execution servlet sous tomcat
execution servlet sous tomcat - Java - Programmation
Marsh Posté le 07-06-2004 à 11:01:13
erreur à l'execution d'une servlet, voici tous les éléments
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Class FirstServlet2 is not a Servlet
    at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:896)
etc ...
je lance la servlet de cette facon (c'est là ou je ne suis pas sur que ce soit bon ?)
http://nom_serveur:8080/FirstServlet2
le code est simple, un grand classique (example tomcat):
/* $Id: HelloWorldExample.java,v 1.2 2001/11/29 18:27:25 remm Exp $
import java.io.*;
import java.util.*;
import javax.servlet.*;
import javax.servlet.http.*;
* The simplest possible servlet.
* @author James Duncan Davidson
public class FirstServlet2 extends HttpServlet {
public void doGet(HttpServletRequest request,
HttpServletResponse response)
throws IOException, ServletException
ResourceBundle rb =
ResourceBundle.getBundle("LocalStrings",request.getLocale());
response.setContentType("text/html" );
PrintWriter out = response.getWriter();
out.println("<html>" );
out.println("<head>" );
     String title = rb.getString("helloworld.title" );
     out.println("<title>" + title + "</title>" );
out.println("</head>" );
out.println("<body bgcolor=\"white\">" );
    // note that all links are created to be relative. this
    // ensures that we can move the web application that this
    // servlet belongs to to a different place in the url
    // tree and not have any harmful side effects.
// XXX
// making these absolute till we work out the
// addition of a PathInfo issue
     out.println("<a href=\"/examples/servlets/helloworld.html\">" );
out.println("<img src=\"/examples/images/code.gif\" height=24 " +
"width=24 align=right border=0 alt=\"view code\"></a>" );
out.println("<a href=\"/examples/servlets/index.html\">" );
out.println("<img src=\"/examples/images/return.gif\" height=24 " +
"width=24 align=right border=0 alt=\"return\"></a>" );
out.println("<h1>" + title + "</h1>" );
out.println("</body>" );
out.println("</html>" );
l'arborescence est la suivante :
C:\Tomcat\webapps\FirstServlet2\WEB-INF\classes
et le fichier web.xml sous C:\Tomcat\webapps\examples\WEB-INF contient
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN" "http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app>
    <display-name>FirstServlet2</display-name>
    <servlet>
        <servlet-name>FirstServlet2</servlet-name>
        <servlet-class>FirstServlet2</servlet-class>
    </servlet>
    <servlet-mapping>
        <url-pattern>/</url-pattern>
    </servlet-mapping>
</web-app>
Je ne vois ce qui cloche.
Merci pour votre aide
Marsh Posté le 07-06-2004 à 11:44:42
très bizare ...
tu aurais pas un jar qui contiendrait les classes de l'API servlet dans ta web-app ?
sinon, je ne crois pas que ca corrigerait le problème, mais utilise des packages pour tes classes ...
Message édité par benou le 07-06-2004 à 11:44:48
ma vie, mon oeuvre - HomePlayer
Marsh Posté le 07-06-2004 à 11:56:57
le fichier xml doit être dans C:\Tomcat\webapps\FirstServlet2\WEB-INF\ il me semble parce que comme par hasard nous avons eu le meme probleme il y a à peine 2 minutes en cour. :)
Je pense que tu tourne sous tomcat5
Marsh Posté le 07-06-2004 à 12:05:42
ben ca dépend du nom de ta web-app ca ...
Marsh Posté le 07-06-2004 à 12:17:41
Mets ta classe dans au moins 1 package et mets le nom complet de ta classe dans le tag servlet-class
Pour ce qui est de l'emplacement du fichier web.xml il doit se trouver dans webapps/<nom du context>/WEB-INF si tu déploie directement dans tomcat.
Message édité par pascal34 le 07-06-2004 à 12:20:17
Marsh Posté le 07-06-2004 à 13:35:44
berceker united
rectification :
en fait j'ai fait une erreur de copier/coller lors du premier post.
le fichier web.xml est bien dans C:\Tomcat\webapps\FirstServlet2\WEB-INF\
