Asus P5K Deluxe - P5K - P5K-E - P5K-SE - P5K Premium [Topic Unique] - Carte mère - Hardware
Marsh Posté le 31-05-2007 à 10:44:16
P5K
CPU
* LGA775 socket for Intel® Core2 Quad / Core2 Extreme / Core2 Duo / Pentium® Extreme / Pentium® D / *Pentium® 4 Processors  / Peryn 8x00
* Compatible with Intel® 05B/05A/06 processors
* Support Intel® next generation 45nm multi-core CPU
Chipset
* Intel® P35 / ICH9 with Intel® Fast Memory Access Technology
Front Side Bus
* 1333 / 1066 / 800 MHz
Memory
* 4 x DIMM, max. 8GB, DDR2 1066*/800 / 667 MHz, non-ECC, un-buffered memory Dual channel memory architecture
Expansion Slots
* 2 x PCI-E x16 (blue @ x16 mode, black @ x4 or x1 mode) supports CrossFire Technology
* 1 x PCI-E x1
* 3 x PCI
Storage
* 4 x SATA 3.0 Gb/s ports /!\ Attention pas de RAID avec les ports internes /!\
* 1 x UltraDMA 133/100/66 for up to 2 PATA devices
* 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
* Supports SATA RAID 0,1 and JBOD
Lan
* Gigabit LAN controllers, featuring AI NET2 Marvell88E8056® PCI-E Gigabit LAN controllers
Audio
* Realtek® ALC883 8-channel
IEEE 1394
* Texas Instrument
USB
* 10 x USB 2.0 ports (4 ports at mid-board, 6ports at back panel)
P5K-E
CPU
Chipset
* Intel® P35 / ICH9R with Intel® Fast Memory Access Technology
Front Side Bus
Memory
Expansion Slots
* 2 x PCI-E x1
* 3 x PCI
Storage
* 6 x SATA 3.0 Gb/s ports
* Supports RAID 0 and 1
* 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Lan
Audio
* ADI® AD1988B 8-channel High Definition Audio CODEC
IEEE 1394
* Agere® FW322 1394a controller supports 2 x IEEE 1394a ports (one at midboard; one at back panel)
USB
P5K-SE
CPU
Chipset
* Intel® P35 / ICH9
Front Side Bus
Memory
* 4 x DIMM, max. 8GB, DDR2 800 / 667 MHz, non-ECC, un-buffered memory Dual channel memory architecture
Expansion Slots
* 1 x PCI-E x16
* 3 x PCI-E x1
* 2 x PCI
Storage
Lan
Audio
* Realtek ALC883
USB
* 12 x USB 2.0 ports
Tests
http://www.overclex.net/hardware/2 [...] -E-Wifi-AP
http://www.xbitlabs.com/articles/m [...] s-p5k.html
http://www.syndrome-oc.net/articles.php?article=112
Test D@rknico : http://forum.hardware.fr/forum2.ph [...] 0#t5602741
Informations diverses sur les P5k et P5k-E
** Pas de gestion RAID 0 et 1 avec les port SATA Int sur la P5K, pour avoir du RAID il faut passer par un connecteur interne et le port externe eSATA (pas terrible quoi).
** Les P5K et -E semble avoir un soucis de vdrop bien plus important que sur les modeles Deluxe et Premium
** A priori y a un vdroop (difference entre la valeur bios/windows) d'au moins 0.04V suivi d'encore 0.04V de vdrop en charge ce qui donne quand meme 0.08V de difference (merci Toonix pour les infos   )
** La Famille P5K gere parfaitement les nouveaux proc Intel 8x00 (normal quoi)
** les HDD HITACHI DESKSTAR reférence HDP725040GLA360, HDP725050GLA360 et HDP725060GLA360 ne fonctionnerait pas en RAID sur le contrôleur ICH9r (test avec 7 HDD et trois cartes mères [une P5E et deux P5K-e WIFI/AP], différents XP et DRIVER ICH9r...
Quelques solutions :
*Activer le CPU Voltage Damper
*Passer au VMod (a vos risque et perils)
---> http://overclocking-masters.com/fo [...] ,t5791.htm
*P5K: le son est haché, saccade et/ou le mouvement de la souris est saccadé
Essayez de mettre à jour le driver du chip JMicron (périphérique "JMicron JMB36X Controller" dans la section "Contrôleurs SCSI/RAID" du gestionnaire de périphériques) en le téléchargeant directement sur le site de JMicron.
