probleme de fxp (transfert entre serveur ftp)
probleme de fxp (transfert entre serveur ftp) - Windows & Software
Marsh Posté le 24-09-2003 à 20:54:01
j ai installer BFTP sur mon PC
il marche bien un pote peux uploader sans souci
mais il voudrais faire du fxp c est a dire un transfert de serveur ftp a serveur ftp
et la ca marche pas je pige pas pquoi
y a une option dans mon serveur qui interdit le fxp mais elle est decocher
vla les logs :
(000007) 24/09/2003 20:32:55 - (not logged in) (XXX.XXX.XXX.XXX) > connected to ip : 82.65.254.22
(000007) 24/09/2003 20:32:55 - (not logged in) (XXX.XXX.XXX.XXX) > sending welcome message.
(000007) 24/09/2003 20:32:55 - (not logged in) (XXX.XXX.XXX.XXX) > 220 Belgarion.homelinux.net
(000007) 24/09/2003 20:32:55 - (not logged in) (XXX.XXX.XXX.XXX) > USER RedBaron
(000007) 24/09/2003 20:32:55 - (not logged in) (XXX.XXX.XXX.XXX) > 331 Password required for RedBaron.
(000007) 24/09/2003 20:32:56 - (not logged in) (XXX.XXX.XXX.XXX) > PASS ********
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > logged in.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 230 User redbaron logged in.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > SYST
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 215 UNIX Type: L8
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > REST 100
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 350 REST supported. Ready to resume at byte offset 100.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > REST 0
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 350 REST supported. Ready to resume at byte offset 0.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > CWD /P:/upload/
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > asked to change directory : 'D:\ftproot\ -> P:\upload\' --> Access allowed.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 250 CWD command successful. "/P:/upload" is current directory.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > PWD
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 257 "/P:/upload" is current directory.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > TYPE A
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 200 Type set to A.
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > PASV
(000007) 24/09/2003 20:32:56 - redbaron (XXX.XXX.XXX.XXX) > 227 Entering Passive Mode (82,65,254,22,180,49).
(000007) 24/09/2003 20:32:57 - redbaron (XXX.XXX.XXX.XXX) > LIST
(000007) 24/09/2003 20:32:57 - redbaron (XXX.XXX.XXX.XXX) > 150 Data connection accepted from XXX.XXX.XXX.XXX:4282; transfer starting.
(000007) 24/09/2003 20:32:57 - redbaron (XXX.XXX.XXX.XXX) > 226 Transfer ok
(000007) 24/09/2003 20:32:59 - redbaron (XXX.XXX.XXX.XXX) > SIZE ctr-awts.nfo
(000007) 24/09/2003 20:32:59 - redbaron (XXX.XXX.XXX.XXX) > 550 No such file or directory.
(000007) 24/09/2003 20:33:00 - redbaron (XXX.XXX.XXX.XXX) > PORT 82,65,216,107,19,137
(000007) 24/09/2003 20:33:00 - redbaron (XXX.XXX.XXX.XXX) > 200 Port command successful.
(000007) 24/09/2003 20:33:00 - redbaron (XXX.XXX.XXX.XXX) > STOR ctr-awts.nfo
(000007) 24/09/2003 20:33:00 - redbaron (XXX.XXX.XXX.XXX) > asked to upload 'ctr-awts.nfo' in 'P:\upload\' --> Access allowed.
(000007) 24/09/2003 20:33:00 - redbaron (XXX.XXX.XXX.XXX) > 150 Opening data connection for ctr-awts.nfo.
(000007) 24/09/2003 20:33:21 - redbaron (XXX.XXX.XXX.XXX) > 425 Cannot open data connection (10060).
(000007) 24/09/2003 20:33:58 - redbaron (XXX.XXX.XXX.XXX) > QUIT
(000007) 24/09/2003 20:33:58 - redbaron (XXX.XXX.XXX.XXX) > 221 Bye bye ...
(000007) 24/09/2003 20:33:58 - redbaron (XXX.XXX.XXX.XXX) > disconnected. (00:01:02)
et voila une connexion qui marche
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > logged in.
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > 230 User Belgarion logged in.
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > SYST
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > 215 UNIX Type: L8
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > PWD
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > 257 "/D:/ftproot" is current directory.
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > TYPE A
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > 200 Type set to A.
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > PORT 82,65,254,22,13,162
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > 200 Port command successful.
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > LIST
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > 150 Opening data connection for directory list.
(000009) 24/09/2003 20:40:16 - Belgarion (82.65.254.22) > 226 Transfer ok
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > CWD /D:/ftproot/Upload
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > asked to change directory : 'D:\ftproot\ -> P:\upload\' --> Access allowed.
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > 250 CWD command successful. "/P:/upload" is current directory.
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > TYPE A
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > 200 Type set to A.
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > PORT 82,65,254,22,13,163
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > 200 Port command successful.
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > LIST
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > 150 Opening data connection for directory list.
(000009) 24/09/2003 20:40:17 - Belgarion (82.65.254.22) > 226 Transfer ok
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > TYPE I
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > 200 Type set to I.
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > PORT 82,65,254,22,13,164
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > 200 Port command successful.
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > STOR VIDEOROM.BIN
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > asked to upload 'VIDEOROM.BIN' in 'P:\upload\' --> Access allowed.
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > 150 Opening data connection for VIDEOROM.BIN.
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > started uploading 'VIDEOROM.BIN' in 'P:\upload\'.
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > 226 File received ok.
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > finished uploading 'VIDEOROM.BIN' in 'P:\upload\' -  (00:00:01 - 52,000 KB - 52,000 KBytes/s).
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > TYPE A
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > 200 Type set to A.
(000009) 24/09/2003 20:40:23 - Belgarion (82.65.254.22) > CWD /D:/ftproot/Upload/
