[Topic unique] Gigabyte GA-N650SLI-DS4
Gigabyte GA-N650SLI-DS4 [Topic unique] - Carte mère - Hardware
Marsh Posté le 08-05-2007 à 12:27:02
Bonjour, je suis tombé par hasard sur la review VR-zone de la Gigabyte GA-N650SLI-DS4 et a ete tres surpris d'une de pas la connaitre et de deux du potentiel de cette derniere :pt1cable:
Il s'agirait apparamment d'une nouveauté chez Gigabyte.
by vr-zone:
There is no consideration when one is looking for a 650i SLI board - The Gigabyte is the choice!
http://www.gigabyte.fr/FileList/Image/motherboard_productimage_ga-n650sli-ds4_big.jpg
http://resources.vr-zone.com.sg/Shamino/giga650/1.jpg
Specs
Processor
   1. LGA775
   2. Support Intel® Core™ 2 Quad/Core™ 2 Duo/Pentium® D/Pentium® 4 Processor
   3. Supports 1333/1066/800 MHz FSB
Chipset
   1. NVIDIA® nForce 650i SLI (Northbridge: C55, Southbridge: MCP51)
   2. Onboard Marvell 88E1116 phy (10/100/1000 Mbit)
   3. Onboard Realtek ALC888 chip
   4. Onboard T.I. TSB43AB23 1394 chip
Memory
   1. 4 DDRII DIMM memory slots (supports up to 8 GB memory)(Note 1)
   2. Supports dual channel DDRII 800/667/533 unbuffered DIMMs
   3. Supports 1.8V DDRII DIMMs
   4. Supports DDR2 667/533/400 DIMM
   5. Supports ECC type DRAM
(Note 1) Due to the limitation of Windows 32-bit operating system, when more than 4 GB of physical memory is installed, the actual memory available for the operating system will be less than 4 GB; Windows 64-bit operating system doesn't have such limitation.
Internal I/O Connectors
   1. 1 24-pin ATX power connector
   2. 1 8-pin ATX 12V power connector
   3. 1 floppy connector
   4. 2 IDE connectors
   5. 4 SATA 3Gb/s connectors
   6. 1 CPU fan connector
   7. 1 system fan connector
   8. 1 North Bridge fan connector
   9. 1 power fan connector
  10. 1 front panel connector
  11. 1 front audio connector
  12. 1 CD In connector
  13. 1 S/PDIF In connector
  14. 2 USB 2.0/1.1 connectors for additional 4 ports by cables
  15. 2 IEEE 1394a connectors for additional 2 ports by cables
  16. 1 power LED connector
  17. 1 Chassis Intrusion connector
Expansion Slots
   1. 2 PCI Express x16 slots (Note 2)
   2. 2 PCI Express x1 slots
   3. 3 PCI slots
(Note 2) In SLI Mode, the two PCIE x16 slots can run at up to x8 respectively. In Normal Mode, only the first PCIE x 16 slot (PCIE_16_1) is available and can run at up to x16.
Rear Panel I/O
   1. 1 PS/2 keyboard port
   2. 1 PS/2 mouse port
   3. 1 S/PDIF Out connection (coaxial+optical)
   4. 1 parallel port
   5. 1 serial port
   6. 4 USB 2.0/1.1 ports
   7. 1 IEEE 1394a port
   8. 1 RJ-45 port
   9. 6 audio jacks (Line In / Line Out / MIC In/Surround Speaker Out (Rear Speaker Out)/Center/Subwoofer Speaker Out/Side Speaker Out)
Form Factor
   1. ATX
   2. 30.5cm x 24.4cm
H/W Monitoring
   1. System voltage detection
   2. CPU/System temperature detection
   3. CPU/System/Power fan speed detection
   4. CPU warning temperature
   5. CPU/System/Power fan failure warning
   6. CPU/System Smart Fan Control
BIOS
   1. 2 4 Mbit flash ROM
   2. Use of licensed AWARD BIOS
   3. Supports Dual BIOS
   4. PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
Other Features
   1. Supports @BIOS
   2. Supports Download Center
   3. Supports Q-Flash
   4. Supports EasyTune (Note 3)
   5. Supports Xpress Install
   6. Supports Xpress Recovery2
   7. Supports Xpress BIOS Rescue
* (Note 3) EasyTune functions may vary depending on different motherboards.
