[Workblog] * tic tac * Lian Li Pc-Q07 / Watercooling
* tic tac * Lian Li Pc-Q07 / Watercooling [Workblog] - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 21-04-2010 à 20:21:55
Projet  Lian Li Pc-Q07  tic tac MOD Watercooling
http://img101.imageshack.us/img101/8113/tictacf.jpg
Config.
-Lian Li Pc-Q07
-Silverstone  Strider ST45SF - 450W
-Lan Party MI P55-T36
-Intel i5  750
-G.Skill  Kit Extreme3 2 x 2 Go PC16000 Ripjaws CAS 9
-EVGA GTX 470
-SSD Intel Postville X25-M 80 Go
-Graveur Blu-ray LG  BH10LS30
Watercooling.
-Pompe Laing DDC-1T 12 Volts 10W
-Top Watercool DDC-Case LT
-Réservoir EKWaterblocks Acrylique MultiOption 150 Rev.2
-WaterBlock Chipset Anfi-tec UCD classic
-Radiateur EKWaterblocks CoolStream RAD-XT 240
-Embouts Bitspower et Feser
-Tuyau Feser Orange
-Liquide Feser One Cooling Fluid Réactif aux UV VERT
-Pâte Thermique Arctic Cooling MX-2
[:cend] [:huit]
Message édité par shura18 le 04-06-2010 à 12:02:47
FeedBack
Marsh Posté le 21-04-2010 à 20:22:16
Les premières photos du matos:
http://img87.imageshack.us/img87/2781/dscf3957.th.jpg     http://img51.imageshack.us/img51/6651/dscf4040t.th.jpg     http://img534.imageshack.us/img534/4275/dscf4043.th.jpg     http://img341.imageshack.us/img341/2464/dscf4060y.th.jpg
http://img718.imageshack.us/img718/826/dscf4062.th.jpg     http://img214.imageshack.us/img214/3800/dscf4066.th.jpg     http://img179.imageshack.us/img179/1791/dscf4067.th.jpg     http://img718.imageshack.us/img718/2223/pieceg.th.jpg
http://img156.imageshack.us/img156/9913/dscf4082k.th.jpg     http://img526.imageshack.us/img526/4291/dscf4090.th.jpg     http://img210.imageshack.us/img210/5755/dscf4092w.th.jpg     http://img402.imageshack.us/img402/6840/dscf4093.th.jpg
http://img195.imageshack.us/img195/8026/dscf4097c.th.jpg     http://img232.imageshack.us/img232/3414/dscf4103.th.jpg     http://img195.imageshack.us/img195/2076/dscf4088h.th.jpg     http://img268.imageshack.us/img268/2567/dscf4113.th.jpg
http://img718.imageshack.us/img718/2029/dscf4112e.th.jpg
Message édité par shura18 le 11-05-2010 à 22:46:26
FeedBack
Marsh Posté le 21-04-2010 à 20:53:38
drapal !
Marsh Posté le 21-04-2010 à 22:13:38
[:lardoncru:4]
[My Topic Ventes/Achats]
Marsh Posté le 22-04-2010 à 01:29:00
Encore un projet qui ne verra jamais le jour
@Shura c'est pas le premier teasing et je pense que ce ne sera pas le dernier
btw : j'édite à loisir
Mon Feedback - Mes Ventes - Simplexity 650D
Marsh Posté le 22-04-2010 à 07:11:19
Juste pour te prouver que c'est possible ;)
perso, je trouve la cg un peu limite vu le reste :)
Pour info : une hd5770 à pcb court rentre ;) (cf club3d ou powercolor)
Feed Ventes
Marsh Posté le 11-05-2010 à 16:23:00
Voila une photo d'une des pièces en fabrication (sur fraiseuse à
commande numérique).
pourquoi dont ?!  Pour l'installation de carte graphique supérieur a 5750,donc ma 5770 ;)
L'ensemble en situation (avec un patron en papier) :
http://img98.imageshack.us/img98/6690/dscf4071g.th.jpg
(ya un mauvais effet d'optique,le ventilo ne dépasse pas sur le graveur ,ya un jeu en haut et en bas de 3mm).
