[Topic Unique] ABIT AN8 32X [sondage 10/04]
ABIT AN8 32X [sondage 10/04] [Topic Unique] - Carte mère - Hardware
Marsh Posté le 23-03-2006 à 11:01:22
ABIT AN8 32X
la AN8 32X a recu le Hot Product Award de TweakPC.de
http://www2.abit.com.tw/upload/news/tweakpc_hot-55.jpg
1) Résumé
Socket 939
Nvidia® NF4 SLI X16
2GHz HT
Dual DDR 400
NV SATA RAID
NV Ethernet Gigabit w/ Firewall
7.1 CH Audio
NVIDIA SLI 32X Tech.
ABIT Silent OTES
ABIT µGuru Tech.
2) Specifications
CPU
Supports Socket 939 Athlon64/ 64FX/ 64X2 Processor with 2GHz system bus using Hyper Transport Technology
Cool 'n' Quiet : adaptation automatique de la frequence du CPU à la charge
Chipset
NVIDIA NF4 SLI X16 / NF4 SLI Chipset
Memoire
Quatre slots DDR
Dual channel DDR 400 ECC/non-ECC un-buffered memory
Jusqu'a 8GB de RAM !
NVIDIA SLI Technology
Deux ports PCI-Express X16 NVIDIA Scalable Link Interface
Deux ports PCI-Express full-bandwidth 16-lignes (pas 8X comme sur les cartes SLI normales)
NV SATA 3Gb/s RAID
4 ports SATA II 3Gb/s RAID 0/1/0+1/5
Supports SATA AHCI, providing Native Command Queuing and native hot plug
2nd SATA RAID
Serial ATA 3Gbps by Sil 3132 PCIE controller
Supports SATA RAID 0/1 NCQ
Audio
On board 7.1 CH Audio CODEC (ALC850)
Supports auto jack sensing and optical S/PDIF In/ Out
Reseau
NVIDIA Gigabit Ethernet avec NV Firewall ActiveArmor
IEEE1394
Firewire IEEE1394a
Connecteurs I/O Internes
2 x PCI Express x16 (deux ports PCI Express full-bandwidth 16-lignes)
2 x PCI Express x1
2 x ports PCI
1 x port disquette
6 x ports SATA
2 x ports Ultra DMA 133/100/66/33
3 x connecteurs USB 2.0 (=> 6 ports USB)
1 x connecteur IEEE 1394
1 x Guru Link (permet de connecter le Guru Clock)
Panneau Arrière I/O
1 x Clavier PS/2
1 x Souris PS/2
4 x ports USB
1 x port LAN RJ-45
1 x IEEE 1394
1 x S/P DIF In
1 x S/P DIF Out
Format
ATX 305 x 245mm
Technologies speciales ABIT
ABIT Patented Silent OTES Technology
ABIT µGuru Technology
Accessoires Compatibles
Guru Clock
3) Contenu de la boite
http://gandalf.vef.free.fr/AN8/IMG_6747_s.JPG http://gandalf.vef.free.fr/AN8/IMG_6655_s.JPG
http://gandalf.vef.free.fr/AN8/IMG_6659_s.JPG http://gandalf.vef.free.fr/AN8/IMG_6660_s.JPG
http://gandalf.vef.free.fr/AN8/IMG_6662_s.JPG http://gandalf.vef.free.fr/AN8/IMG_6665_s.JPG
http://gandalf.vef.free.fr/AN8/IMG_6666_s.JPG http://gandalf.vef.free.fr/AN8/IMG_6667_s.JPG
4) Téléchargements
Bios
Les Bios de la AN8 32X chez ABIT
Drivers
Page de drivers de la AN8 32X chez ABIT
chipset : nVidia nForce4 16X
sata : Silicon Image SiL3132 32bits
sata : Silicon Image SiL3132 64bits
sata : Autres OS : Drivers Silicon Image
Manuels
Le manuel de la AN8 32X en anglais
Utilitaires
ABIT µGuru v3.018
5) Liens
News
Une news chez hardware.fr : CrossFire et SLI x16 chez ABIT
De jolies photos chez coolaler : ABIT AN8 32X
Tests
Un test / comparatif de la AN8 32X sur motherboards.org (en anglais)
Test de la AN8 32X chez t-break (en anglais)
Un comparatif SLI vs. SLI 16X sur t-break (en anglais)
Encore un test de la AN8 32X sur techreport (en anglais)
Overclocking de la AN8 32X chez bit-tech
test de la AN8 32X chez pro-clockers (en anglais)
test de la AN8 32X chez PC stats (en anglais)
test de la AN8 32X chez Hot Hardware (en anglais)
Message édité par gandalf-ze-wizard le 24-12-2007 à 10:54:09
Marsh Posté le 23-03-2006 à 11:01:35
6) FAQ
Question : Si je branche 2 cartes graphiques, mais pas en SLI (voire pas 2 nVidia), est ce que j'aurais quand meme les 2 cartes en PCIe 16X ?
