[Topic Unique] Thermaltake Element S,G,T et V MAJ 05/11/09
Thermaltake Element S,G,T et V MAJ 05/11/09 [Topic Unique] - Boitier - Hardware
Marsh Posté le 17-02-2009 à 13:35:21
Le Thermaltake Element S est un boîtier pour les personnes cherchant une très bonne ventilation type Storm Sniper, un grand espace de stockage amortissant les vibrations  grâce à ses 7 slots HDD amortissant les vibrations ainsi que d'un look très classe.
Caractéristiques du Element S
Features:
- Anti-vibration & noise reduction material on side panel
- Stealth Black Interior
- Massive Storage Capability with 7 x 3.5" and 2 x 2.5" HDD bays
- Direction-free HDD cage
- Excellent thermal performance with optimal air flow
- Folding edge design to strengthen structure and prevent cutting
Specs:
Case Type: Mid Tower
Material: SECC
Front Bezel Material: Plastic
Color: Black
Side Panel: Solid
Motherboard Support: Micro ATX, Standard ATX
Motherboard Tray: No
5.25" Drive Bay: 3
Ext. 3.5" Drive Bay: 0
Int. 3.5" Drive Bay: 7
Expansion Slots: 7
Front I/O Ports: USB 2.0 x 2, eSATA & HD Audio ports
Cooling System: - Front (intake) : 120 x 120 x 25 mm TurboFan, 1300 rpm, 17 dBA : 120 x 120 x 25 mm (optional) - Rear (exhaust) : 140 x 140 x 25 mm TurboFan, 1000 rpm, 16 dBA - Top(exhaust) : 230 x 230 x 20 mm red LED fan, 800 rpm, 15 dBA - VGA (exhaust) : Two 60 x 60 mm fan(optional)
Liquid Cooling Capable: No
Liquid Cooling Embedded: No
Power Supply Supported: Standard ATX PSII(optional)
Power Supply Included: No
Dimension (H*W*D): 21.3 x 9.1 x 19.9 in / 505 x 230 x 540 mm
Net Weight: 19.49 lbs / 8.84 kg
Galerie photo
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01063.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01064.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01065.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01066.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01068.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01069.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01070.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01071.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01072.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01073.jpg
Message édité par Fssabbagh le 05-11-2009 à 23:39:46
Messatsu !
Marsh Posté le 17-02-2009 à 13:37:15
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01074.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01075.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01076.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01091.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01092.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01077.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01078.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01079.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01080.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01081.jpg
Messatsu !
Marsh Posté le 17-02-2009 à 13:41:23
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01082.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01083.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01084.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01085.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01086.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01088.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01089.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01090.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01087.jpg
Tests
Hardware Secrets : http://www.hardwaresecrets.com/article/690
HiTechLegion : http://www.hitechlegion.com/review [...] ttelements
ThinkComputer :http://www.thinkcomputers.org/inde [...] ews&id=929
3d gameman en vidéo : http://www.dailymotion.com/Fssabbagh/video/141481554
tests Français :
http://www.cowcotland.com/articles [...] ltake.html
Message édité par Fssabbagh le 30-03-2009 à 20:09:48
Messatsu !
Marsh Posté le 17-02-2009 à 16:43:41
entre le 230mm latéral, le 230mm sur le top, le 140mm à l'arrière et les 2 60mm la zone de la cm est parfaitement ventilée c'est clair.
bien vu le cable management ;)
qu'en est-il de la finition chez Thermaltake ?
Feed sur mon topic : http://forum.hardware.fr/hfr/Achat [...] 7444_1.htm
Marsh Posté le 17-02-2009 à 17:11:00
il est beau mais il me semble que les ventilo thermaltake sont a chier...faut voir pour ceux la
d'après le premier test la cage des disque c'est pas le top du top  :whistle:
Marsh Posté le 17-02-2009 à 17:34:57
c'est un boitier à modder à mon avis.
Marsh Posté le 18-02-2009 à 02:05:52
alimenter en air un ventilo de 23cm par une petite grille même pas disposée en face c'est ridicule  :heink: (je parle du ventilo latéral)
Message édité par couilleshot le 18-02-2009 à 02:13:27
:o :o :o
Marsh Posté le 18-02-2009 à 11:25:29
There's space around the door to allow the fan(s) to intake cool air.
d'après Rodney Reynolds :wahoo:
Messatsu !
Marsh Posté le 18-02-2009 à 12:16:59
c'est un concurrent du nine hundred ça ... au niveau des façades, ventilo, repartition des cables, etc, c'est un peu foutu pareil.
