validation XHTML
validation XHTML - HTML/CSS - Programmation
Marsh Posté le 09-02-2006 à 10:19:52
salut,
je m'arrache les cheveux avec 2 erreurs que me donne le validateur HTML de W3C :
# Error  Line 24 column 3: document type does not allow element "ul" here; missing one of "object", "ins", "del", "map", "button" start-tag.
<ul>
The mentioned element is not allowed to appear in the context in which you've placed it; the other mentioned elements are the only ones that are both allowed there and can contain the element mentioned. This might mean that you need a containing element, or possibly that you've forgotten to close a previous element.
One possible cause for this message is that you have attempted to put a block-level element (such as "<p>" or "<table>" ) inside an inline element (such as "<a>", "<span>", or "<font>" ).
# Error Line 37 column 123: document type does not allow element "input" here; missing one of "p", "h1", "h2", "h3", "h4", "h5", "h6", "div", "pre", "address", "fieldset", "ins", "del" start-tag.
...="bc2be6f1e33eeec34ce5bfacabc6d7c7" />
Voici mon code HTML
  1. !DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
  2. <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="fr">
  3. <head>
  4. <meta http-equiv="content-type" content="text/html; charset=iso-8859-1" />
  5. <title>Bienvenue à la crèche Reine Fabiola</title>
  6. <style type="text/css" media="all">@import "style/style.css";</style>
  7. </head>
  8.   <body>
  9.   <div id="Header"><a href="http://www.projetinternet.be/index.php5" title="Accueil">CRECHE REINE FABIOLA</a>
  10. </div> <div id="Content">
  11. <h1>Bienvenue à la crèche Reine Fabiola</h1><img src="images/childrenplaying.jpg" alt="enfants" />
  12. <p>Bienvenue à la crèche communale Reine Fabiola.<br />Celle-ci est un département
  13. du service des Affaires sociales de l''administration communale
  14. de Jette.<br />Elle accueille des enfants du lundi au vendredi, de
  15. 7h30 à 18h00.<br />Les bambins y sont répartis dans cinq sections
  16. où ils évoluent en fonction de leur âge et de leur développement:</p>
  17. <p>
  18. <ul>
  19. <li>La section des <b>chatons</b> accueille les bébés de 0 à 7 mois.</li>
  20. <li>La section des <b>mickeys</b> accueille les petits, de 7 à 12 mois.</li>
  21. <li>La section des <b>coccinelles</b> accueille les petits de 12 à 18 mois.</li>
  22. <li>La section des <b>spirous</b> accueille les moyens de 18 à 24 mois.</li>
  23. <li>La section des <b>schtroumpfs</b> accueille les enfants de 24 à 36 mois.</li>
  24. </ul>
  25. </p>
  26. <p>En tant que membre, vous pourrez inscrire vos enfants en ligne,<br /> compléter le planning mensuel des présences de vos enfants,<br />voir les photos prises lors des événements, consulter les actualités...
  27. </p>
  28.   <br />
  29.         <a href="http://www.projetinternet.be/register_form.php5">Pas encore inscrit ?</a>
  30.    <a href="http://www.projetinternet.be/forgot_form.php5">Mot de passe oublié?</a>
  31.   <form method="post" action="member.php5">
  32.   <fieldset>
  33.   <legend>Identification</legend>
  34.   <table border = "1">
  35.     <tr>
  36.      <th><label for="email">Email</label></th>
  37.      <td><p><input type="text" name="email" id="email"/></p></td></tr>
  38.
  39.     <tr>
  40.      <th><label for="password">Mot de passe</label></th>
  41.      <td><p><input type="password" name="password" id="password"/></p></td></tr>
  42.   </table>
  43.   <p><input type="submit" value="Valider" /></p>
  44.   </fieldset>
  45.   </form>
  46. <br />
  47. </div>
  48.   <div id="Menu">
  49.
  50. <a href="http://www.projetinternet.be/index.php5">Home</a><br /><a href="http://www.projetinternet.be/infos.php5">Infos pratiques</a><br /></div>
  51.         <div id="Footer">
  52.         <a href="http://www.php.net"><img
  53.         src="images/php-power-micro2.png"
  54.         alt="PHP Powered" /></a>
  55.         <a href="http://www.mysql.com"><img
  56.         src="images/mysql.png"
  57.         alt="MySql Powered" /></a>
  58.         <a href="http://validator.w3.org/check?uri=referer">
  59.  <img src="images/button-xhtml.png"
  60.         alt="Valid XHTML 1.0 Transitional" /></a>
  61.  <a href="http://jigsaw.w3.org/css-validator/">
  62.         <img src="images/button-css.png"
  63.         alt="Valid CSS!" /></a>
  64.  </div>
  65.   </body>
  66.   </html>
je ne vois pas ou se trouve l'erreur.
merci d'avance pour toute suggestion
Marsh Posté le 09-02-2006 à 11:03:11
Je trouve les messages d'erreur parlants, moi, là...vire les <p></p> autour de ton premier <ul>, et pour voir...
Can't buy what I want because it's free -
Marsh Posté le 09-02-2006 à 11:22:07
ben j'pense que virer les <p> autour du input aussi hein...[:moule_bite]
D'ailleurs qu'est ce qu'ils foutent la?[:autobot]
Marsh Posté le 09-02-2006 à 11:30:40
ok, je vais essayer ça.
pour les <p> autour du input, je m'etais inspiré entre autres de ce site :
http://giminik.developpez.com/arti [...] ulti-form/
Marsh Posté le 09-02-2006 à 11:31:50
Bah regarde mieux, dans leurs <td> yen a nulle part des <p>.:o
Marsh Posté le 09-02-2006 à 11:35:03
ok , ca passe maintenant.
merci a vous !
