gravure de cd audio devenue impossible - CD/DVD/BD - Hardware
Marsh Posté le 11-06-2005 à 15:31:06
je joint le journal de gravure de nero
=== CDRom-Device-Map ===
YAMAHA CRW-F1E G: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048032kB)
Free physical memory: 637MB (652780kB)
Memory in use : 37 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
11.6.2005
CD Audio
15:11:43 #1 CDADOC -1 File Cdadoc.cpp, Line 1465
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: Off,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 01:23.14, Pause frames: 150, Filters: 0, Name: 'Impro D50 romantique 1.wav'.
Total size: 01:25.14
15:11:43 #2 Text 0 File Burncd.cpp, Line 2866
YAMAHA CRW-F1E
Protection contre les ruptures activés
15:11:43 #3 Text 0 File Reader.cpp, Line 127
Reader running
15:11:43 #4 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
15:11:43 #5 Text 0 File Burncd.cpp, Line 3151
Turn on Disque entier, using CD-R/RW media
15:11:47 #6 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 6238 ( 1:25.13)
15:11:47 #7 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO (enabled: CD)
15:11:47 #8 Text 0 File DlgWaitCD.cpp, Line 2309
Recorder: YAMAHA CRW-F1E;
CDRW code: 00 97 34 24; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: 96 00 D7, 2: 61 22 18 (LI 97:34.24), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 66 4A 99, 2: 38 80 00, 3: 04 C4 A0
15:11:47 #9 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
15:11:48 #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (Impro D50 romantique 1.wav)
2 indices, index0 (150) not provided
original disc pos #0 + 6239 (6239) = #6239/1:23.14
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 6239 blocks [YAMAHA CRW-F1E]
15:11:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1040
Prepare recorder [YAMAHA CRW-F1E] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 15026928, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
6239 | lead-out | 1 | 0x01 | 0x00
15:11:50 #12 Phase 36 File dlgbrnst.cpp, Line 1832
Début de gravure à 24x (3 600 Ko/s)
15:11:50 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2596
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:11:50 #14 Text 0 File Mmc.cpp, Line 16285
StartDAO : CD-Text - Off
15:11:50 #15 Text 0 File Mmc.cpp, Line 21025
Set BUFE: Buffer underrun protection -> ON , Optimum Writespeed Control : ON
15:11:50 #16 SCSI -1107 File Cdrdrv.cpp, Line 1176
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03855000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x03
CDB Data: 0x5D 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x2C 0x03
15:11:50 #17 Text 0 File Mmc.cpp, Line 16572
CueData, Len=32
21 00 00 01 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
01 aa 01 01 00 01 19 0e
15:11:50 #18 CDR -1107 File ThreadedTransferInterface.cpp, Line 1756
Zone programme non vide
15:11:50 #19 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1756
Impossible d'effectuer la fonction Disc At Once
15:11:50 #20 Phase 38 File dlgbrnst.cpp, Line 1832
La gravure a échoué à 24x (3 600 Ko/s)
15:11:50 #21 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
15:11:50 #22 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 13:06:00
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 07/05/2004 16:01:14 (Prassi/Veritas driver for win 2K)
File 'Drivers\IdeChnDr.sys': Ver=2.2.0.2126, 04/10/2002, size=93594 bytes, created 14/08/2002 00:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Marsh Posté le 11-06-2005 à 15:05:29
bonjour à tous
voilà, juska aujourdui, je gravait des cd audios sans problèmes ... voilà qu'il m'ai plus possible d'en graver ! message d'erreur avec nero : impossible de graver en mode disque entier avec ce graveur... ma fois je veut bien, mais juska présent il gravait dans ce mode sans broncher ... par curiosité j'essaye avec un autre cdr, idem. avec le windows média player, pareil, impossible, qui plus ai il bloque. j'ai un graveur dvd isonic. il grave très bien une compile iso par contre. Je ressort mon ancien graveur de cd, un yamaha, pareil, pas moyen de graver un cd audio, toujours le même message d'erreur. Bien sûr avant de chercher de l'aide ici, g essayé les gravures dans d'autres modes : piste par piste et disc at once, pareil, les deux graveurs ne veulent rien savoir ! je craque là !!!
HELP