---> http://www.jmicron.com/Driver.htm
*P5K: mon port IDE et/ou mon port réseau ne fonctionnent pas
Vérifiez qu'aucun port USB n'est branché sur le connecteur interne USB11-12 (situé entre le processeur et la carte graphique). Si c'est le cas, branchez-le sur un autre connecteur USB (USB7-8 ou USB9-10 situés près de la pile du CMOS).
*P5K: y a des bruits parasites et grésillements qui peuvent être entendus sur la prise casque des P5K, brancher le casque sur la sortie arrière "enceinte" corrige tout problême. Par défaut, soundmax va vous demander de déplacer votre casque vers l'avant, mais refusez, et dites lui que vous avez branché des speakers (et pas votre casque). Votre casque ainsi connecté sur la sortie "enceintes" située à l'arrière devrait fonctionner sans le moindre parasite.
Marsh Posté le 31-05-2007 à 10:44:27
6) Liens divers
  Tableau récapitulatif de toutes les versions Asus P35
 Tableau récapitulatif de toutes les versions Asus P35   New
 New
>>> ici http://support.asus.de/faq/faq_rig [...] uage=en-us <<< ici
Drivers P5K
http://www.clubic.com/telecharger- [...] s-p5k.html
Drivers P5K-E
http://www.clubic.com/telecharger- [...] p5k-e.html
Drivers P5K-SE
http://www.clubic.com/telecharger- [...] 5k-se.html
Test de la P5K Premium
http://materiel.froggytest.com/mod [...] icleid=191
http://www.01net.com/fiche-produit [...] p-edition/
http://www.clubic.com/article-7935 [...] guide.html
http://www.syndrome-oc.net/article [...] =2&lang=fr
Test de la P35 Blitz Formula
http://materiel.froggytest.com/mod [...] icleid=201
http://www.jmax-hardware.com/index [...] 0&Itemid=1
http://www.syndrome-oc.net/article [...] =3&lang=fr
Marsh Posté le 31-05-2007 à 10:59:29
Voila, comme le topic concernant le P35 parle majoritairement de cette carte mere je me permet donc de créer un topic unique a celle ci ! Si vous avez des commentaires, des informations diverses et variées que vous pensez obligatoire dans un topic unique, merci de m'en faire part !
Marsh Posté le 31-05-2007 à 11:40:27
ReplyMarsh Posté le 31-05-2007 à 11:42:32
| greg06800 a écrit : tu devrais rajouter topic unique dans ton titre... |
j'allais le dire
Marsh Posté le 31-05-2007 à 11:59:30
oki doki
Marsh Posté le 31-05-2007 à 12:07:41
il n'y a pas de port com
Marsh Posté le 31-05-2007 à 12:09:45
| Citation :   |
Apparement si tu un un bracket avec un port COM tu peu le relier direct a la mobo ! A noter qu'il n'y a pas de port PS2 pour la souris, adaptateur PS2>USB obligatoire !!!
Marsh Posté le 31-05-2007 à 12:10:38
oui enfin pour un onduleur c'est plus genant
Marsh Posté le 31-05-2007 à 13:02:17
J'ai 3 remarques sur cette carte et son utilisation .
1 ) je n'arrive pas à faire fonctionner asus probe . En effet lorsque je le lance , il s'inscrit dans les processus mais il ne s'affiche pas ! Heureusement speddfan fonctionne très bien avec cette carte !
2) le bios 311 est moins bon en terme d'overclocking  de la mémoire .  Avec mes kingston 8500 , je peux
tenir 540 mhz en cas 44412 à 2.30 volt avec le bios 307 alors qu'avec le 311 il faut que je mette 2.35 volt pour obtenir le même résultat .
3) Il est impossible d'activer l' AAM avec cette carte . le reglage disparait au reboot .
Marsh Posté le 31-05-2007 à 13:04:49
J'ai hâte de recevoir la mienne, déjà pour vérifier dans un premier temps son comportement et la reconnaissance des divers composants sous linux (dans le pire des cas asus propose l'ensemble des drivers pour linux en téléchargement et ça c'est vraiment bien  )
Marsh Posté le 31-05-2007 à 13:26:45
slt merci pour ce Topic qui m'intérèsse car j'ai l'intension d'acheter La P5K DELUXE.
Mais là j'hésite aprés les derniers rumeurs de sifflement constatés par certains pocesseurs de cette carte.
Si c'est confirmé, je ne saurais vraiment pas quoi prendre comme mobo.
avec la P5B-E PLUS, j'avais le même problème.
Pouvez vous confirmer ces rumeurs ou pas?
D'autres rumeurs disent qu'elle chauffe beaucoups. qu'en dites vous?
encore une fois merci car sur l'autre forum , c'était le bordel quoi!!
