[TOPIKUNIK] Terminators -=Mais ou iriez vous en cas d'infestation?=-
Terminators -=Mais ou iriez vous en cas d'infestation?=- [TOPIKUNIK] - Vie pratique - Discussions
Marsh Posté le 09-08-2009 à 17:56:00
Avec une AI avancée, que les robots essayent de prendre le controle du monde ou iriez vous?
Quelles techniques facon de vivre changeriez vous?
http://www.internationalhero.co.uk/t/t800metal.jpg
http://www.budapestagent.com/blog/t1000/t-1000.jpg
http://yesilvadi.files.wordpress.com/2008/04/terminator3tx.jpg
http://streetknowledge.files.wordpress.com/2009/04/terminator-salvation-concept-2.jpg
http://i25.tinypic.com/sxhok2.jpg
http://www.filmofilia.com/wp-content/uploads/2009/04/terminator_salvation_conceptart_7_m.jpg
http://fc09.deviantart.com/fs14/f/2006/358/7/8/Terminator_hunter_killer_mech_by_flyingdebris.jpg
Terminator Classification
There are five sub-types of Terminators: Hunter-Killers, Early Infiltrators, Modern Infiltrators, Advanced Infiltrators, and Specialist Infiltrators.
Hunter-Killers: Series 001, Series 070, Series 400, Series 500,Series 90.
Early Infiltrators: Series 600, Series 700.
Modern Infiltrators: Series RIP, Series 800, Series 850, Series 888.
Advanced Infiltrators: Series 900, Series 950, Series 1000, Series 1001, Series 1002, Series X.
Specialist Infiltrators: Series I-950, Series TS-300, Class TOK715, Marcus Wright.
Others: Series 1000000, Series Infinity.
Series 001: a large battle unit armed with twin-linked miniguns.
Series 070: a tall and basic Terminator model designed as a basic foot soldier.
Series 090: the most basic terminator model and with a massive production.
Series 400: a multi-purpose unit designed for close-quarters combat.
Series 500: the first true Terminator and the most successful machine of its time.
Series 600: the first infiltrator model that possesses a rubber skin sheath.
Series 700: a more compact variant of the previous model with a more detailed rubber sheath.
Marcus Wright: an experimental infiltrator created to aid in the perfection of the T-800s.
Series RIP: a prototype of the T-800 series and the first Model 101 Terminator.
Series 800: a breakthrough Terminator that uses organic covering for superior infiltration.
Series 850: a variant of the previous model that is hardened against plasma-based attacks.
Series 888: another variant that is faster, stronger, and more resilient that the T-800.
Series 900: a hyper-alloy armored Terminator designed to eliminate other machines.
Series 950: a more advanced variant of the previous model with a superior endoskeleton.
Series 1000: a poly-mimetic Terminator capable of altering its form and appearance.
Series 1001: a variant of the previous model that possesses superior interpersonal skills.
Series 1002: another variant of the standard T-1000 that is more adaptive in combat.
Series 1000000: a larger poly-alloy construct created to guard the Skynet Core.
Series X: a hyper-advanced endoskeleton that possesses poly-alloy and onboard weaponry.
Series I-950: a cybernetically enhanced human designed to be the ultimate infiltrator.
Series TS-300: a ceramic Terminator designed to replace specific individuals.
Class TOK715: a Terminator created specifically to gain John Connor's trust.
Series Infinity: a multi-phasic machine armed with an onboard TDE device.
Marsh Posté le 09-08-2009 à 17:56:12
idées..
Capturer un T-800, le reprogrammer pour aider a sa protection
PROS: bonne protection en général
CONS: pas efficace contre plus gros terminators, le capturer..
Repartir dans le passé
PROS: possibilité de changer les choses
CONS: trouver la technologie, etre téléporté au bon endroit au bon moment, trouver des vetements etc.
Message édité par slowboy le 11-08-2009 à 16:19:10
Marsh Posté le 09-08-2009 à 17:56:20
réservé
Marsh Posté le 09-08-2009 à 19:46:47
j'ai envie de dire "in before the lock" vu la similitude avec le topic zombies...