Petit comparo en chipset nvidia 650 sli Ou ll'on voit un petit 52O de fsb sur un X6800 Conroe
Abit Fatal1ty FP-IN9 SLI
ASUS P5N-E SLI
Overclocking
520FSB
475FSB
486FSB
CPU PWM
6-Phase
4-Phase
3-Phase
Voltage Control
Best
Average
Average
Price
USD$140
USD$130
USD$140
Tests/infos
-http://www.vr-zone.com/?i=4939&s=1 vr-zone
-http://www.gigabyte.fr/Products/Mo [...] 650SLI-DS4 infos constructeurs
-http://www.clubic.com/shopping-185 [...] i-ds4.html Prix
Message édité par mesmerize le 08-05-2007 à 12:47:10
Marsh Posté le 09-05-2007 à 10:21:11
up!
des news , quelqu'un a eu des échos de perf ou d' o/c avec cette carte?
mieux que la P5NE SLI? P5N32 SLI?
Marsh Posté le 09-05-2007 à 10:56:54
elle me parait bien, a voir par rapport a la p5nesli
C'est toujours au pied du mur qu'on voit mieux le mur
Marsh Posté le 15-05-2007 à 13:29:48
personne ne l'as achetée?
Marsh Posté le 22-05-2007 à 20:40:38
Je me suis lancé, ce sera moi le cobaye, commandé chez materiel.net aujourd'hui. Je suis plutot pro-nvidia et la review de vr-zone m'a convaincu. Avec ca un E6320 avec son Noctua NH-U12F, 2 gskill PC6400PK et une 8800 GTS. Je vous ferai un feed ici-meme dès que le tout sera réceptionné et monté.
Marsh Posté le 26-05-2007 à 16:20:19
Est-ce qu'il y a les caches sur les connecteurs 2x4 et 2x12 broches ? C'est pour savoir si je doit acheter les adaptateurs pour boucher les trous non utilisés car j'ai une alim 2x2 et 2x10 broches.
Marsh Posté le 01-06-2007 à 18:02:39
Je répond à ma question.
Il y a un cache sur le connecteur 2x8 broches, mais pas sur le connecteur 2x12 broches.
Marsh Posté le 11-06-2007 à 22:04:45
Est ce que cette carte concurrence les P5N E SLI ?
Ou la carte Asus est tellement supérieure que personne ne s'interesse à cette GB ?
Marsh Posté le 22-06-2007 à 10:34:27
Moi j'en ai acheté une de GA-N650SLI-DS4 et bien je ne suis pas déçu ! Mon E4400 tourne à 3,4GHz (10x340) à 1,39V :) J'ai 2x1Go de gskill PC6400PK et une 8800GTS 640Mo
Message édité par V1ru5 le 22-06-2007 à 10:44:25
Marsh Posté le 23-06-2007 à 13:24:55
la DQ6 devrait le faire aussi??? je me tape pour celle là.....car j'ai déja une DQ6 sans SLI
Marsh Posté le 23-06-2007 à 13:37:24
Gigabyte GA-N650SLI-DS4 > Asus P5NE-Sli
car utilisation de condo solides et non standard
et radiateur sur le southbridge = sur Asus = rien
Marsh Posté le 24-06-2007 à 15:04:07
Perso je suis un peu décu par mon oc mais je sais pas si c'est la mobo ou mon proc qui me limite. Je depasse pas 375mhz de fsb, mon 6320 tourne donc a 2.6ghz. Sinon belle carte mere bien agencé avec un bios très complet. Pour info, le bios F7 est dispo depuis le début du mois.
Marsh Posté le 26-06-2007 à 23:39:45
T'es sûr qu'il s'agit pas juste d'un FSB Hole ? Moi le mien ne boot pas entre 280 et 330 de FSB. Par contre à 340 ça tourne niquel !
J'ai pas essayé plus haut encore. ;)
Message édité par V1ru5 le 26-06-2007 à 23:40:30
Marsh Posté le 27-06-2007 à 14:38:50
D'après VR-Zone il y a un truc pour pouvoir monter haut en fréquence. Il faut régler manuellement la fréquence de la ram 2mhz plus vite que ce qu'elle devrait faire.
par exemple, avec ton fsb de 375mhz, la ram est régler sur 750+2=752mhz ;)
A tester.