Réponse : Oui, bien sur ! Quelles que soient les cartes, elles marchent en 16X sur chaque port !
7) News
le 29/03/06 comparatif SLI 16X vs. SLI
t-break a publié un article (en anglais) comparant le SLI au SLI 16X ...
url=http://www.tbreak.com/reviews/article.php?cat=mobos&id=436]SLI vs. SLI 16X[/url]
le 28/03/06 la AN8 32X dispo a montgallet !
ca y est, la AN8 32X est dispo dans la vraie vie a Paris ...
Liste des prix à Montgallet
le 23/03/06
http://gandalf.vef.free.fr/AN8/config1_s.jpg http://gandalf.vef.free.fr/AN8/config2_s.jpg
http://gandalf.vef.free.fr/AN8/config3_s.jpg
quelques photos de ma config "montée" mais pas branchée ...
Message édité par gandalf-ze-wizard le 23-06-2006 à 10:23:25
Marsh Posté le 23-03-2006 à 11:01:43
8) Photos
Overclocking
http://gandalf.vef.free.fr/AN8/CPU-z_CPU_s.PNG
le HTT 300 passe !!!
http://www.bit-tech.net/content_images/abit_an8_32x/abitoc.jpg
chez bit-tech, le FSB 340 passe !!!
Postez vos meilleurs OC, et je les publierais dans ce post !
Vues generales
La carte dans toute sa splendeur !
http://gandalf.vef.free.fr/AN8/IMG_6681_s.JPG
Les connecteurs 'back plate'
http://gandalf.vef.free.fr/AN8/IMG_6687_s.JPG
Le dessous de la carte mère !
Details
http://gandalf.vef.free.fr/AN8/IMG_6682_s.JPG
Le coin superieur gauche, avec le Silent OTES sur les MOSFET, le CPU et l'afficheur de diagnostique :love:
http://gandalf.vef.free.fr/AN8/IMG_6688_s.JPG
Les ports PCI-Express 16x et 1x et les ports PCI
http://gandalf.vef.free.fr/AN8/IMG_6711_s.JPG
L'afficheur de diagnostique : 00 => PC éteint
Message édité par gandalf-ze-wizard le 23-06-2006 à 10:23:43
Marsh Posté le 23-03-2006 à 11:13:33
Le BIOS
http://gandalf.vef.free.fr/AN8/IMG_6717_s.JPG
Page principale
http://gandalf.vef.free.fr/AN8/IMG_6721_s.JPG
Menu µGuru Utility / OC Guru
on peut juste regreter de ne pas pouvoir regler le voltage du Chipset ...
http://gandalf.vef.free.fr/AN8/IMG_6724_s.JPG
Menu µGuru Utility / OC Guru / Power Cycle Statistics
Message édité par gandalf-ze-wizard le 28-03-2006 à 11:15:22
Marsh Posté le 23-03-2006 à 11:13:46
Le BIOS (Suite)
http://gandalf.vef.free.fr/AN8/IMG_6725_s.JPG
Menu µGuru Utility / ABIT EQ
http://gandalf.vef.free.fr/AN8/IMG_6726_s.JPG
Menu µGuru Utility / ABIT EQ / Temperature Monitoring
http://gandalf.vef.free.fr/AN8/IMG_6727_s.JPG
Menu µGuru Utility / ABIT EQ / Voltage Monitoring
http://gandalf.vef.free.fr/AN8/IMG_6728_s.JPG
Menu µGuru Utility / ABIT EQ / Fan Speed Monitoring
http://gandalf.vef.free.fr/AN8/IMG_6729_s.JPG
Menu µGuru Utility / ABIT EQ / FanEQ Control
http://gandalf.vef.free.fr/AN8/IMG_6730_s.JPG
Menu µGuru Utility / ABIT EQ / FanEQ Controle / CPU FanEQ Control
(vous pouvez faire de meme avec les 5 ventilos de la MB !)
on peut regler 2 paliers pour la vitesse de rotation du ventilateur en fonction de la temperature !
on peut preciser quelle est la temperature de reference, ce qui est tres pratique pour les ventilateurs AUX1 et AUX2
http://gandalf.vef.free.fr/AN8/IMG_6731_s.JPG
Menu Advanced Chipset Settings
K8<->NB HT Speed correspond au HTT ...
http://gandalf.vef.free.fr/AN8/IMG_6732_s.JPG
Menu Advanced Chipset Settings / DRAM Configuration
Moins de reglages que sur les DFI, mais suffisement pour exploiter sa RAM !
