[Topic Unique] Asus P9X79
Asus P9X79 [Topic Unique] - Carte mère - Hardware
Marsh Posté le 16-02-2012 à 10:06:04
http://www.asus.com/websites/Global/products/ITjeO1wq0nRUPfej/aMmVuvK6yJ1jJe9I_500.jpg
Vidéo de présentation:
http://www.cowcotland.com/news/295 [...] 9-pro.html
Tests:
http://www.overclex.net/articles/asus-p9x79-pro/
http://www.overclocking-pc.fr/inde [...] &Itemid=59
http://www.legitreviews.com/article/1767/1/
P9X79:
Specifications
CPU Intel® Socket 2011 for 2nd Generation Core™ i7 Processors
Supports Intel® Turbo Boost Technology 2
* Refer to www.asus.com for CPU support list
Chipset Intel® X79
Memory 8 x DIMM, Max. 64GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Quad Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to www.asus.com or user manual for the Memory QVL (Qualified Vendors Lists).
Multi-GPU Support Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD Quad-GPU CrossFireX™ Technology
Expansion Slots 2 x PCIe 3.0/2.0 x16 (dual x16) *1
1 x PCIe 3.0/2.0 x16 (x8 mode) *1
2 x PCIe 2.0 x1
1 x PCI
Storage Intel® X79 chipset :
2 x SATA 6Gb/s port(s), white
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
ASMedia® ASM1061 controller :
1 x Power eSATA 6Gb/s port(s), green
1 x eSATA 6Gb/s port(s), red
LAN Intel® 82579V, 1 x Gigabit LAN Controller(s)
Audio Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- Blu-ray audio layer Content Protection
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
IEEE 1394 VIA® 6315N controller
1 x IEEE 1394a port(s)
(1 at back panel)
USB Ports ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (4 at back panel, blue)
14 x USB 2.0 port(s) (6 at back panel, black+white, 8 at mid-board)
Special Features ASUS Dual Intelligent Processors 3 with New DIGI+ Power Control :
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 8 + 2 Phase CPU Power Design
- Industry leading Digital 2 + 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- Ai Charger
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- USB 3.0 Boost
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert+
ASUS EZ DIY :
- USB BIOS Flashback
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports 1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 6Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
4 x USB 3.0
6 x USB 2.0 (one port can be switched to USB BIOS Flashback)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x USB BIOS Flashback Button(s)
Internal I/O Ports 4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s) (4 -pin)
4 x Chassis Fan connector(s) (4 -pin)
1 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS 64 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.6, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note *1: This motherboard is ready to support PCIe 3.0 SPEC. Functions will be available when using PCIe 3.0-compliant devices. Please refer to www.asus.com for updated details.
P9X79 PRO
Specifications
Chipset Intel® X79
Multi-GPU Support Supports NVIDIA® 3-Way SLI™ Technology
Expansion Slots 3 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8) *1
2 x PCIe 2.0 x1
Marvell® PCIe 9128 controller :
2 x Power eSATA 6Gb/s port(s), green
Bluetooth Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports ASMedia® USB 3.0 controller : *2
6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+white, 6 at mid-board)
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
- MemOK!
- AI Suite II
- Ai Charger
- ASUS SSD Caching
- USB 3.0 Boost
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert+
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports 1 x Bluetooth module(s)
4 x USB 3.0
6 x Audio jack(s)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on button(s)
1 x Reset button(s)
I/O Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x SLI bridge(s)
ASUS Utilities
ASUS Update
*2: 4 x USB 3.0 ports at back panel with 1 additional VIA SuperSpeed USB hub controller
Message édité par muaddib6969 le 16-02-2012 à 10:31:43
Marsh Posté le 17-02-2012 à 01:36:18
impossible d'installer asus AI suite sous win 7 64bits, vous avez réussi vous?
Marsh Posté le 18-02-2012 à 01:20:11
Bon la méthode c'est d'installer d'abord la version du CD qui elle marche et apres upgrader avec les dernières versions ASUS.
Marsh Posté le 18-02-2012 à 01:48:27
oui exact, moi j'ai mis celle du cd d'abord
Jc
Marsh Posté le 18-02-2012 à 14:39:06
les ports usb s'eteignent avec l'ordi, ca vous le fait aussi? j'aimerais bien que ca continue de charger ma souris.