Marsh Posté le 30-06-2007 à 05:09:14
Salut tous,
Bon. Je dois pas savoir m'y prendre : je ne parviens absolument pas à overclocker ma config.
Pour info :
- C2D E4300
- 2 x 1 Go PC6400 G.Skill HK (timings : 4-4-3-5)
- GA-N650SLI-DS4 (évidemment), flashée avec le BIOS en version F7
Quels que soient les réglages, au reboot j'ai droit à une longue attente, puis deux bips "bizarres" (pas aussi francs que le bip de reboot normal), et généralement un message d'erreur m'informant d'erreurs durant le POST.
J'ai tenté plusieurs fréquences, notamment :
- 2.8 GHz (en 7 x 400 MHz)
- 3 GHz (en 9 x 333 MHz)
Avec plusieurs voltages, de 1.35 à 1.50 V.
En mode Linked / Unlinked (en forçant la RAM à 800 MHz).
En désactivant l'arrêt sur erreurs durant le POST, en désactivant les "modes thermiques" (je vois pas de meilleure traduction, là).
Rien à faire : quand j'arrive à redémarrer, CPU-Z me donne un FSB de 200, point. 1.8 GHz semble être la limite, ce que je trouve vraiment bizarre compte tenu de la capacité d'overclock dont semble pouvoir faire preuve le E4300 (surtout couplé à cette carte mère).
Un autre truc bizarre, au passage : je ne vois dans le BIOS aucune option pour régler les timings de la RAM. Du coup, je suis en 5-5-5-15 d'après CPU-Z, ce qui est quand même ultra-moyen compte tenu du SPD de la RAM.
Je pige pas, et accepterai tout commentaire ou idée sur le sujet.
Merci d'avance !!
Message édité par agyar le 30-06-2007 à 11:30:47
Marsh Posté le 30-06-2007 à 11:29:59
Bon, je me réponds tout seul sur un point : la configuration des timings de la RAM. C'est ma très grande faute : j'aurais lu le manuel avant de poster, j'aurais pu voir qu'il faut faire [CTRL]+[F1] dans le menu de configuration du BIOS pour accéder aux réglages avancés.
Bref, ça c'est fait et ne pose apparemment pas de problème.
Reste à overclocker le proce, et là je cherche toujours (mais j'ai du temps aujourd'hui : je vais continuer à chercher).
Message édité par agyar le 30-06-2007 à 15:06:40
Marsh Posté le 30-06-2007 à 18:13:03
Bon. Ca commence à venir, mais j'ai quand même beaucoup de mal à monter en fréquence. Vu que je débute dans le domaine, je m'y prends sûrement pas comme il faudrait ?
Je suis arrivé à 2,4 GHz, avec un coef. de 9 et un FSB de 266 MHz.
Mais bon, pour ça j'ai sévèrement monté le voltage des composants : +0,2 V partout, sauf le CPU (+0,5 V).
J'ai aussi dû abaisser le "LDT Frequency" à 4x, et j'ai désactivé les Spread Spectrum (par précaution), "CPU Enhanced Halt (C2)" et EIST (un truc un peu curieux : cette option n'apparait plus dans les options avancées du BIOS (?!)).
J'ai tenté de monter plus haut, mais rien à faire : le PC ne boote plus, et  finit par faire un "Safe boot" (constaté à 300 MHz de FSB).
Un autre truc curieux : j'ai tenté d'obtenir la même fréquence CPU avec un coef. de 6x et un FSB de 400 MHz, histoire d'être synchro avec la RAM. Même en montant la tension NB/HTT à fond (+0,35 V), rien à faire : ça ne démarre pas plus.
Ca vous paraît normal, ce comportement des composants ??
EDIT : bon, en fait le "LDT Frequency" ne change rien à l'affaire (bien que ça me semble très étonnant, il semblerait que ce soit un paramétrage spécifique aux processeurs AMD, et lié à la fréquence du bus HTT, mais tout n'est pas clair sur ce point). Du coup, en 5x ça passe quand même ; le point crucial semble bien être le voltage du northbridge : si je le redescends d'un cran (+0.30 V), plus de boot possible.
J'ai monté le FSB à 275 MHz, mais impossible d'aller plus loin : soit Windows freeze complètement, soit (beaucoup plus soufvgent) le PC ne boote simplement pas.