Message édité par shura18 le 11-05-2010 à 16:23:29
FeedBack
Marsh Posté le 11-05-2010 à 16:28:16
Jolie tout ce matos :o :p
Marsh Posté le 11-05-2010 à 17:15:52
kingway a écrit :
j'trouve dommage d'avoir explosé lavant du boitier plutot que d'avoir pris une 5770 qui rentre, de même que de wc le chipset, pas tellement utile.
sinon c'est sympa :)
La 5770 je l'avais deja,donc j'allais pas perdre des sous a la revendre pour en racheter une..
l'avantage c'est que jpeux mettre d'autres cartes,pas de restriction de taille..
Merci ;)
Message édité par shura18 le 11-05-2010 à 17:16:53
FeedBack
Marsh Posté le 11-05-2010 à 19:41:50
Pièces pour le boitier (sortie carte graphique ):
Edit:
Voila la nouvelle plaque de face avant:
Maintenant jvais "m'amuser" pour découper  :whistle:
Message édité par shura18 le 11-05-2010 à 19:48:35
FeedBack
Marsh Posté le 11-05-2010 à 20:00:50
j'aime beaucoup vivement la fin  :o
Marsh Posté le 11-05-2010 à 21:28:36
kingway a écrit :
tu devrais la faire faire la plaque avant, à moins que t'arrive à avoir un truc clean mais c'est super dur.
Bahh jme trouve pas trop mauvais la
Dremel PowWwaA  :lol:
Message édité par shura18 le 11-05-2010 à 21:31:32
FeedBack
Marsh Posté le 11-05-2010 à 21:29:59
ouép c'est pas mal  [:mesh:3]
Marsh Posté le 11-05-2010 à 22:06:49
Tu as eu çà où ??
Car je suis acheteur !!
La hd5770 existe en pcb court compatible avec le boitier et ce sans découpe (club 3d et/ou powercolor)
Message édité par dduckof62 le 11-05-2010 à 22:12:43
Feed Ventes
Marsh Posté le 11-05-2010 à 22:07:54
J'avais oublié de poster celle la:
Pour le moment je garde le graveur de Blu-Ray,si vraiment j'ai des temperatures de *****, suppression du graveur => Ajout d'un Rad 120 => Nouvel plaque de face avant (mais j'aime pas trop cette option)
Je sais pas trop a quoi m'attendre niveau temp. (i5 750+Chipset+5770 ?!?)(sur un rad 240 EKWB, celui la http://www.docmicro.com/pieces/EKW [...] _8585.html )
Quand j'avais la zotac 9300 ITX ça tournait a 32° pour CPU + Chip graphique sur un Rad 120,mais c'était qu'un e8400 donc..
Voila deux petites photos (mise en situation):
http://img268.imageshack.us/img268/2567/dscf4113.th.jpg   http://img718.imageshack.us/img718/2029/dscf4112e.th.jpg
Message édité par shura18 le 11-05-2010 à 22:13:29
FeedBack
Marsh Posté le 11-05-2010 à 22:16:33
Tu as eu çà où ??
Tu as du zapper car ton post est apparu ensuite ;)
Feed Ventes
Marsh Posté le 11-05-2010 à 22:27:50
dduckof62 a écrit :
http://img214.imageshack.us/img214 [...] 066.th.jpg
Tu as eu çà où ??
C'est un produit MNPCTech ( http://www.mnpctech.com/ ) mais si tes pas des USA c'est compliqué pour acheter..
Moi je commande Chez performance-pcs.com
Je sais que la 5770 existe en pcb court mais je l'avais deja sur un autre pc,jallais pas la revendre pour en racheter une et encore perdre des sous..
L'avantage c'est que je peux mettre n'importe quelle carte (jusqu'à 29 cm,donc..)( d'ailleurs la GTX470 commence a me faire de l'œil )
Message édité par shura18 le 11-05-2010 à 22:43:39
FeedBack
Marsh Posté le 11-05-2010 à 22:59:23
c'est combien les fdp chez ppcs? (plutot 10-20€? ou 50-100€?)
Marsh Posté le 11-05-2010 à 23:40:33
C'est assez cher..
pour les poignées et la 3d grille
$26.52 soit 20.88 euros,après j'ai l'impression que c'est au poids..donc sa dépend de ce que tu commande
(inscris-toi,sa donne le prix dans le panier)
Message édité par shura18 le 11-05-2010 à 23:46:56
FeedBack
Marsh Posté le 13-05-2010 à 11:23:35
Pour l'instant, j'adore !! Tres prometteur !!