Marsh Posté le 19-02-2012 à 01:50:01
je ne sais pas, je ne l'éteins jamais ... mais je crois que le premier en haut à gauche est fait pour ça.
Jc
Marsh Posté le 19-02-2012 à 10:51:24
L'oc tuner a l'air bien fichu sur les Asus x79. Pour ma part, j'obtiens avec un 3930K une solution à 4.3 ghz avec 1.288 vcore. En stress test : 55 degrés avec un corsair H100 en low.
Marsh Posté le 19-02-2012 à 17:36:13
ben moi je me suis servi de ça aussi, sous windaube j'ai de suite sélectionné extrème lol
résultat : 4,8 Mhz avec 1,45 volt par contre le H100 est à fond Mdrrrr
Jc
Marsh Posté le 19-02-2012 à 18:34:30
Jc
A rectifier manuellement dans ce cas parce que 1,45 vcore, cela commence à faire beaucoup.  :D
Je ne sais pas pourquoi, mais vu le prix des procos en X79, on peut être tenté par la modération en overclocking.  :p
Marsh Posté le 20-02-2012 à 08:56:30
pour l'instant en vitesse d'origine 23° au repos, 33 en occt, ca va j'ai de la marge.
Marsh Posté le 20-02-2012 à 21:18:14
un truc chiant l'asus auto tune descend la vitesse de la ram lors de son OC, je tiens a mes DDR-1600 moi
Marsh Posté le 21-02-2012 à 00:00:21
alors pour la durée de vie du proco, je ne fais pas de souci.
ensuite j'ai le même problème avec la mémoire et moi c'est de la 2133 !
je pense que je vais refaire ça via le setup du bios
Jc
Marsh Posté le 06-03-2012 à 18:39:55
Bonsoir,
y'a t'il une utilité à prendre une p9x79 pro au lieu d'une p9x79 ?
Marsh Posté le 06-03-2012 à 23:06:07
si tu veux faire un peu d'OC la pro est plus costaude.
Le mieux est d'utiliser l'outil de comparaison sur le site d'asus.
Marsh Posté le 07-03-2012 à 00:24:49
p9x79 et i7 3820 quelqu'un a testé?
sur le net on peut lire que ca boot pas!!
c'est la combinaison cpu/motherboard que je veux acheter prochainement...
sur le site de asus ils disent qu'il pourrait  avoir une mise a jour du bios a faire...est-ce que ca ce fait rapidement une mise a jour du bios?
Marsh Posté le 07-03-2012 à 00:41:33
pour retrouver ma mémoire à sa vitesse, je suis passé par le bios finalement.
là c'est 100 x 46 à 1,432 et les 32 Gb de mémoire sont en 2133 Mhz.
Jc
Marsh Posté le 07-03-2012 à 22:42:12
les MAJ de bios c'est trop facile. tu fous le truc sur une clé usb et hop via le bios ca se fait tt seul.
Message édité par muaddib6969 le 07-03-2012 à 22:43:09
Marsh Posté le 08-03-2012 à 09:36:07
J'ai trouvé un sujet comme quoi le gars arrivait pas à booter sa P9X79 avec son i7 3820 mais il n'avait pas branché les 4 pins restant de sont alim sur la carte mère.
J'ai pris cette config et je tiens au courant...
Marsh Posté le 08-03-2012 à 15:20:35
Sous entendu la normal n'est pas fait pour et donc impossible de taquiner les 4ghz avec le i7 3820 ?
Marsh Posté le 08-03-2012 à 19:12:13
je pense que ca devrait le faire vu que tu montes de base a 3.9ghz en turbo ca devrait aller.
Marsh Posté le 09-03-2012 à 07:56:27
D'acc' !
On verra bien...
L'oc ne sera surement pas pour tout de suite
Marsh Posté le 19-03-2012 à 11:36:25
Je remonte le sujet.
Config montée, pas de souci. L'association i7 3820 et p9x79 marche très bien !
Marsh Posté le 20-03-2012 à 20:12:45
Quelqu'un peut m'expliquer à quoi servent les switch TPU et EPU sur la carte ?