Mais bon, pourquoi pas :D
"Vous avez beau travailler dur, devenir intelligent, on se rappellera toujours de vous pour la mauvaise raison."
Marsh Posté le 09-08-2009 à 20:29:34
En tous cas, je dirais qu'on a pas à se soucier du Harvester qu'on voit dans Terminator Salvation car dans la réalité de l'univers Terminator, ce robot géant n'existerait pas. Il n'est qu'une tentative éhontée de copier Transformers. :o
Michael Bay restera toujours le maître des robots géants ! Et non, contrairement à ce que disent les mauvaises langues, les Transformers ne font pas plus plastique que les Terminator.
Et pour combattre des Terminator, le mieux est la ville où il est plus facile de livrer une guérilla. Si T4 se passe dans le désert, c'est uniquement pour faciliter le tournage et les explosions. :D
edit : un Harvester
http://hfr-rehost.net/photos3.pix.ie/90/F8/90F8A816FF5241D48CFCCF1DB2661D4D-500.jpg
Message édité par chiesse le 09-08-2009 à 20:30:22
"Comme disait l'autre con, le 21ème siècle sera à chier ou ne sera pas" Groland
Marsh Posté le 09-08-2009 à 20:31:22
Y'a pas déjà eu un topic sur ça ?
Sinon dans une montagne d'une île déserte sans ressource intéressante pour les cyborg ... compliqué quoi :D
[VDS] Steam Controller comme neuf, 35€ fdpin.
Marsh Posté le 09-08-2009 à 20:32:22
yo_play a écrit :
Spa pareil. Les zombies sont lents, et sans défense. Les robots, ça va être une autre très grosse paire de manches. :o
 [:o_non] on a Joce
Marsh Posté le 09-08-2009 à 20:40:40
et apres on va avoir quoi? infestation d aliens? de predators?....
JE VOUS EMMERDE TOUS BANDE DE CONS! Connard de motos!
Marsh Posté le 09-08-2009 à 20:41:46
De jovalise  :o
[:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise][:jovalise]
des gestes simples et ponctués, par quelques points presque importants, la précision coordonnée, d'une île déserte, des plans secrets, d'un architecte, à la retraite, passionné par son métier, refaire le monde, à son idée, tracer des routes, les emprunter
Marsh Posté le 09-08-2009 à 20:41:47
une pluie de pierre noir la mèr :o
Marsh Posté le 09-08-2009 à 20:44:34
Africains, ressortissants albanais, ouvriers roumains...
Marsh Posté le 09-08-2009 à 20:52:47
in before the lock !
Marsh Posté le 09-08-2009 à 22:13:36
Il aurait fallu mettre des photos en face des séries parce que comme ça, difficile à voir.
Sinon, je ne pense pas que l'on puisse survivre à des terminators. Aucune de nos armes ne fait le poids.
en même temps, en théorie aucune de nos technologies ne permet de construire un terminator...
note en passant : on est prié d'éviter de comparer la saga des terminators aux films vraiment merdiques style transformers, merci.  [:dao]
edit : ou alors allons y carrément au plus profond de la fosse et comparons aussi avec les Gi joe au hasard
edit 2 : c'est rigolo d'avoir mis ce sujet en "vie pratique"  [:afrojojo]
Message édité par Absolument Fabuleux le 09-08-2009 à 22:18:38
Marsh Posté le 09-08-2009 à 23:09:18
Marsh Posté le 09-08-2009 à 23:44:32
J'irai dans une fonderie et je planterai ma tante entre une cuve de métal en fusion et un monte charge.
Marsh Posté le 10-08-2009 à 00:03:35
On risque rien, Shwarzy et de notre coté [:talladega:2]
 [:talladega:3]
Celui qui parle beaucoup se trompe tout autant.