Marsh Posté le 14-05-2010 à 19:48:48
drap
FEED
Marsh Posté le 17-05-2010 à 07:22:27
up :D
Achats / Ventes Feed-Back ITX Tower
Marsh Posté le 17-05-2010 à 22:58:19
Hop! hop!  Changement de carte graphique
FeedBack
Marsh Posté le 17-05-2010 à 23:00:22
Tu mets quoi a la place ?
Marsh Posté le 17-05-2010 à 23:09:49
:D :ange:   "Petit" Plaisir..
http://img517.imageshack.us/img517/8369/dscf4137o.th.jpg   http://img294.imageshack.us/img294/5306/dscf4148g.th.jpg
Message édité par shura18 le 17-05-2010 à 23:10:24
FeedBack
Marsh Posté le 17-05-2010 à 23:28:17
Ouich c'est grand , tu veux pas faire échange contre ma 5850 sa seras moins grand  :o
Marsh Posté le 18-05-2010 à 00:13:13
loooooool  Ohh que non ,déjà par ce que ça fait la même taille (voir moins la gtx470) en plus la 5850 a les connecteurs devant  :o (pourquoi faire des cartes plus petites si c'est pour les rallonger avec les connecteurs..  :??:  :kaola: )
FeedBack
Marsh Posté le 18-05-2010 à 07:13:51
+1
son pas doué quand même, il est ou leurs cerveaux ? :D
sinon Watercooling aussi pour la nouvelle venu ?
Marsh Posté le 18-05-2010 à 07:31:04
laule
Tu vas t'y prendre comment du coup pour la CG :??:
Marsh Posté le 18-05-2010 à 10:14:52
Ames974 a écrit :
laule
Comment ça ?
FeedBack
Marsh Posté le 18-05-2010 à 10:20:31
Parce que c'est plus jolie dans le boitier , ils sont moins voyant ;)
Marsh Posté le 18-05-2010 à 10:36:28
 :kaola:  Dis ça au possesseurs de mini ITX et de petits boitiers..  :lol:
romain13tuning a écrit :
+1
Bah... la gtx 470 c'est 225w un i5 750 95w (sans oc) et le chipset il parait que c'est jusqu'à 50w (jtouve ça énorme ?!)
Donc tout ça sur un ekwb de 240 ça va faire djust !
Faut soit la 470 soit proc et chip  :??:  (je sais pas trop quoi choisir la vraiment)
Message édité par shura18 le 18-05-2010 à 10:36:52
FeedBack
Marsh Posté le 18-05-2010 à 10:42:10
Moi je dirais proc et chipset ;) !
Marsh Posté le 18-05-2010 à 11:50:56
Moi je dis vivement la suite.
tu va mettre ou ton rad ? un 240 ??
Feed Ventes
Marsh Posté le 18-05-2010 à 19:15:20
Il est déjà posé :) Extérieur Face droite du boitier (quand le boitier est de face)
EDIT:
J'ai reçu ma commande Aquatuning:
Des petits dissipateurs pour ma carte mère ;)
http://img697.imageshack.us/img697/776/dscf4157u.th.jpg
Message édité par shura18 le 18-05-2010 à 22:19:50
FeedBack
Marsh Posté le 18-05-2010 à 22:14:38
j'attends donc la suite ;)
Feed Ventes
Marsh Posté le 18-05-2010 à 22:15:56
Dissipation
Dissiper
Dissipateur ^^
Marsh Posté le 18-05-2010 à 22:23:13
Cubensia a écrit :
Dissipation
Dissiper
Dissipateur ^^
 j'ai posté plus vite que le correcteur d'orthographe [:beel1]
(ah ah le pire c'est que quand j'ai écris le mot j'ai vu que c'était pas bon et au final j'ai zappé   :whistle: ).
FeedBack
Marsh Posté le 18-05-2010 à 23:39:13
elle mesure combien la 470 stp ? :)
Marsh Posté le 18-05-2010 à 23:57:45
24,2 Cm :jap:
Message édité par shura18 le 18-05-2010 à 23:58:06
FeedBack
