Help !! Probleme P5WD2, DD SATA et installation XP - Carte mère - Hardware
Marsh Posté le 20-05-2006 à 00:24:46
Salut Christophe30,
Meme probleme que toi.
J'ai une P5WD2 premium avec un P4D805 et 2*1024 de DDR2 PC6400 gold edition d'OCZ, et que j'installe sur un sata ou un ide c'est le meme message comme quoi y a un probleme sur le disque.
Je continue à chercher, si j'ai du neuf je reviens poster.
Marsh Posté le 20-05-2006 à 00:37:34
Un élément de réponse :
I was also disappointed with the documentation during the install process. The manual should have been more explicit saying that you pretty much need to install your windows XP onto a SATA drive. I was trying to do this on an IDE drive, but you needed to install a driver during the install in order to make the IDE visible. And these IDEs are Asus add-ons, so are not visible by the BIOS.
http://stores.tomshardware.com/pur [...] d=290842//
Marsh Posté le 20-05-2006 à 00:47:08
merci pour ta reponse Spartatist,
Comme je vois tout le monde galere et personne n'y arrive vraiment.
Je continue à chercher.
Marsh Posté le 20-05-2006 à 00:51:53
Trouvé aussi :
I recently found out this information on the P5WD2:
"The P5WD2 (Premium) *does* overvolt its CPUs by default. The CPU is ranged at 1.225 - 1.380 and you should manually lower the voltage to about 1.3 down from the 1.49 where it is set by default. Very sloppy of ASUS. Or rather, this seems to be done on purpose, as memory is overvolted too. In fact, the whole system is slightly overclocked out of box -- probably to get an edge over the competition."
So that must have been the problem.
--Fishaman
Marsh Posté le 20-05-2006 à 00:53:26
Encore :
Have been reading the manual much more carefully and also all the online references about this board.
Just got back and first thing, plugged in the 8 pin EATX power (instead of the 4 pin), hooked up the EZPlug (Molex), and then reseated everything.
VOILA!! Booted up!
Marsh Posté le 20-05-2006 à 00:54:21
ET finalement :
Hi all,
After having the same problum I tried SATA 80G HD & SATAii 300G HD & IDE 80G. The problum was in the CD-ROM drive. Put the CD-ROM / DVDRW on the BLUE plug {ICH7R Primary IDE connector} on the motherboard. Not the RED ones!!
After that all is working fine!!
En espérant que çà vous aide (perso j'ai pas cette carte mais si on peut aider......)
Marsh Posté le 20-05-2006 à 01:00:09
Ok merci pour ces elements,
Je teste et check ces elements, merci de ton aide.
Pour l'instant je dirais plutot que tu es chanceux de ne pas avoir une telle mobo!!!
Marsh Posté le 20-05-2006 à 01:01:32
Et qui confirme :
The ITE chipset has 2 red connectors but the manual says it does not support ATAPI devices ? I dont know what that means, but i guess it has no support for my cd writer devices,
Le chipset ITE (connecteurs rouges) ne supporte pas les périphériques ATAPI donc CD/DVD/Graveur donc bien utiliser le connecteur bleu pour les CD/DVD Rom
Marsh Posté le 20-05-2006 à 01:04:32
Ca progresse
J'ai branché un disque dur ide sur la meme nappe que le lecteur cd (dd en slave et cd en master) sur le port ide bleu, et l'install de windows c'est lancer malgre quelque avertissement comme quoi il n'y avait pas de dd en master ide1.
reste 30 minutes d'install, je repost si l'install c'est terminé sans soucis.
Marsh Posté le 20-05-2006 à 01:06:24
A ta place j'aurais plutot fait l'inverse HD en master et CD en slave mais si çà marche....
De plus ils recommande de plutot installer le system sur du SATA donc je suppose CD sur connecteur bleu et un disque sur le SATA. Une fois installé tu pourrais alors installer ton HD IDE sur un des connecteurs rouges en maitre
Marsh Posté le 20-05-2006 à 01:07:37
exact mais j'avais la fleme le cd etait visse et le cavalier pas super accessible, alors que le dur etait demonté.
Marsh Posté le 20-05-2006 à 01:10:33
Bah de toute manière si çà se passe bien tu pourras inverser après
Marsh Posté le 20-05-2006 à 01:11:41
Enfin, j'espère que j'ai pu t'aider.....çà a l'air de prendre une voie plus naturelle question install :-)
Marsh Posté le 20-05-2006 à 01:14:40
Le but etant quand meme d'avoir un os sur deux disque sata en raid0.
J'ai l'impression que les problemes viennent de la configuration des disques dans le bios, mais j'ai essayé plusieurs parametres et rein ne m'a l'air de fonctionner!!!!!!
Marsh Posté le 20-05-2006 à 01:15:42
l'install c'est finie sans soucis!
Reste à trouver une solution pour le sata!
Merci de ton aide en tout cas!