Message édité par agyar le 01-07-2007 à 00:01:20
Marsh Posté le 04-07-2007 à 16:15:03
Ben on dirait que la GA-N650SLI-DS4 n'intéresse pas grand-monde, en fin de compte : quand on voit la fréquentation du topic Asus P5N-SLI, bah ça n'a rien à voir, quoi...
Tant pis pour moi, je plafonne à 2,4 GHz (ce qui est déjà pas si mal, c'est vrai).
Marsh Posté le 04-07-2007 à 17:52:08
Non juste que la Asus est beaucoup plus connue alors que la Gigabyte est de bien meilleure qualité avec une meilleure alimentation, un meilleur refroidissement du northbridge ... et elle est meilleure en o/c d'après le test ci dessus.
Je voulais l'acheter mais mon magasin ne l'avait pas avant 1 mois et j'ai pas pu attendre :pt1cable:
Marsh Posté le 04-07-2007 à 18:16:44
Bah, sans vouloir faire de pub : Materiel.net propose PLEIN de matos, avec un délai de livraison record si le matériel est en stock, et à des prix raisonnables (plus chers que Montgallet, mais en même temps, Montgallet c'est moins cher que pas cher).
Leur SAV est bon en cas de pépin, et je dois avouer n'avoir aucun reproche à leur faire (ce qui semble être le cas de beaucoup de leurs clients, y a qu'à lire les commentaires laissés sur les articles proposés).
Bref : si t'es pressé et qu'il n'y en a pas à ton magasin, ça peut être un bon plan ;)
Merci pour ton commentaire sur cette CM : je commençais à me poser des questions (même si ça ne change rien au fait que je n'ai pas pu overclocker mon E4300 autant que  je l'aurais voulu).
Marsh Posté le 04-07-2007 à 19:19:39
Je pense que le pb d'overclocking vient de toi => essaies de regarder comment faire dans le topic unique P5N-E SLI car puisque c'est le même chipset, ca s'overclocke de la même manière.
Marsh Posté le 04-07-2007 à 19:20:53
Ils sont à l'avance, chez gigabyte :)
Marsh Posté le 05-07-2007 à 09:26:53
Gigabyte commandée hier soir pour voir la différence avec ma Asus P5NE sli et son Vdroop de fou 0.05 V.
J'espére avoir la meme facilité à monter en frequence mon E4300 ??
Sinon la gigabyte à l'air trés prometteuse.
Je donnerai des infos quand elle sera montée.
Marsh Posté le 07-07-2007 à 18:19:44
carte reçue hier,montage facile,boot sans soucis.
-Bien meilleure pour overclocker mon E4300 que l'Asus,aucun Vdroop donc j'ai pu pousser un peu mon proco jusqu'a 3.45 ghz avec 1.57 V de Vcore et pour l'instant je le teste à 3.3 ghz c'est 200 Mhz de plus que sur l'Asus.
-De plus ma mémoire OCZ est enfin bien gerée,l'Asus me mettait n'importe quoi en timing et j'avais jamais pu la pousser.
-Je l'ai torturée et a chaque fois elle a rebootée:aucun clear Cmos !!!!!
-La Giga fait mieux finie que l'Asus et le radiateur du chipset me permet de rester en passif.
Moi qui n'avais pas repris de Gigabyte depuis deux ans je suis trés impressionné des progrés de cette marque.
La meilleure carte en 650sli !!!!
Marsh Posté le 07-07-2007 à 19:45:17
avis très intéressant :)
merci albundy88
Marsh Posté le 08-07-2007 à 17:45:04
deux jours stable à 3.3Ghz avec 1.55v vcore ce qui fait 1.53v reél et pas de Vdroop!!!
Le radiateur du chipset est brulant mais pas de plantage alors que la P5NE plantait depuis l'installation de ma 8800 GTS,j'avais dû la watercoolée.
Flashée avec le dernier bios sans soucis.
J'arrive à booté à 3.5 ghz mais il me faut 1.6 v de Vcore pour stabiliser:la carte le supporte sans probléme mais le proc commence à chauffer pas mal malgré mon watercooling.
Vu la fréquence atteint par mon E4300 qui est limité en FSB,je pense qu'un E6600 sur cette carte ferait des merveilles ou un 6750 quand il sortira.