Par contre le truc très utile que l'on ne retrouve pas sur les nine et twelve hundred, c'est le trou pour pouvoir démonter un rad par derrière sans démonter la carte mère.
Marsh Posté le 18-02-2009 à 12:58:26
Le trou pour le rad ça a été lancé par coolermaster, thermlatake en concurrent direct un peu dépassé suit le mouvement
Désolé mais pour moi c'est clairement mal foutu, autant virer le ventilo latéral, faudrait savoir où se positionne ce boitier : pro et sobre ou ventilé tuning?
Le mélange des deux pourrait être interessant mais le ventilo latéral sert clairement à rien, ou alors faut lui mettre une vrai grille  :heink:
Message édité par couilleshot le 18-02-2009 à 13:01:41
:o :o :o
Marsh Posté le 18-02-2009 à 13:46:56
Y' a pas de filtre sur les ventilos ?
-=Mon topic ventes=-
Marsh Posté le 19-02-2009 à 10:19:03
si justement :
MAJ du post principal :)
Messatsu !
Marsh Posté le 19-02-2009 à 10:53:43
edit : tu a accès au backplate du ventirad cpu sans démonter la mobo comme le coolermaster 840 et cerise sur le gâteau le bruit des ventilos thermaltake est raisonnable :hello: la finition est excellente et la qualité de la cage hdd est très propre notamment pour réduire les vibrations
Message édité par Fssabbagh le 19-02-2009 à 10:55:11
Messatsu !
Marsh Posté le 19-02-2009 à 11:29:28
Le raven me faisait envie mais celui la a l'air bien vivement un test FR.
Dans la vidéo on ne voit pas le 23cm latéral il est en option ?
Marsh Posté le 19-02-2009 à 11:30:52
non il est bien là ;)
Message édité par Fssabbagh le 19-02-2009 à 11:35:20
Messatsu !
Marsh Posté le 19-02-2009 à 14:10:24
Une idée de la disponibilité en magasin français?
J'ai lu un test + vu la video sur daily et çà m'a l'air d'etre du tout bon ce boitier.
Je le trouve sobre et avec une bonne finition de quoi faire envie ;)
Marsh Posté le 19-02-2009 à 14:21:34
+1 Vigorius :love:
Messatsu !
Marsh Posté le 19-02-2009 à 14:26:40
Ouep par contre les deux trous pour les ventilo de 6 cm je voit pas l'intérêt surtout avec un 23 latéral.
Marsh Posté le 19-02-2009 à 14:43:58
Ouais surtout qu'avec des 6 cm paye ton bruit aigu :/
Je l'ai trouvé à vendre ici http://fr.shopbot.ca/pp-thermaltak [...] 67699.html
Au canada donc...
Vivement qu'il arrive en boutique française.
Il est en mid tower en plus donc parfait vu que je n'ai pas une grosse configuration.
Marsh Posté le 19-02-2009 à 14:54:43
je pense que même si tu a une grosse config le Element S pourra tout caser avec ses 7 slots HDD et son très bon câble management :)
Messatsu !
Marsh Posté le 19-02-2009 à 16:38:47
Dans aucun des trois tests je n'ai vu ni lu qu'il y' avait un 23 latéral.
Message édité par morgani le 19-02-2009 à 16:41:45
Marsh Posté le 19-02-2009 à 19:43:13
Bon je viens de regarder le manuel sur le site de TT et en fait il y' a deux version une avec 23 latéral et une sans, celle avec possède une grille devant le ventilo sur la porte latéral.
http://www.thermaltake.com/db/pictures/modules/PDT/PDT060207001/20091221730753343.jpg
Message édité par morgani le 19-02-2009 à 19:56:03
Marsh Posté le 19-02-2009 à 21:49:13
Oki merci pour les informations morgani, reste à voir vers quel prix il sera proposé en france vu qu'on est vers 149$ à l'etranger çà devrait faire du 110-120€ prix français çà non?
Un bon concurrent au 900 V2 de antec et coolermaster 922 qui sortira bientot donc...
Marsh Posté le 20-02-2009 à 10:40:56
le problème des Antec c'est le très faible espace en hauteur ce qui rend difficile l'installation d'un ventirad assez imposant
Messatsu !
Marsh Posté le 20-02-2009 à 12:42:50
Bon y'a du nouveau les loulous.
Version avec ventilo latéral donc de 23 cm
http://www.materiel.net/ctl/Boitie [...] 1W2ZD.html
On s'est encore fait avoir sur le taux de change, du coup pour ce prix j'hésite fortement je m'attendais à 10-20 euros de moins tout de même.