Marsh Posté le 20-05-2006 à 01:17:26
Faudra essayer :
Disques sur SATA avec construction de l'array
et çà devrait alors passer enfin si là déjà çà passe ....
Marsh Posté le 20-05-2006 à 01:22:43
RAID, une solution ?? :
I had success but I am confused now...
I looked in the Disk Manager and it did not see the drives. So I set the BIOS to IDE instead of Raid. It still did not see the drives. Next I moved the drives off of the SATA RAID connectors and plugged them in as SATA 1 and 2. Disk manager found them at that point and I made them dynamic drives and striped them. The confusing part is the BIOS is still set to IDE instead of RAID....
Marsh Posté le 20-05-2006 à 01:23:20
Sous winxp, je viens de lui brancher à chaud un disque sata, et bien il ne le vois pas, rien, nada......
Je vais faire un petit tour dans le bios!
Marsh Posté le 20-05-2006 à 01:24:52
C'est clair que ce bios est tout sauf "clair" hahaha.
Sans rire c'est la galere cette carte!
Marsh Posté le 20-05-2006 à 01:28:06
A première vue il y a un site intéressant à visiter à propos de cette carte mais il est extrémement lent :
http://vip.asus.com/forum/view.asp [...] uage=en-us
Quelle carte mère dis donc ? Une prise de t^te, il faut être motivé ....
Marsh Posté le 20-05-2006 à 01:32:17
Merci pour le site,
Bein la carte à l'air bien, faut juste piger comment elle fonctionne.
Marsh Posté le 20-05-2006 à 01:35:51
En tous cas, bon courage ! Si j'ai pu amener ma petite pierre à l'édifice....
Bonne nuit.
Marsh Posté le 20-05-2006 à 01:36:10
Apres un redemarrage le dd sata est reconnu????
J'ai rien changé dans le bios!!!
Marsh Posté le 20-05-2006 à 01:40:01
Oh oui çà !! Je suis un peu pareil, tant que je n'ai pas trouvé.....
Mais parfois on cogiter un peu la nuit en dormant et la solution vient le lendemain mais dur de lacher l'affaire
Marsh Posté le 20-05-2006 à 01:41:29
u cours de la lecture et après je vais me coucher :
The latest intel from Intel says that the ICH7R supports BOTH AHCI AND RAID!!!!!!!  You do not lose RAID if you set AHCI in the BIOS.  You simply gain NCQ and DMA architecture - read the links that the ASUS manual references at the top of page 4-17.  I'm pretty certain of this one.
Marsh Posté le 20-05-2006 à 10:09:14
Ok ca y est!
J'ai reussi à installé windows sur 2 disques Sata en raid0.
Et bien c'est une installation tout à fait normale d'os sur un raid0:
Finalement il n'y qu'en ide et sata non raid que je galere, mais il doit y avoir des drivers à installer aussi depuis le cd de la mobo.
Voili voilou si ca peu aider quelqu'un, parce que j'ai pas mal galeré en ide et sata pensant que j'avais un probleme hard; incompatibilité ou defaut, mais en fait ce n'est que de la configuration....
Marsh Posté le 06-07-2006 à 19:56:02
comment ta fait alors mec car la j'ai le mem prob avec cette carte mere.
jai un graveur et un dur, comment je dois les brancher? il reconnai que celui qui est sur le port bleu?
du coup il peu pas minstaller windows car ya pas de dur il me dit?
et quand je met les 2 sur le rouge le pc me fait excran bleu a l'install, par contre dans le bios, nada, c comme ci rien nété branché, sauf quadn jen met un sur le bleu
Marsh Posté le 30-06-2008 à 12:56:37
| Spartatist a écrit : Un élément de réponse :   |
Pardon de faire remonter un poste si vieux mais je viens de recuperer cette carte mere et je galere.
Faut il re-installer windows pour installer les port IDE Rouge? Si oui quel driver?
J'ai reussi l install sur le port bleu mais rien n'est reconnu sur le port IDE rouge
Merci beaucoup.
Marsh Posté le 17-05-2006 à 15:36:44
J'ai monté une nouvelle machine avec comme carte mere une ASUS P5WD2.
Je n'arrive pas à installer XP, que ce soit sur un disque SATA ou un disque IDE.
En configuration IDE, l'install de XP démarre (chargement des composants) mais plante en arrivant au demarrage proprement dis de l'install avec un message indiquant un probleme avec le disque.
En configuration SATA (celle que je prefererais), l'install ne demarre meme pas car ca fait comme si le cd n'était pas reconnu.
J'ai fait plein de combinaison de branchement (EIDE, IDE, SATA, ...) mais rien ne marche.
Je commence un peu à desesperer de voir cette machine marcher.
Si quelqu'un avait le meme genre de conf et deja rencontré ce probleme, j'apprécierais beaucoup un peu d'aide
Merci,
Christophe