Marsh Posté le 31-05-2007 à 13:32:38
Chez moi aucun sifflement constaté, un vrai modèle de silence
Elle chauffe pareil que la p5b dlx, il faut un minimum de flux d'air et c'est ok.
De toute manière la temp cm est sans grande importance...
Marsh Posté le 31-05-2007 à 13:34:39
elle me fait bien envie cette carte mère mais dans ce cas il faut que je me débarrasse de ma p5w dh deluxe!
Marsh Posté le 31-05-2007 à 13:41:48
Excellent topic
je viens de recevoir la mienne, je monte ça ce soir...
Marsh Posté le 31-05-2007 à 14:06:23
ha, je l'attendais depuis quelques jour ce topic   . sinon pour moi aussi pas de pb de sifflement, elle fonctionne très bien cette mobo, facile à utiliser et très douée pour l'O/C.
Marsh Posté le 31-05-2007 à 14:12:10
si ca interesse voici un lien d'un test de la
P5K E/WiFi AP
Marsh Posté le 31-05-2007 à 14:14:47
| jiiiiip a écrit : si ca interesse voici un lien d'un test de la   |
le test n'est pas encore écrit...
Marsh Posté le 31-05-2007 à 14:16:41
change de page, il y en a 8
Marsh Posté le 31-05-2007 à 14:16:59
Non, non!! il s'agit exclusivement de la P5K DELUXE VOYONS!!! il ne faut pas gacher ce topic unique.
Donc les fana de Gygabite et autres n'ont qu'a s'abstenir!!
P5K DELUXE ONLY!! P5K DELUXE ONLY!! P5K DELUXE ONLY!!
Marsh Posté le 31-05-2007 à 14:18:09
| 69annee_erotique a écrit : change de page, il y en a 8 |
merci bien je le sais ! mais le test n'est pas écrit
Marsh Posté le 31-05-2007 à 15:39:02
Bravo pour l'initiative du topic unique consacré a la famille P5K.
J'ai deux questions pour les possesseurs de P5K Dlx :
- le module wi-fi, est-il soudé a la carte mère où bien peut-il être désolidarisé de celle-ci ? (a la façon d'une carte pci par exemple ndlr)
- est ce que des incompatibilités avec une alimentation corsair HX620 auraient étés renseignées ? Si des forumers utilisant le couple P5K+HX620 pouvaient donner  un petit feedback, ce serait fort appréciable.
Marsh Posté le 31-05-2007 à 15:42:34
ReplyMarsh Posté le 31-05-2007 à 15:47:38
Drapal, je compte commander la mienne aujourd'hui ou demain.
Un peu déçu qu'ils aient viré le port PS2 de la souris, mais bon, ce sera l'occasion, de franchir le pas PS2 -> USB en même temps que DDR -> DDR2 et A64 ->C2D ! Mon dieu, que de changements...
Bon sinon, question con : pas de problème avec une Fortron Green 400W et sa prise 4 pins ?
Marsh Posté le 31-05-2007 à 16:00:02
Ca y est! Commandé hier chez grosbill en VPC, comme ca, si elle siffle --> remboursement. En +, la livraison est gratuite en ce moment.
Mais Kozzi me rassure, je suis sur qu'elle sifflera pas
Marsh Posté le 31-05-2007 à 16:03:30
| han_solo a écrit : Bravo pour l'initiative du topic unique consacré a la famille P5K.  |
Ben j'ai ça en commande justement, donc je fais un retour d'expérience dès que j'ai reçu/monté le matos
Marsh Posté le 31-05-2007 à 16:24:20
J'ai une Corsair HX620 avec ma P5K-Deluxe, et ca fonctionne parfaitement... !
Marsh Posté le 31-05-2007 à 20:43:46
C'est un topic uniq P5K Serie ou P5K+P5K Del ou P5K Del only ?
Marsh Posté le 31-05-2007 à 22:12:15
Merci je l'ajoute
Marsh Posté le 31-05-2007 à 22:15:00
On peu parler de la famille P5K Deluxe et meme des autres mais là faudrais que je mette plus de driver a jours et là c'est chaud !
Marsh Posté le 31-05-2007 à 10:43:57
Allez je me lance dans le topic sur cette carte mere !
1) Descriptifs
2) Tests
3) Download
4) Photos
5)Complements d'informations
1) Descriptifs
CPU
*This motherboard supports FSB 1333/1066/800
Chipset
Front Side Bus
Memory
* The chipset officially supports the memory frequency up to DDR2 800MHz. Tuned by ASUS Super Memspeed Technology, this motherboard natively supports up to DDR2 1066MHz
Please refer to www.asus.com or user manual for Memory QVL.