Les autres menus sont classiques ...
Message édité par gandalf-ze-wizard le 28-03-2006 à 11:15:42
Marsh Posté le 23-03-2006 à 11:13:51
Sous Windows
http://gandalf.vef.free.fr/AN8/everest_MB_inconnue_s.PNG
Everest ne connait pas encore la carte mère ^^
par defaut, le FSB est ~légerement~ overclocké : 203MHz ...
http://gandalf.vef.free.fr/AN8/CPU-z_mainboard_s.PNG
par contre CPU-z 1.32 la connait !
http://gandalf.vef.free.fr/AN8/everest_chipset_s.PNG
mais il affiche les infos DES chipsets !
North Bridge: nVIDIA nForce4 SLI X16 (C51D)
North Bridge: AMD Hammer IMC
South Bridge: nVidia MCP04
Message édité par gandalf-ze-wizard le 28-03-2006 à 11:16:01
Marsh Posté le 24-03-2006 à 10:52:05
Message édité par gandalf-ze-wizard le 28-03-2006 à 11:17:54
Marsh Posté le 24-03-2006 à 11:55:03
Ah enfin ! je me demandais quand est ce que quelqu'un allait faire un Topic sur cette Mobo
Bien joué Gandalf  :jap:
Autrement pas de probleme pour l'install de windows ?
Et au niveau des temperature chipset, processeur ?
quelle RAM as tu pris ?
C'est quoi ton ventirad ?
Ton alim ?
Et si tu as fais des photos du montage final ?
 :jap:  Merci Gandalf
Message édité par fafa_monteco le 24-03-2006 à 12:41:44
Marsh Posté le 24-03-2006 à 12:54:55
Jolie... :love:
Superbe carte et très beau Topic Unique bien complet.
Mon Feedback : http://forum.hardware.fr/hardwaref [...] 9368-1.htm
Marsh Posté le 24-03-2006 à 16:07:09
youpi !
un deux participants a mon topic !
:hello: rorofox et fafa_monteco !!!
bienvenue !
Message édité par gandalf-ze-wizard le 24-03-2006 à 16:07:40
Marsh Posté le 24-03-2006 à 16:15:41
Ton alim ?
 :jap:  Merci Gandalf
alors, ma config :
alim : Hiper type-R 480W
RAM : Centon PC3200 LL (2.0 2 2 5 @ 200MHz 2.5 4 3 5 @ 300MHz)
ventirad : SI 120
pour l'installe de windows, pas de soucis, si ce n'est que j'ai (betement) le choix entre un windows 2k3 qui refuse le soft ABIT µGuru (monitoring) et un Win XP64, qui refuse ma carte wifi ...
lundi je demanderais a mon ecole une license XP 32 bits ...
je n'ai pas encore fait le montage complet ^^ (mais je vais aller chercher l'APN pour faire quelques photos d'ensemble ...)
pour les temperatures ca donne :
CPU : 37°
SYS (chipset) : 28°
PWM (MOSFET): 34°
Message édité par gandalf-ze-wizard le 24-03-2006 à 16:27:13
Marsh Posté le 24-03-2006 à 16:32:55
gandalf-ze-wizard a écrit :
alors, ma config :
ventirad : SI 120
CPU : 37°
SYS (chipset) : 28°
PWM (MOSFET): 34°
Ok merci Gandalf d'avoir repondu  :jap: en plus ça tombien puisque je voulais savoir si le SI120 etait compatible avec cette carte  :lol:
reste plus qu'à attendre les photos et tes premières impressions   ;)
Ah oui autre ptite question : Qu'est ce qui t'as fais pencher plutot pour cette mobo que la Asus A8N32 SLI Deluxe ?
