reboot et bluescreen
reboot et bluescreen - Matériels & problèmes divers - Hardware
Marsh Posté le 27-10-2011 à 18:59:23
bonjour,
quand je laisse le pc en idle tout seul, il a tendance a rebooter. Donc j'ai fais un essaye avec whocrashed :
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 17153769472 total
VM: 2147352576, free: 1899110400
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 27/10/2011 16:03:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102711-15787-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x170CD8)
Bugcheck code: 0x116 (0xFFFFFA80127BB010, 0xFFFFF8800FF75CD8, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 280.26
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 280.26
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 280.26 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation VIDEO_TDR_ERROR
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl!TdrResetFromTimeout+0x214)
file path: C:\Windows\system32\drivers\dxgkrnl.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics Kernel
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
qu'est ce que je dois faire ? mettre a jour mes drivers ? je sais pas trop comment m'y prendre.
Marsh Posté le 27-10-2011 à 21:45:03
repère le modèle et la marque de ta carte graphique avec gpuz tu va chercher le dernier drivers sur le site du constructeur tu désinstalle les anciens tu  reboot et tu installe les nouveauxainsi que les directx
étant donné que nous vivons dans un monde corrompu par l'argent, tout ce qui est gratuit est bon à prendre
Marsh Posté le 27-10-2011 à 22:46:30
j'ai mis a jour et j'ai eu droit a un autre bluescreen avec les même problemes