Faut-ils les activer pour overclocker ou les désactiver ?
Mon Feed-back
Marsh Posté le 21-03-2012 à 09:41:15
TPU overclocking automatique et EPU économie d'énergie. RTFM...
Topic de vente: http://forum.hardware.fr/hfr/Achat [...] 8206_1.htm
Marsh Posté le 06-04-2012 à 17:41:19
Je profite de ce topic pour poser une question par rapport à ma carte , une p9x79 WS.
J'ai une 580 que j'avais installé sur le 1er port noir, mais je n'avais pas vu que c’était un x8.
Du coup je l'ai mis sur le 2eme port bleu (un x16) (le 1er est impossible à utiliser car la backplate touche les ports des rams...)
J'ai aussi une gt210 que j'ai mis sur le 1 port noir (un x8) et une asus xonar stx sur le dernier port noir (aussi x8).
Mais la 580 est d’après gpuZ en x8, je ne comprend pas pourquoi, est ce que le fait qu'elle est été installé au début sur un port x8 l'aurait bloqué en x8?
Quelqu’un aurait une idée?
EDIT: Je m'auto répond: les ports bleus ET noirs sont connectés donc si une carte est sur un noir et une autre sur un bleu , tout passe en x8.
Message édité par bugfx32 le 18-04-2012 à 01:18:41
Ryzen 7800x / Strix 670E  / 64go Gskill / 6 To SSD /Strix 3090 + Titan X / Seasonic P1000 / Full Watercooling
Marsh Posté le 11-04-2012 à 21:46:28
J'aimerai avoir votre avis sur cette carte, et notamment sur la température qu'atteint  ma conf actuelle :
Boitier corsair 600t white
Cm : p9x79 deluxe
Cg : asus gtx570
Proc : 3930k
Ram : 16 go de gskill pc17000 cl9
Refroidissement proc :h100, installé en push sur le dessus du 600t (ventilos changé par noctua nf-p12 pwm
4 ventilos noctua (nf-s12b) en extraction sur la Grille mesh latérale
Actuellement, la carte mère monte très rapidement ds les 28, 30ºc et le proc à 35ºc rien que dans le bios...
Lors de mon installation de windows, le proc est monté à 40ºc, alors que je ne l'ai pas oc...
Est ce que ça vous semble normal ?
Notamment gaazzzz, tu dis que ton proc est à 20ºc en idle, et j'en suis bien loin...pourtant il me semble qu'on à peu près la méme conf...
En plus, j'ai un souci avec la carte mère qui ne démarre plus : écran noir au dèmarrage + vga_led alumée + code q_code à 94 => retour sav car plus de détection des ports pci...
J'ai essayé différents ports et deux cartes graphiques différentes, ça n'a rien changé.
Je fini par croire que j'ai vraiment tiré un mauvais numéro...
Mais surtout, j'aimerai savoir si les températures vous semblent normales ou pas, pour orienter la recherche du ou des problèmes de ma carte au niveau du support technique d'asus...
Gaazzzz, comment as - tu monté ton h100 ? En push/pull ? Sur le dessus du boitier?
Car j'aimerai bien savoir également si je n'aurai pas un souci avec mon h100, qui d'ailleurs fait entendre sa pompe plus que mes noctuas....
D'avance un grand merci pour votre aide.
Tassin
Marsh Posté le 12-04-2012 à 06:46:25
Tout dépend de la température ambiante aussi.
Si ton PC se trouve dans une pièce où l'air est à 24°, tu n'auras pas un proco refroidi à l'air à 20°
Mon Feed-back
Marsh Posté le 12-04-2012 à 08:45:47
Ben là j'étais plus proche des 18 degrés ambiants, donc une bonne marge qd même....et ce qui m'étonne, c'est la montée aussi rapide en température rien que dans le bois, même si cette dernière reste stable ensuite (heureusement encore )
Tassin
Marsh Posté le 14-04-2012 à 22:58:32
Pour la température CPU la CG joue bcp, je suis passé d'une 4850 a une 7950 j'ai pris 8°c sur le proc qui est juste au dessus.