Message édité par fafa_monteco le 24-03-2006 à 16:37:19
Marsh Posté le 24-03-2006 à 16:42:51
j'aime bien ABIT !
j'ai ete beaucoup plus convaincu a l'epoque par ma NF7-S que par la A7N8X Deluxe et donc apres un passage chez DFI, je retourne voir du cote ABIT !
les photos arrivent dans la soiree ...
et les premieres impressions dans le WE ...
Marsh Posté le 24-03-2006 à 16:55:14
j'aime bien ABIT !
là on est d'accord  :sol:
Marsh Posté le 25-03-2006 à 14:26:10
UP
Marsh Posté le 25-03-2006 à 19:39:45
desole pour le pas de photos ...
l'APN a ete requisitionne par mon frere pour le WE ...
Marsh Posté le 26-03-2006 à 14:59:15
Marsh Posté le 26-03-2006 à 18:23:34
Marsh Posté le 27-03-2006 à 09:47:33
Ah oui au fait j'ai oublié demandé  :hello:
Quand tu as monte ton SI120, est ce que tu as été obligé d'acheté une plaque de fixation pour mettre en dessous de la carte mere ?  :jap:
Marsh Posté le 28-03-2006 à 07:31:22
elle est fournie avec le radiateur ...
Marsh Posté le 28-03-2006 à 09:40:46
Ok merci
Marsh Posté le 28-03-2006 à 09:53:59
bah le bleu bah le rouge je preferai la fatality
de plus elle debarque un peu tard mais bon
Marsh Posté le 28-03-2006 à 10:59:00
que veux tu dire par la ?
tu fais reference a la couleur de l'OTES ?
franchement, si c'est le cas, c'est pas un probleme, le silence etant assez impressionnant parrapport a un ventirad sur le chip ...
Marsh Posté le 28-03-2006 à 11:10:28
Marsh Posté le 29-03-2006 à 10:32:45
SLI vs. SLI 16X
Message édité par gandalf-ze-wizard le 29-03-2006 à 10:36:36
Marsh Posté le 29-03-2006 à 12:29:06
Pas beaucoup de difference pour l'instant
Et autrement elle marche bien la ptitE an8 ?
Marsh Posté le 29-03-2006 à 13:11:08
elle marche tout a fait bien !
j'ai remplace ma DFI NF4 par la AN8 32X (en attendant d'avir un 2e CPU)
et j'en suis tout a fait satisfait !
pour l'instant, le SLI 16X n'a pas une grande consequence niveau perfs, mais la gestion du RAID 5 est tout a fait agreable !
en fait, au final, je n'ai qu'un regret concernant cette carte : lorsque on met le reglage du CPU sur 'custom' (pour regler coef, HTT et PCI-E), cela desactive automatiquement le Cool 'n Quiet ...
a par ca, que du bon !
Marsh Posté le 30-03-2006 à 16:25:52
bin alors, elle ne vous inspire pas cette carte moman ?
Marsh Posté le 30-03-2006 à 18:28:32
ba si  :sweat:
Marsh Posté le 30-03-2006 à 20:03:31
ceux qui n ont pas teste ABIT ne peut pas comprendre C' EST le N°1
Message édité par metm le 31-03-2006 à 21:27:11
Marsh Posté le 30-03-2006 à 20:05:31
si j ai bien compris pour le volte du cpu c'est Max 1.7 V
                                                et pour la ddr 1.6v
Marsh Posté le 30-03-2006 à 22:46:17
metm a écrit :
ceux qui n ont pas teste ABIT ne peut pas comprendre  N°1
je comprend pas ...
                                                et pour la ddr 1.6v
cpu : entre 1,4 et 1,8 V
ddr : entre 2,5 et 3,2 V
avec un modificateur entre -60mV et +60mV
Marsh Posté le 31-03-2006 à 21:25:03
ok je vien de trouver un lien il date d aujourd hui
http://www.bit-tech.net/hardware/2 [...] 32x/1.html
FSB teste a 340
Message édité par metm le 31-03-2006 à 21:29:49
Marsh Posté le 03-04-2006 à 16:58:57
voici un autre test pour cette mobo  :jap:
http://www.pro-clockers.com/article.php?id=125
Marsh Posté le 04-04-2006 à 10:57:26
merci pour tous ces liens !
Marsh Posté le 04-04-2006 à 18:44:02
de rien  :jap:
Marsh Posté le 05-04-2006 à 00:19:00
de rien
Marsh Posté le 08-04-2006 à 17:04:43
Marsh Posté le 08-04-2006 à 17:07:33
Marsh Posté le 12-04-2006 à 08:53:17
