traducteur pascal --> C
traducteur pascal --> C - Delphi/Pascal - Programmation
Marsh Posté le 27-04-2004 à 19:03:44
salut a tous
je voudrais savoir si vous avez deja programmé un traducteur pascal->C?
si oui comment faut il faire??? avez vous un prog deja fait que je puisse etudier?
lyim
Marsh Posté le 27-04-2004 à 19:08:13
aucune idée, mais bon courage
Marsh Posté le 27-04-2004 à 19:09:04
apt-cache show p2c
Package: p2c
Priority: optional
Section: devel
Installed-Size: 720
Maintainer: Josip Rodin <joy-packages@debian.org>
Architecture: i386
Version: 1.21alpha2-2
Depends: libc6 (>= 2.3.2-1)
Suggests: gcc, gpc
Filename: pool/main/p/p2c/p2c_1.21alpha2-2_i386.deb
MD5sum: 7aabb0f65f83c79701b97503b16d8881
Description: Pascal to C translator
 P2c is a tool for translating Pascal programs into C. The input
 consists of a set of source files in any of the following Pascal
 dialects: HP Pascal, Turbo/UCSD Pascal, DEC VAX Pascal, Oregon Software
 Pascal/2, Macintosh Programmer's Workshop Pascal, Sun/Berkeley Pascal,
 Texas Instruments Pascal, Apollo Domain Pascal. Modula-2 syntax is also
 supported.
 Output is a set of .c and .h files that comprise an equivalent program
 in any of several dialects of C. Output code may be kept machine and
 dialect-independent, or it may be targeted to a specific machine and
 compiler. Most reasonable Pascal programs are converted into fully
 functional C which will compile and run with no further modifications,
 although p2c sometimes chooses to generate readable code at the expense
 of absolute generality.
Marsh Posté le 27-04-2004 à 19:17:58
ok merci!
mais c'est un package pour debian non?
comment je peux lire le code source de ce package?
je suis desolé pour ces question mai je suis tres doué dans le domaine de la programmation et tout ce que ca touche....
lyim
Marsh Posté le 27-04-2004 à 19:22:09
