P4 3.06 sur ebay (intel mobile pentium ? ca marche sur pc ?) [Help] - Carte mère - Hardware
Marsh Posté le 20-09-2004 à 19:42:30
Le fond du problème est surtout que je ne suis pas sur que le 3.06 mobile possède l'HT...
Marsh Posté le 20-09-2004 à 20:13:17
A priori pas de soucis de ce coté là :
Intel Mobile Pentium 4 Processor Supporting Hyper-Threading Technology
On Sept. 23, 2003 Intel Corporation introduced the Mobile Intel® Pentium® 4 processor supporting Hyper-Threading (HT) Technology for portable notebook PCs, commonly referred to as desktop replacement notebooks.
Origine :
http://www.infohq.com/Computer/mob [...] eading.htm
Si sa CM est compatible pas de soucis.
Y'a aussi des CM pour PC de bureau qui sont compatibles, comme :
BOXD865GBFL Desktop Board, ATX, 865G Chipset, dual channel DDR400, mPGA 478, AGP8X, ADI AC'97 Audio w/ SoundMAX, ASIC, SATA, Intel PRO/100
BLKD865GBFL Desktop Board, ATX, 865G Chipset, dual channel DDR400, mPGA 478, AGP8X, ADI AC'97 Audio w/ SoundMAX, ASIC, SATA, Intel PRO/100
BOXD865GBF Desktop Board, ATX, 865G Chipset, dual channel DDR400/333/266, mPGA 478, AGP8X, ADI AC'97 Audio w/ SoundMAX, ASIC, SATA
BLKD865GBF Desktop Board, ATX, 865G Chipset, dual channel DDR400/333/266, mPGA 478, AGP8X, ADI AC'97 Audio w/ SoundMAX, ASIC, SATA
BOXD865PERLL Desktop Board, ATX, 865PE Chipset, dual channel DDR400/333/266, mPGA 478, AGP8X, ADI AC'97 Audio w/ digital output, 1394a, ASIC, SATA RAID, Intel PRO/100
BLKD865PERLL Desktop Board, ATX, 865PE Chipset, dual channel DDR400/333/266, mPGA 478, AGP8X, ADI AC'97 Audio w/ digital output, 1394a, ASIC, SATA RAID, Intel PRO/100
BOXD865PERLK Desktop Board, ATX, 865PE Chipset, dual channel DDR400/333/266, mPGA 478, AGP8X, ADI AC'97 Audio w/ digital output, 1394a, ASIC, SATA RAID, Intel PRO/1000
BOXD865PERL Desktop Board, ATX, 865PE Chipset, dual channel DDR400/333/266, mPGA 478, AGP8X, ADI AC'97 Audio w/ SoundMAX, ASIC
BLKD865PERL Desktop Board, ATX, 865PE Chipset, dual channel DDR400/333/266, mPGA 478, AGP8X, ADI AC'97 Audio w/ SoundMAX, ASIC
Source :
http://www.synnex.co.th/product/intel/motherboard.php
Alors...
Est-ce que ta CM a ce socket?
PS :
Je vois pas trop pourquoi avoir ou pas la techno HT est le fond du probleme? Me semblait que le fond du problème était 'Un Pentium Mobile fonctionne t il sur un PC Desktop?'
Marsh Posté le 31-08-2004 à 17:09:49
J'ai acheté ceci sur ebay et d'un coups j'ai peur que cela ne marche pas dans mon desktop !! Apparement l'intel mobile pentium serait different de l'intel pentium-m ?
vous en pensez-quoi ?
Processeur Intel Pentium 4 possédant 512 Ko de mémoire cache et fonctionnant sur bus mémoire à 533 Mhz. Fréquence à 3.06 Ghz soit 3060 Mhz ! A installer sur une carte mère avec socket mPGA 478 qui supportera ce bus. Processeur idéal pour un overclocking au regard de sa faible fréquence de bus !!!!
Rapidité et performances assurées pour les jeux et les applications. Idéal sous Windows XP, ce processeur sera le coeur de votre installation musclée
Intel® Pentium® 4 processeur référence : SL726
Bonnes enchères !
Le 23-août-04 à 20:56:00 Paris, le vendeur a ajouté les informations suivantes :
Ce processeur est un intel Pentium 4 mobile qui intègre la technologie Speedstep. La vitesse s'adapte donc à la charge de travail de votre PC. Idéal pour avoir une configuration peu bruyante qui ne chauffe pas. De plus, il est donc également possible de le mettre dans une ordinateur portable
Voici les caractéristiques officielles de Intel :
Mobile Intel® Pentium® 4 Processors
Results
sSpec Number
SL726
Processor Frequency
3.06 GHz CPUID String
0F29h
Package Type
478 pin PPGA Core Voltage
1.300
Bus Speed
533 MHz Thermal Guideline
70W
Core Stepping
D1 Thermal Spec
100°C
L2 Cache Size
512 KB Manufacturing Technology
0.13 micron
L2 Cache Speed
3.06 GHz Bus/Core Ratio
23
Spec Update
http://developer.intel.com/design/ [...] tation.htm
Product Order Codes
OEM Order Code
RK80532GE083512
Notes
This processor includes enhanced Intel SpeedStep® Technology.