Marsh Posté le 20-02-2009 à 15:00:00
Je cherchais un boitier qui allie sobriété et ventilation et je l'ai enfin trouvé.
Peut-être mon futur boitier pour remplacer mon antique Antec1040 en 80mn.
Non pour moi le prix à l'air correct, surtout si le boitier est de qualité et que l'on trouve pas mieux chez la concurence dans ce style de boitier.
Le prix sur ce site canadien est de 150$:
http://www.esng.ca/productDetail.p [...] &isid=9820
Et il n'a pas l'air de posseder de ventilateur latéral.
Sur matériel.net il y a bien le ventilateur latéral donc c'est la version la plus chère.
De plus il y à des questions de TVA en France, et la conversion €=>$ est moins favorable en ce moment.
Par contre avant ma décision d'achat, j'attend d'abord de lire un test FR.
Parce que là il est dispo dans 14 jours en France et j'hésite à précommandé.
Message édité par Zenus le 20-02-2009 à 15:03:15
Marsh Posté le 20-02-2009 à 15:24:47
ta bien raison
Messatsu !
Marsh Posté le 20-02-2009 à 15:40:56
Plus j'y pense et puis je me dit que c'est le boitier que j'ai toujours voulu avoir.
Nouveau test en anglais :
http://www.pureoverclock.com/revie [...] 713&page=1
Note finale :
http://www.pureoverclock.com/images/review/cases/thermaltake_elements/thermaltake_elements_summary.jpg
Ce boitier à l'air excellent.
Message édité par Zenus le 20-02-2009 à 15:42:05
Marsh Posté le 20-02-2009 à 16:14:24
:love:
Messatsu !
Marsh Posté le 20-02-2009 à 16:49:16
Chu interessé  :)
Par contre dans le meme delire y a deux boitiers, un à 100 € et l'autre à 180 €
http://www.materiel.net/live/45887.jpg
http://www.materiel.net/ctl/Boitie [...] 01W2Z.html
http://www.dailymotion.com/video/x [...] -le-t_tech
test fr : http://www.revioo.com/articles/a11923_5.html
http://www.materiel.net/live/47810.jpg
http://www.dailymotion.com/video/x [...] ition_tech
Message édité par shum94 le 20-02-2009 à 17:26:50
Marsh Posté le 20-02-2009 à 16:52:15
les tests de ces 2 boîtiers sont là :
http://www.dailymotion.com/search/ [...] -le-t_tech
http://www.dailymotion.com/search/ [...] ition_tech
Messatsu !
Marsh Posté le 20-02-2009 à 17:02:54
Pour ceux qui souhaiterais un boitier parfaitement sobre et qui n'aimerais pas la bande rouge de la porte avant,
il me semble que d'après les photos du haut de ce topic que c'est partie soit détachable mais c'est à confirmer.
Puis il faudrait voir ce que ça donne sans.
Sinon un coup de pinceau (ou de l'adhesif renforcé noir) et le tour est joué.
Mais moi je l'aime déjà bien comme ça  :love:
Message édité par Zenus le 20-02-2009 à 17:05:27
Marsh Posté le 20-02-2009 à 17:05:34
déjà rien que les 7 baies HDD :)
Messatsu !
Marsh Posté le 22-02-2009 à 20:24:07
Hum apres voir vu le cooler master ats 840, je dois dire que plus rien d'autres m'interesse.
Marsh Posté le 23-02-2009 à 08:10:04
C'est pas le même prix hein.
Marsh Posté le 23-02-2009 à 11:32:45
en comparant le spedo au 840, le spedo sépare les composants ce que le 840 ne fait pas mais la finition est peut-être un peu meilleure :)
Messatsu !
Marsh Posté le 24-02-2009 à 02:32:54
le Element S est la réponse au Haf 932...
Marsh Posté le 24-02-2009 à 09:15:28
à mettre en face du Sniper plutôt ou du Nine hundred 2, moi j'aime l'allure et les fonctions mais pas le plastique, dommage   :kaola: :(
le même avec extérieur alu serait trop classe  :o
Message édité par couilleshot le 24-02-2009 à 09:17:06
:o :o :o
Marsh Posté le 24-02-2009 à 15:20:38
oui mais le prix  [:tinostar]
Messatsu !
Marsh Posté le 24-02-2009 à 16:00:05
le Element S et le HAF sont vraiment comparables tant pour les prix que pour l'architecture interne des boitiers, le principe de circulation de l'air est quasi identique sauf que c'est le choix des ventilos qui diffère et l'ajout d'un pseudo compartiment.
ce sont 2 boitiers très proches mais pensé autrement...
