pc-5300 ou pc-6400 - Divers - Overclocking, Cooling & Modding
Marsh Posté le 23-04-2008 à 19:20:52
bonsoir !! d'apres les caracteristiques ci-dessous , c'est de la pc-5300 ou 6400 ??? siouplait merci Memory type: DDR2 SDRAM Error correction: NONE Voltage interface level: SSTL (1.8V) Data width: 64 bits Number of physical banks: 2 (double sided) Number of logical banks: 4 Number of row addresses: 14 14 Number of col addresses: 10 10 Bank density: 512 512 MB Primary RAM Width: 8 8 bits Error checking RAM Width: 0 0 bits Module density: 1024 MB Refresh rate: 7812.500 us Self-refresh: Oui Burst lengths supported: 4 8 CAS 3.0: Cycle time (tCYC) = 5.000 ns fMax = 200.000 Mhz Access time (tAC) = 0.600 ns fMax = 1666.667 MHz CAS 4.0: Cycle time (tCYC) = 4.300 ns fMax = 232.558 Mhz Access time (tAC) = 0.500 ns fMax = 2000.000 MHz CAS 5.0: Cycle time (tCYC) = 3.000 ns fMax = 333.333 Mhz Access time (tAC) = 0.450 ns fMax = 2222.222 MHz InconnuInconnuMin delay, Bk/Bk random cols: 0 clocks Min row precharge time (tRP): 15.000 ns Min row active delay (tRRD): 7.500 ns Min RAS to CAS delay (tRCD): 15.000 ns Min Actv to precharge (tRAS): 45.000 ns Addr/Cmd setup time: 0.200 ns Addr/Cmd hold time: 0.270 ns Data setup time: 0.100 ns Data hold time: 0.170 ns Write recovery time (tWR) 15.000 ns Int Wr to Rd Cmd Dly (tWTR) 7.500 ns Int Rd to Pchg Cmd Dly (tRTP) 7.500 ns Min Act/Auto-Rfrsh Time (tRC) 60.000 ns Min Auto-Rfrsh/Act Cmd (tRFC) 105.000 ns Max Dev Cycle time (tCK max) 8.000 ns Max DQS-DQ Skew (tDQSQ max) 2.400 ns Rd data hold skew Fctr (tQHS) 3.400 ns PLL relock time 0.000 ns Memory analysis probe chars: 00 DIMM type: UDIMM (module width = 133.35mm) FET switch external enable: Non Analysis probe installed: Non Includes weak driver: Oui Manufacturer's JEDEC ID code: 00000000 0000987f Module manufacturing location: 4 (manufacture dependant) Module part number: 99C5316-019.A00LF Module revision code: 0 (manufacture dependant) Module manufacturing date: Wk 7 of 2008 Module serial number: 78cc1c8c SPD revision: 1.1
Marsh Posté le 23-04-2008 à 20:52:43
5300 a voir les fréquences à 333MHz non?
bonsoir !! merci
siouplait
Data width: 64 bits
Self-refresh: Oui
CAS 3.0:
CAS 4.0:
CAS 5.0:
SPD revision: 1.1
Message édité par toussaint14 le 23-04-2008 à 19:21:49
