[Topic Unique ] L'Asrock Penryn1600SLI
L'Asrock Penryn1600SLI [Topic Unique ] - Carte mère - Hardware
Marsh Posté le 17-01-2008 à 22:17:51
Bonsoir a tous , j'ai jeté un oeil sur cette carte qui a l'air pas mal du tout surtout niveau caractéristiques...
Moi qui cherchais une carte mere ressente avec 2 ports IDE , si celle ci était sortie un peu plus tot, je l'aurai pris avec un CPU intel...
http://img221.imageshack.us/img221/5251/asrockpenryn1600sli110dia9.jpg
LGA 775 for Intel® Core™ 2 Extreme / Core™ 2 Quad / Core™ 2 Duo / Pentium® Dual Core / Celeron®, supporting Penryn Quad Core Yorkfield and Dual Core Wolfdale processors
- Compatible with all FSB1600/1333/1066/800MHz CPUs
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset  - Northbridge: NVIDIA® 650iSLI (C55)
- Southbridge: NVIDIA® nForce 430
Memory  - Dual Channel DDR2 memory technology
- 4 x DDR2 DIMM slots
- Supports DDR2 800/667/533 non-ECC, un-buffered memory
- Max. capacity of system memory: 8GB*
BIOS  - 8Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, DRAM, NB, SB, VTT Voltage Multi-adjustment
 Audio, Video and Networking
Graphics  - n/a
Audio  - 7.1 CH Windows® Vista™ Premium Level HD Audio with Content Protection
- DAC with 110dB dynamic range (ALC890 Audio Codec)
LAN  - Gigabit LAN 10/100/1000 Mb/s
- Giga PHY Realtek RTL8211B
- Supports Wake-On-LAN
 Expansion / Connectivity
Slots  - 3 x PCI Express x16 slots (white @ x16 mode, yellow @ x8 mode)
- 1 x PCI Express x1 slot
- 3 x PCI slots
- Supports NVIDIA® SLI™
4 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1, JBOD and RAID 5) and NCQ functions
- 2 x ATA133 IDE connectors (support 4 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- CPU/Chassis FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- SLI/XFire power connector
- CD in header
- Front panel audio connector
- 1 x USB 2.0 header (supports 2 USB 2.0 ports)
- 1 x WiFi/E header
Rear Panel I/O  ASRock WiFi_SPDIF I/O Plus
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Serial Port: COM1
- 1 x Parallel Port (ECP/EPP Support)
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Prix : environ 75 euros
Je possede une Asrock sur ma 2e config , ca a l'air quand meme assez stable , alors apres il y a ceux qui disent que Asrock est une bonne marque et ceux qui disent que c'est du bas de gamme merdique...
Qu'en pensez vous , moi perso , cette carte me plait...
Message édité par Olio le 31-03-2008 à 22:35:09
Marsh Posté le 17-01-2008 à 22:28:00
75€ c'est quasi le prix de la Asus...qui a plus d'equipements !
Retraité du Hardware
Marsh Posté le 17-01-2008 à 22:31:19
Laquelle ???
Moi ce qui m'interresse ce sont les 2 ports IDE
Marsh Posté le 17-01-2008 à 22:32:56
laquelle d'asus ??
mais je croyais que le penryn quad etait pas compatible avec le chipset nforce 650sli ???
On nous aurait menti ?
Message édité par rxtech le 17-01-2008 à 22:33:13
http://valid.x86-secret.com/show_oc.php?id=356342 - http://www.youtube.com/watch?v=HNg [...] re=related
Marsh Posté le 17-01-2008 à 22:35:11
Et pourtant cette Asrock supporte le quad et le core2duo
Marsh Posté le 18-01-2008 à 11:24:36
la p5n e sli
Marsh Posté le 18-01-2008 à 11:51:28
ouai mais quand tu vois tout les problemes rencontré sur p5n e sli, ca fait pas envie ... Et je sais de quoi je parle, j'en ai une ...
Marsh Posté le 18-01-2008 à 12:32:27
Déja dis moi si tu trouve une P5N E sli a 75 euros...
Ca tourne plutot a 90/100 euros
Ensuite , l'Asrock a plus d'équipement comme tu dis...
Elle intégre meme le wifi et le hdmi
Avant de dire des anneries , vérifie
Marsh Posté le 18-01-2008 à 13:42:57
Oulala excuse moi grand gourou apôtre asrock tout puissant  :love:
en effet j'ai lu un peu vite
Marsh Posté le 18-01-2008 à 13:45:24
pas mal, faut voir pour l oc et les perfs...
pas cher 75e pour une carte si complete...
Marsh Posté le 18-01-2008 à 18:46:19
Oula ne le prends pas mal hein :)
J'ai rien contre Asus et je suis pas un disciple Asrock , seulement tu as direct affirmer des choses fausses :)
Marsh Posté le 18-01-2008 à 18:57:02
Il me semble aussi avoir lu que les Yorkfield ne seraient pas compatibles avec les chipsets 650i et 680i.
Marsh Posté le 18-01-2008 à 18:59:19
Ben j'ai pris les caractéristiques sur le site Asrock...
Et apparement elle supporte les yorkfield
Marsh Posté le 18-01-2008 à 19:08:43
Sinon ASRock va proposer de plus en plus des cartes mères à base des chipsets milieu de gamme, un P35 est prévu aussi si elle n'est pas sorti.
De toute façon, niveau prix les ASRock couteront toujours moins chères que les cartes mères Asus pour ne pas concurrencer la maison mère.