Marsh Posté le 16-04-2012 à 12:56:07
nouveau bios dipos:
P9X79 PRO BIOS 1010
1. Improve system stability.
2.Improve memory compatibility.
3..Enhance compatibility with some USB devices.
4.Fix PCIEx16 VGA card HD 7970 cannot be detected when the temperature of VGA less than -40.
Marsh Posté le 16-04-2012 à 13:59:20
Bonjour muaddib6969,
Tout d'abord merci pour ta réponse sur le sujet.
Je pense également, mais on verra ça au retour de ma carte mère, que la température que j'ai mesurée dans le bios était forcement plus importante que sous windows, vu que mes ventilos tournaient très lentement (300 tr/mn car noctua pwm au mini). sous windows, avec la suite d'asus, je les avais réglés pour tourner entre 900 et 1300 tr/mn, ce qui devait augmenter l'efficacité du refroidissement du proc par le H100... mais je n'ai pas eu l'occasion de réellement en mesurer le résultat, vu que le pc a planté juste après :(, et n'a jamais redémarré...
Là où j'ai un doute, c'est sur la montée en température de la carte mère, et cela est peut être justement du à sa défaillance...
wait and see comme on dit...
cdt
Tassin
Marsh Posté le 18-04-2012 à 00:36:58
Bonjour , je possède aussi cette carte mère.
quand je rentre dans le bios , je vois une température comprise entre 20 et 25 C° pour le processeur.
Cependant quand j'utilise speedfan je vois qu il m'indique "CPU = 103 C°" sachant que la température des cores est d'environs 30° après des heures (donc bien après la lecture des 20 / 25 C du bios)
Donc je me suis demandé quelle valeur me donne le bios ? la vraie température du processeur ? ou la température d'un core ?
Si c'est le CPU alors speedfan disjoncte ?
merci.
Marsh Posté le 18-04-2012 à 01:54:15
En fait là j'ai overclocké à 4,6Ghz et mon proc est en ce moment à 37° par contre en charge core temp me dit que certains core atteignent les 70° ce qui ne m’inquiète pas plus que ça ;)
mon H100 est monté en haut du boitier avec le radiateur à l'intérieur et les ventilo à l'extérieur (sous la grille mesh).
à noter, le bios vient de changer pour la asus p9x79 pro !
Jc
Marsh Posté le 18-04-2012 à 12:58:05
Jc
Salut et merci pour ta réponse.
Nous avons donc la même installation, mais j'atteins déjà ces températures sans avoir oc mon proc... => certainement un pb avec la carte... wait and see, j'ai transmis le problème au support technique d'asus pour qu'ils vérifient également la température de fonctionnement de la carte, lors des différents tests qu'ils effectuerons dessus !
Tu as changé les ventilos du H100 ou pas ? ils sont branchés sur la pompe ou la carte ?
cdt
Tassin
Marsh Posté le 18-04-2012 à 14:27:39
attention les core peuvent monter plus haut en temp que le processeur global. Il faut regarder vi OCCT qui le montre bien.
Marsh Posté le 19-04-2012 à 22:43:02
nouveau bios encore
P9X79 PRO BIOS 1104
1.Improve Improve system stability.
2.Enhance compatibility with some USB devices.
Marsh Posté le 20-04-2012 à 08:28:24
nouveau bios dipos:
P9X79 PRO BIOS 1010
Et bien je peux dire qu'ils sont réussi leur coup avec ce BIOS !!!
Avec la version précédente, je n'avais que des écrans bleus.
Après cette mise à jours 1010, plus rien. Très bonne stabilité (j'avais quand même déinstaller quelques drivers (gestion usb 3 et sata) mais je n'ose plus les réinstaller :D)
J'hésite à mettre la version 1104. Des retours ?
Marsh Posté le 20-04-2012 à 09:49:33
Tu pourras toujours repasser sur le 1010...
Marsh Posté le 20-04-2012 à 21:15:06
pour avoir mis aussi vite à jour le bios entre 2 version, je suspecte un gros bug dans la 1010. Donc il vaut mieux passer la 1104.
Je suis dessus la, pas de pb particulier
Marsh Posté le 21-04-2012 à 09:17:51
+1
Mon Feed-back