Marsh Posté le 10-08-2009 à 00:12:25
Je reprogramme un modèle TOK-715 et je m'en vais très loin avec. Peu importe l'endroit, elle est censée être plus intelligente que moi donc c'est elle qui me guidera :o
http://www.izipik.com/images/200908/10/kbk1l4ilxv17ly0xae-tok75_2.jpg http://www.izipik.com/images/200908/10/mber3hmftanfmasm77-tok75_1.jpg
Spoiler :
Vous la voyez bien là? :o
Message édité par Sgt Sharp le 10-08-2009 à 00:19:48
Marsh Posté le 10-08-2009 à 00:17:38
humm drapal
disons que on peut aussi citer les cylons
rien ne vaut une guérilla cachée dans les montagnes ou dans les buildings des villes
Après à combattre c'est pas simple entre les détecteurs de chaleur et l'éveil permanent ("I never sleep" )
Disons que ca serait vraiment pas drôle à vivre donc l'idée de trouver une autre planète pour se cacher est assez bonne je pense ;)
PS : les robots motos c'est la seule chose que j'ai adoré dans T4 :love:
Message édité par C501 le 10-08-2009 à 00:20:43
Sleep is overrated...
Marsh Posté le 10-08-2009 à 00:37:44
http://www.izipik.com/images/20090 [...] ok75_2.jpg http://www.izipik.com/images/20090 [...] ok75_1.jpg
Spoiler :
j'me laisse guider sans soucis :o
http://blog.hdscreencaps.com/wp-content/uploads/blog.hdscreencaps.com/2009/03/summer_glau_0002.jpg
Слава Україні  Feedback "l'habitat urbain satisfait toute
Marsh Posté le 10-08-2009 à 00:40:09
je l'attendais celle là :love:
dommage que la scène où john vérifie sa pile n'est pas prise de face :love:
Marsh Posté le 10-08-2009 à 00:40:35
dommage qu'il y ait pas de saison3 surtout :/
Marsh Posté le 10-08-2009 à 01:05:16
T'y vas caches là quand même.... :o
Bon, puisque tu as ouvert la voie....
http://www.izipik.com/images/200908/10/kq4vz1n8a7d3kiq22e-snapshot20090810005557.jpg
Spoiler :
J'avoue ca rend moins bien que le rose bonbon et la culotte rouge bordeau :o
Mais faudrait pas croire que y'a que ça dans la série non plus... :D
Marsh Posté le 10-08-2009 à 13:33:08
l'idée de capturer un terminator et le re-programmer est une excellente idée, le challenge encore la est le processus..
Je vais le mettre au 1er post
l'idée serait de mettre des stratégies sur chaque type de terminator comment le détruire (T-800, moto, T-X..), je suis sur que ce topic sera d'utilité public tout comme au cas ou il y aurai un Z-day! :D
Marsh Posté le 10-08-2009 à 16:59:51
Si ce soir c'est pas lock, je crée un topik infestation Gremlins et un topik infestation Vampires...faut pas déconner là :o
Et toi, comment manies-tu ton manche ? - Dernière fréquence modulée
Marsh Posté le 10-08-2009 à 17:06:00
prenez vous vraiment du plaisir a essayer de pourrir les topics des autres?  :fou:
probleme d'ego ca.. si t'aimes pas le sujet force pas ton opinion sur tout le monde, post pas et laisse les autres qui aime ca le faire..
tous les gouts sont dans la nature la :o
serieux c est fatiguant ces gens controlant la  :fou:
Marsh Posté le 10-08-2009 à 17:07:28
Eh laisse discuter  [:azylum]
Ce que je vois c'est que tout le monde sur le topic Z-Day a trouvé ça tellement pitoyable que je suis le seul à être venu. Tu devrais m'applaudir plutôt que de me blâmer :o
Marsh Posté le 10-08-2009 à 17:28:10
Hmm autant Summer Glau a un joli facès mais en soutif ça ne déborde pas exactement de partout :o
Marsh Posté le 10-08-2009 à 17:36:25
+1 (sauf que j'aime pas son faciès)
Et sinon moi j'irais dans une grotte. Au moins, les Terminator auront du mal à se déplacer et à communiquer entre eux, s'ils le peuvent. Bref, peinard. Bien sûr, il faut prévoir un réseau souterrain avec plusieurs issues à la surface. Faudrait pas se faire piéger à l'intérieur... :D
Marsh Posté le 10-08-2009 à 17:59:48
dans une scene du 4 qd l hybride arrive a la muraille il se fait scanner par la sentinelle, et apres se fait donner l acces..