Message édité par jesaipacki le 18-01-2008 à 19:09:08
Marsh Posté le 18-01-2008 à 19:11:03
c'est juste qu il manquait un composant sur les cm a base ne nf6xxsli pour recevoir les quads ...
Je suppose que vu que cette cm vient juste de sortir, ils ont rajoute ce fameux composant ...
Et puis vu que nvidia viens de sortir les 780i et 790i, il faut bien qu ils eclusent leurs stocks de chipsets nf6 ...
Marsh Posté le 19-01-2008 à 10:21:34
Ma P5n e sli sortie debut 2007 accepte les quad depuis le debut :
http://www.asus.com/products.aspx? [...] odelmenu=1
Asrock c'est super qualité prix et fiable (une mobo morte sur une trentaine montée), le probleme c'est les bios. Apres si on n'Oc pas ça reste un tres bon choix
Marsh Posté le 19-01-2008 à 11:00:23
[:haltias]
une petite carte qui risque de remplacer ma 939SLI32...
Pour la fiabilité, j'en ai monté 6, et pas de soucis sur 3 ans.
C'est sur apres, ce ne sera peut etre pas LA carte de l'oveclocker fou :pt1cable: , mais du moment que c'est stable.
Au niveau perf, un petit aperçu ici : http://my.ocworkbench.com/bbs/show [...] post425861
TOPIC @verclock des series 939 Asrock :)
Marsh Posté le 19-01-2008 à 12:00:52
Marsh Posté le 19-01-2008 à 13:37:07
Ah ben tiens alors :)
Ma prochaine avec un quad ( dans 1 an )
Marsh Posté le 19-01-2008 à 15:15:23
Ben je me laisserai bien tenter par cette petite carte mère d'ici quelques temps. J'achète du Asrock depuis 3 générations de CPU (K7, A64, Core2) et en dehors du faux port PCIEx16 de la dernière aucun soucis de stabilité.
Merci pour l'info Olio  :hello:
Marsh Posté le 21-01-2008 à 19:40:02
De rien :)
Marsh Posté le 21-01-2008 à 21:00:49
des infos sur les disponibilités prochaines ? :)
Marsh Posté le 21-01-2008 à 23:20:30
J'attends aussi :)
Pour l'instant rien
Marsh Posté le 22-01-2008 à 08:57:18
Je cite
This model may not be sold worldwide. Please contact your local dealer for the availability of this model in your region.
Donc cette carte ne sera pas forcement vendue en France (comme c'est le cas pour la carte mere Asrock en P31).
A noter que plusieurs cartes mères en P35 sont référencées chez Asrock :
http://www.asrock.com/mb/overview. [...] 35-WiFi%2b
http://www.asrock.com/mb/overview. [...] 00P35-WiFi
http://www.asrock.com/mb/overview. [...] 0Twins-P35
La dernière semble aussi assez interressante
Marsh Posté le 22-01-2008 à 09:10:55
Marsh Posté le 22-01-2008 à 09:37:27
rxtech a écrit :
La cm asrock en p31 est au catalogue rue du commerce au prix de 66 euros : http://www.rueducommerce.fr/compos [...] ntel%20P31
ah ok, dsl, j'avais regardé il y a quelques temps.
Par contre pour le même prix on a une Gigabyte...
Marsh Posté le 22-01-2008 à 09:47:44
D'un autre cote, a 65 euros c'est dur de faire moins cher ... :lol:
Marsh Posté le 29-01-2008 à 12:50:08
Marsh Posté le 29-01-2008 à 13:36:45
On sent vraiment la volonte d asrock de devenir une marque " a part entiere ", et non juste un constructeur de carte mere pas cheres ...
Marsh Posté le 30-01-2008 à 19:09:00
Marsh Posté le 08-02-2008 à 17:03:56
Preview de la carte : http://www.ocworkbench.com/2008/as [...] 0dB/g1.htm
elle m'a l'air bien sympatique...
Marsh Posté le 08-02-2008 à 19:29:57
Ma prochaine avec un bon CPU intel :) :)
Marsh Posté le 17-02-2008 à 15:21:38
Marsh Posté le 17-02-2008 à 15:59:28
je croyais que les cartes mères 650i et 680i pouvait pas supporter les nouveaux quad core yorkfield ?
https://www.ebay.fr/usr/swfalcon + http://www.priceminister.com/boutique/farainp
Marsh Posté le 17-02-2008 à 16:16:14
Oui, d'où le titre de l'article!
Marsh Posté le 21-02-2008 à 11:31:37
Marsh Posté le 21-02-2008 à 13:54:23
Marsh Posté le 21-02-2008 à 19:13:30
Nan du tout mais je pensais a 60/70 comme les autres cartes de chez Asrock :)
La on atteint presque 100 euros avec les frais de port :)
Marsh Posté le 22-02-2008 à 00:38:42
Sauf que cette carte est sensiblement moins dépassée que ce qu'asrock à l'habitude de sortir. Ici, il ne s'agit pas de recycler un chipset vieux de 4 ans qu'on a vaguement modernisé pour l'occasion. C'est un chipset récent, avec le support complet des techno actuelles, un chip son haut de gamme (pour un bidule intégré), des condo solides et un bios évolué. C'est quand même pas tout à fait la même gamme; ils ne vont pas te la vendre à prix coûtant.
Marsh Posté le 22-02-2008 à 01:52:10
je  me permet de metre un lien pour mon topic sur les
Asrock chipset P15