Expansion Slots
2 x PCI-E x1
3 x PCI
Storage
Southbridge
- 6 x SATA 3.0 Gb/s ports
- Supports RAID 0 and 1
JMicron® JMB363 PATA and SATA controller
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
- Supports SATA RAID 0,1 and JBOD
LAN
Dual Gigabit LAN controllers, featuring AI NET2
RealtekRTL8110SC® PCI Gigabit LAN controller
Wireless LAN
ASUS WiFi-AP Solo
54 Mbps IEEE 802.11g and backwards compatible with 11 Mbps IEEE 802.11b
- Software Access Point mode
- Station mode : Infrastruceure mode and Ad-Hoc mode
Audio
- Coaxial / Optical S/PDIF out ports at back I/O
- ASUS Noise Filter
IEEE 1394
USB
ASUS AI Lifestyle Features
ASUS Quiet Thermal Solution:
- ASUS AI Gear2
- ASUS AI Nap
- ASUS 8-Phase Power Design
- ASUS Fanless Design: Heat-pipe solution
- ASUS Fanless Design: Stack Cool 2
- ASUS Q-Fan 2
ASUS Crystal Sound:
- ASUS Noise Filter
ASUS EZ DIY:
- ASUS Q-Connector
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS AI Slot Detector
ASUS WiFi@Home:
- ASUS WiFi-AP Solo
Other Features
ASUS MyLogo 3
Multi-language BIOS
Overclocking Features
Intelligent overclocking tools:
- AI NOS (Non-delay Overclocking System)
- ASUS AI Booster utility
Precision Tweaker:
- vCore: Adjustable CPU voltage at 0.0125V increment
- vDIMM: 16-step DRAM voltage control
- vChipset: 4-step Chipset voltage control
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 800MHz at 1MHz increment
- Memory tuning from 667MHz up to 1333MHz for DDR2
- PCI Express frequency tuning from 100MHz up to150MHz at 1MHz increment
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
Back Panel I/O Ports
1 x PS/2 Keyboard
1 x S/PDIF Out (Coaxial + Optical)
2 x External SATA
1 x IEEE1394a
2 x RJ45 port
6 x USB 2.0/1.1
1 x WiFi-AP Solo antenna jack
8-channel Audio I/O
Internal I/O Connectors
2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
1 x COM connector
6 x SATA connectors
1 x CPU Fan connector
4 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
Front panel audio connector
1 x S/PDIF Out Header
Chassis Intrusion connector
CD audio in
24-pin ATX Power connector
2 x 4-pin ATX 12V Power connector
System Panel(Q-Connector)
BIOS
16 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Accessories
UltraDMA 133/100/66 cable
FDD cable
4 x Serial ATA cables
1 x 2-port Serial ATA power cable
I/O Shield
User's manual
ASUS WiFi-AP Solo manual
3 in 1 Q-connector
1 x 2-port USB2.0 / 1-port IEEE1394 module
ASUS WiFi-AP Solo omni-directional antenna
Support CD
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Suite
ASUS WiFi-AP Solo Wizard
Anti-virus software (OEM version)
Image-Editing Suite
Form Factor
ATX Form Factor, 12"x 9.6" (30.5cm x 24.4cm)
2) Tests
http://www.clubic.com/article-7388 [...] rlake.html
http://www.jmax-hardware.com/index [...] 5&Itemid=1
http://www.legionhardware.com/document.php?id=644
http://www.hexus.net/content/item.php?item=8764
http://www.cpu3d.com/motherboards/ [...] board.html
http://www.matbe.com/articles/lire [...] /page6.php
http://www.hardware.fr/articles/67 [...] -ddr3.html
3) Download
Generalement ici : http://support.asus.com/download/d [...] uage=fr-fr
Bios :
Version 202:http://dlsvr01.asus.com/pub/ASUS/m [...] e/0202.zip
Version 311:http://dlsvr01.asus.com/pub/ASUS/m [...] e/0311.zip
Version 404:http://dlsvr02.asus.com/pub/ASUS/m [...] e/0404.zip
Version 501:ftp://ftp.asus.com.tw/pub/asus/mb [...] e/0501.zip /!\ Beta
Version 503:ftp://ftp.asus.com.tw/pub/asus/mb [...] e/0503.zip /!\ Beta ???
Version 505:ftp://ftp.asus.com.tw/pub/ASUS/mb [...] e/0505.zip /!\ Beta ???