un peu comme les zombies ou tu peux te recouvrir de chair puante pour qu ils te pensent des leurs, on pourrait prendre un oeil de terminator, mettre sur une petite batterie comme ca de loin du te fais scanner pi ils te laissent tranquille, apres tu viens avec du C4 et t en met partout pi boum? ca marcherait sur leurs usines
maintenant si t as une armée devant toi je sais pas comment..
Marsh Posté le 10-08-2009 à 18:05:26
[:spaydar]
Marsh Posté le 10-08-2009 à 19:03:55
Tu fais comme dans le film tu trouve le super ordinateur qui commande tout et tu le débranche
Marsh Posté le 10-08-2009 à 19:04:12
et pourquoi pas ? si ça évite de revoir pour la troisième fois les mêmes stratégies sur le topic zombies [:castor66]
Marsh Posté le 10-08-2009 à 19:18:48
Je sens que ce topic va pas durer longtemps (une raison qu'il ne soit pas crée dans la sous cat société ? :whistle: )
Si les terminators débarquent, j'abandonne  [:hahaguy] Encore avec les zombies, c'est possible de tenter une fuite mais là, si on tombe contre un terminator, à moins d'avoir un jacuzzi de lave dans sa poche, je vois pas comment on peut s'enfuir :o
PSN : XprtZ - BattleTag : XprtZ#2257 - 3DS : 2492-4109-3060
Marsh Posté le 10-08-2009 à 19:22:00
:dtc:
Marsh Posté le 10-08-2009 à 19:29:51
Allez j'apporte une réponse sérieuse :o
il faut en effet voir selon les robots un moyen de se réunir avant de les combattre :
les catacombes ou les grottes semblent un bon endroit pour se cacher, histoire de rendre l'accès très difficile et de rester hors des caméras thermiques
Ensuite il faut survivre mais bon c'est compliqué :
- un robot moto allez dans un batiment (escaliers)
- un gros robot choisissez un endroit bien étroit
- un robot volant sous un toît
etc
les villes semblent le meilleur endroit pour se cacher
Pour les abattre, les reprogrammer ca reste le meilleur moyen. Si on l'a fait dans un sens on peut le faire dans l'autre théoriquement. Ensuite je pense que avant que ca soit trop tard, l'emploi de bombes à impulsions électromagnétiques peuvent pas mal régler le problème : ça les grille et nous ca nous fait rien \o/
PS : par contre je me garde une cameron reprogrammée pour mes besoins personnels :o
Message édité par C501 le 10-08-2009 à 19:32:59
Marsh Posté le 10-08-2009 à 19:33:21
mwoais, je préfèrerais reprogrammer Christana Loken personnellement ( terminator 3 )
http://www.univers-l.com/images/personnalite_kristanna_loken.jpg
edit : et comme ça aussi  [:draculax]
Spoiler :
http://i479.photobucket.com/albums/rr152/srivishnu/NUDU%20BABES/Kristanna_Loken_in_Terminator_3_Ris.jpg
Message édité par Absolument Fabuleux le 10-08-2009 à 19:36:48
Marsh Posté le 10-08-2009 à 19:33:53
Ou les deux :o
Marsh Posté le 10-08-2009 à 19:34:03
Spoiler :
ah la la l'erreur XXL dans la série où elle a tour à tour les yeux bleus puis rouges :o
Marsh Posté le 10-08-2009 à 19:38:02
Certains ont beau dire, mais ce n'est pas sur le topic zombies que l'on peut fantasmer  :o
 :D
Marsh Posté le 10-08-2009 à 19:47:19
haha une cannon en T1000 ca doit etre interessant :D
