1" ?>
  2. <rdf:RDF
  3. xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" >
  5. <title
  6. xmlns="http://purl.org/dc/elements/1.1/">
  7. le titre de mon document
  8. </title >
  10. <rdf:Description rdf:about="http://mondocument.org">
  11. <description
  12. xmlns="http://purl.org/dc/elements/1.1/">
  13. http://mondocument.org
  14. </description >
  15. </rdf:Description>
  16. </rdf:RDF>
au lieu de ceci:
  2. <rdf:RDF
  5. <title
  8. </title >
  10. </rdf:RDF>
Comme vous pouvez le voir, j'obtiens à cause de mon "for-each" un double. Alors est-ce que quelqu'un a déjà rencontré ce type de problème et qu'est-ce qu'il a fait pour le régler?  :??:
Toute aide sera vraiment appréciée!
EmperorCadavre
Marsh Posté le 11-08-2008 à 11:35:55
Tu passes deux fois dans le for-each, donc c'est normal qu'il te produise deux résultats...
Marsh Posté le 11-08-2008 à 18:43:16
Salut, effectivement mon for-each, comme je l'avais mentionné plus tôt, était mon problème. Mais j'ai finalement trouvé une solution à mon problème. Même si, selon moi, elle peut paraitre comme une forme de "patchage". Mais au moins elle donne le résultat que je recherchais. Merci quand même de ton aide!