Version 601:http://dlsvr02.asus.com/pub/ASUS/m [...] e/0601.zip /!\ Beta
Version 603:http://dlsvr02.asus.com/pub/ASUS/m [...] KD0603.zip
Version 703:http://dlsvr02.asus.com/pub/ASUS/m [...] e/0703.zip /!\ Beta
Version 705:http://dlsvr02.asus.com/pub/ASUS/m [...] KD0705.zip
Version 809:http://dlsvr02.asus.com/pub/ASUS/m [...] KD0809.zip
Version 812:ftp://ftp.asus.com.tw/pub/ASUS/mb [...] e-0812.zip
Version 902:ftp://ftp.asus.com.tw/pub/ASUS/mb [...] e-0902.zip
Audio :
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/m [...] _Vista.zip
Vista 32bit
Win XP64
http://dlsvr01.asus.com/pub/ASUS/m [...] _64bit.zip
WinXP
http://dlsvr01.asus.com/pub/ASUS/m [...] _32bit.zip
LAN :
Realtek RTL8110SC Lan Driver
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/l [...] 152007.zip
Vista 32Bit
WinXP64
WinXP
Marvell Yukon Gigabit Ethernet Driver
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/l [...] 56_Lan.zip
Vista 32Bit
WinXP64
WinXP
RAID :
Intel Matrix Storage 7.6.0.1011
http://downloadmirror.intel.com/13 [...] a76_cd.exe
Vista 64bit
http://dlsvr01.asus.com/pub/ASUS/m [...] 117150.zip
Vista 32Bit
WinXP64
WinXP
Utilitaires :
Asus Probe 1.04.19
XP - Vista
http://dlsvr01.asus.com/pub/ASUS/m [...] V10419.zip
Others :
Linux Drivers
http://dlsvr01.asus.com/pub/ASUS/m [...] rivers.zip
4) Photos
Bundle
View de coté
Composant
5) Complement d'information
** les drivers RAID se trouvant sur le CD sont corompu, prenez en d'autre sur le net
** certains membres rencontre des problemes de sifflement => retour SAV
** CpuZ peu voir votre RAM comme DDR3 => mettre un bios recent
** une version Premium dispo => pas vraiment de difference avec la Deluxe (voir test en post 3)
** Les RAD Noctua sont compatible avec les P5K-*
** Vous avez des temperatures qui vous semble trop basse : mettre PECI sur OFF
** La frequence du proc fait le yoyo : c'est que les systemes d'economie d'energie sont sur ON , c'est les commande C1E et EIST. A noter quelle ne gene en rien l'o/c donc il est preferable de les laisser sur ON !
Explications de MEI, merci a lui :
* Alors le C1E c'est une fonction automatique du CPU qui reduit le coeff/et la tension. Typiquement le coeff mini avec une tension mini. Je dit automatique car ça a lieu quand le CPU est dans l'etat d'energie C1. C'est ce qui arrive quand l'OS envoi la commande HALT. Ca veut dire qu'en mode C1E le CPU ne bosse jamais.
* L'EIST permet de gerer la frequence/tension du CPU à la volé, mais ce doit etre demandé par l'OS. Au mini on retrouve bien sur les valeur du C1E et au maxi les valeur nominale du CPU. Entre il y a des paliers qui peuvent (meme doivent) exister. A l'OS de s'en depatouiller. En EIST bien sur le CPU peu bosser.
** Pour le flashage du bios, il est conseillé de passer par l'utilitaire EZ-flash au demarrage avec un bios sur clé USB, l'utilitaire windows montre pas mal de plantage chez pas mal de membres.
** La Famille P5K gère parfaitement les nouveaux proc Intel 8x00
**La Premium recontre pas mal de problèmes avec les disques dur Samsung en SATA. Pour le momment aucune solution n'a été trouvée. Evitez donc cette marque si vous montez un pc a base de premium et uniquement la Premium, aucun soucis concernant les autres fabriquants.
** Disque dur WD et Samsung selon les froums sur le site ASUS, il semble que seules les premieres revisions de la CM sont concernées. Celles dès le mois de aout 07 sont ok. Le numero de serie 78xxx (7 pour 2007 et 8 pour aout) est bon, ceux avant c'est la galère. J'ai une 78xx et mon WD 640Gb nouveau avec plateux haute densité roxx alors que certains avec des anciennes series de CM plantent. Sur le forums d'ASUS il parait que le RMA de la P5K vous renvoit une carte qui marche.
** Bios 0612: rapporté par plusieurs sur XS forums, et j'ai testé moi même: meilleures performances memoire en bench et leger mieux en OC de la memoire, reste très stable.
Message édité par joel0077 le 08-02-2009 à 08:25:07