Marsh Posté le 08-07-2007 à 17:54:20
cette carte mère me tente vraiment y a pas à dire, dommage juste qu'elle soit à prix très intéressant (101€) dans une boutique à fuir uniquement (microchoix), dès qu'on cherche dans des boutiques fiables c'est 115€
Message édité par DivX le 08-07-2007 à 17:55:40
Marsh Posté le 08-07-2007 à 19:46:07
Perso toujours impossible de booter a plus de 375mhz de fsb avec mon e6320. La carte reboote systématiquement à 380, 400 et 410 mhz de fsb en utilisant les memes réglages que vr-zone. J'ai eu une lueur d'espoir a 425mhz car la carte a booté correctement mais là c'est windows qui plante direct  :sweat:  Albundy88 possible d'avoir les réglages bios de ton oc. Ya peut etre un truc que j'ai oublié de modifier...
Marsh Posté le 08-07-2007 à 20:59:16
Pour mes reglages le E4300 a un coeff de 9 donc j'ai pas essayé plus de 385 Mhz:
V nb=+0.35v
v fsb=+0.35v
v cpu=1.6v
ldt=x2
Ram unlinked 800 mhz.
Essaie ram linked synchro pour depasser les 400mhz si tu as de la bonne ram.
Essaie aussi en baissant le coef de ton proc pour voir si c'est le voltage du chipset qui pose probléme ou le proc(augmente le voltage du proc à 1.5v pour tes essais aprés tu essaieras de la baisser)
Voila si ça peut aider
Marsh Posté le 11-07-2007 à 12:30:55
on peut monter un Noctua NH-U12F sur cette carte ?
Marsh Posté le 11-07-2007 à 12:33:01
bon finalemeent j'ai ma reponse :
oui : seulement en orientation horizontale (à cause de l'hauteur du radiateur chipset)
Marsh Posté le 13-07-2007 à 13:44:30
Merci pour les infos Albundy88, j'ai réussi à aller jusqu'au bureau a 425/850 avec tes réglages mais dès que je lance une appli c bsod assuré. De toute facon mon aircooling est trop juste pour mettre de tels voltages (je suis a 50° en idle avec un vcore de 1.5) donc je vais rester bien gentiment a 2.6ghz pour l'instant. En tout cas il y a bien un fsbhole entre 375mhz et 410mhz sur cette mobo, jai vu quelques témoignages sur des forums américains qui confirment ca.
Dernière question, ya un interet a augmenter la frequence de la mémoire     le plus haut possible en la delinkant de la frequence du fsb ou pas?
Marsh Posté le 13-07-2007 à 13:45:56
drapal
Marsh Posté le 16-07-2007 à 22:32:53
Drapal aussi, je cherche la cm ultime pour le SLI  [:alphat]
Mon topic - Mon Feed-Back
Marsh Posté le 16-07-2007 à 22:36:59
Si tu veut la carte mere ultime beh sa : ^^'
Moi te suivre? :non:
Marsh Posté le 16-07-2007 à 22:45:45
ha ouais quand même :D
Marsh Posté le 16-07-2007 à 22:50:02
Marsh Posté le 16-07-2007 à 23:24:16
OWNED ^^
Marsh Posté le 17-07-2007 à 15:19:52
tites questions :
quelles sont vos températures du Northbridge ? (en utilisation normale)
parce que ca m'intrigue, chez moi la température du radiateur du Northbridge dépasse les 50°C (pas de thermomètre allant au delà :D),
de plus, je ne sais pas tellement quelle sonde correspond au Northbridge sous Speedfan. (je n'ai rien o/c, tout est d'origine)
sinon, j'ai du mal à avoir le son de la CM, j'ai dù utiliser ma vieille carte son pour l'avoir, dans le gestionnaire de périphérique il ne détectait pas de périph audio, étrange non ? (j'ai installer les drivers du CD, rien, puis ceux sur le site de Gigabyte, toujours rien)
Message édité par Pick Of Destiny le 17-07-2007 à 15:20:31
Marsh Posté le 17-07-2007 à 21:59:23
Pour la temp Northbridge,il n'y a pas de sonde mais il est trés chaud je dirai dans les 60 ° chez moi.Pas d'inquiétude un chipset ça supporte plus mais je crois que je vais le watercooler surtout pour eliminer une source de chaleur dans mon boitier.
Pour l'audio,j'ai une Xfi donc je ne sais pas!!Tu as bien la carte activée dans le bios???
