Wts new set offering the New Nikon D90 Body + Kit + Battery Grip
Wts new set offering the New Nikon D90 Body + Kit + Battery Grip - Appareil - Photo numérique
Marsh Posté le 10-03-2010 à 05:42:29
Upgrading into a new set want to offer the New Nikon D90 12MP DSLR Camera with nikkor 18-105mm lens
Equipment Type: Body + Kit + Battery Grip
Price:$ 590usd
Detailed item info
Product Description
Fusing 12.3-megapixel image quality and a cinematic 24fps D-Movie Mode, the Nikon D90 exceeds the demands of passionate photographers.
Details
Dimensions (WxDxH): 13.2 cm x 7.7 cm x 10.3 cm
Weight: 0.62 kg
Additional Features:
*Lens Features
Optical Sensor Type: CMOS
Optical Sensor Size: 15.8 x 23.6mm
Maximum Focal Length: 105 mm
Minimum Focal Length: 18 mm
Display: LCD display - TFT active matrix - 3" - color
Flash Features
Flash Type: Pop-up flash
Red Eye Reduction: Yes
be fast with your response now only serious buyers email me at :
Message édité par bricocoman le 10-03-2010 à 08:59:09
