Votre Barton il passe combien de FSB ? Pont L12 Mod FSB 200 ??
Votre Barton il passe combien de FSB ? Pont L12 Mod FSB 200 ?? - Air Cooling - Overclocking, Cooling & Modding
Marsh Posté le 21-06-2003 à 16:53:36
Bon mon Barton passe pas plus de 175 Mhz de FSB alors que mon matos permet 215 Mhz (déjà testé)
Il paraitrai que le coupage du pont L12 permet de s'affranchir de ce problème de FSB 'bloqué'
Qu'en savez vous ?
http://www.techimo.com/forum/t59804.html
It has recently been found that nForce2 motherboards prior to revision 2 for some reason destabilize when running Athlon XP/333 MHz and trying to O/C to 200 MHz FSB. Users have found that without modifications the old Athlon XP/266 O/C better than the Athlon XP/333.
The second trick, also applicable to nForce2 motherboards without the CPU_FSB jumper, includes the physical modification of one of the L12 bridges on the Athlon XP/333 CPU. Beware that this modification will void any warranty on the CPU! The one L12 bridge to be cut is illustrated in this picture:
http://www.rme-audio.de/images/TechInfo/nForce2/image014.gif
Je vais tester ça...bientôt
Message édité par cuspides le 21-06-2003 à 17:03:00
Marsh Posté le 21-06-2003 à 18:23:09
up  :bounce:
