[ INFO ] Votre EPoX EP8KTA3 (+/Pro) supportera-t-elle les Athlon XP ?
Votre EPoX EP8KTA3 (+/Pro) supportera-t-elle les Athlon XP ? [ INFO ] - Hardware
MarshPosté le 04-03-2002 à 13:53:24
Salut.
Voilà ce que j'ai trouvé sur un NewsGroup d'Epox,
as i read before in yhis ng, when this question was asked to Epox, they replied that if your northbridge is silver printed, and has the number 0059C (or something like this) then it does not suuport athlon xp, but if it´s printed with some any other colour and has the number 0108C, then it does support. maybe you should look at it before buying any cpu.
Puis ca
I found on another ng that if you had rev 1.0 you should be ok their is no sliver numbers on my northbridge chip someone said if you had a board below rev 1.0 you had to check your northbridge chip yes it would be nice if their was an archive but looks like we are not even keeping the ng thanks for the help
[jfdsdjhfuetppo]--Message édité par vsfa--[/jfdsdjhfuetppo]
Marsh Posté le 04-03-2002 à 13:53:24
Salut.
Puis ca
keeping the ng
thanks for the help
VsFa :jap: | ID PSN: vsfa
