probleme d'installation de jbuilder9 [résolu]
probleme d'installation de jbuilder9 [résolu] - Java - Programmation
Marsh Posté le 23-12-2003 à 09:19:08
  1. [fullphil@localhost jb9_linux]$ ./per_install.bin
  2. Preparing to install...
  3. tail: option « -1 » est obsolète; utiliser « -n 1 »
  4. Pour en savoir davantage, faites: « tail --help ».
  5. ./per_install.bin: line 329: [: `)' expected, found -z
  6. WARNING! The amount of /tmp disk space required and/or available
  7. could not be determined.  The installation will be attempted anyway.
  8. Extracting the JRE from the installer archive...
  9. Unpacking the JRE...
  10. Extracting the installation resources from the installer archive...
  11. Configuring the installer for this system's environment...
  12. Launching installer...
  13. Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
  14. Stack Trace:
  15. java.lang.NoClassDefFoundError
  16.         at java.lang.Class.forName0(Native Method)
  17.         at java.lang.Class.forName(Class.java:140)
  18.         at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:62)
  19.         at java.awt.Window.init(Window.java:224)
  20.         at java.awt.Window.<init>(Window.java:268)
  21.         at java.awt.Frame.<init>(Frame.java:398)
  22.         at java.awt.Frame.<init>(Frame.java:363)
  23.         at com.zerog.ia.installer.Main.c(Unknown Source)
  24.         at com.zerog.ia.installer.Main.main(Unknown Source)
  25.         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  26.         at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
  27.         at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
  28.         at java.lang.reflect.Method.invoke(Method.java:324)
  29.         at com.zerog.lax.LAX.launch(Unknown Source)
  30.         at com.zerog.lax.LAX.main(Unknown Source)
  31. GUI-
  32. [fullphil@localhost jb9_linux]$
une fois l'archive décompressée, en lancant l'installeur j'ai ce probleme... J'ai tout supprimé dans /tmp, mais meme resultat
Message édité par full_phil le 23-12-2003 à 15:25:48
Marsh Posté le 23-12-2003 à 12:19:46
tu as payé, tu as droit à une assistance :o
IVG en france
Marsh Posté le 23-12-2003 à 12:22:49
le mec qui a fait l'archive sous windows a foiré un bordel de retour à la ligne avant de le foutre sur edonkey :o
Marsh Posté le 23-12-2003 à 12:37:21
J'ai téléchargé la version personnelle gratuite sur borland.com, rien payé donc et pas de edonkey...
Message édité par full_phil le 23-12-2003 à 12:38:13
Marsh Posté le 23-12-2003 à 12:38:49
utilise autre chose que cette merde :o
Marsh Posté le 23-12-2003 à 14:03:51
autant pour moi, désolé c'est l'habitude... [:spamafote]
   n'empeche que tu devrais utiliser autre chose. Je sais ça arrange rien à ton probleme present mais tu nous remerciera plsu tard  :jap:
IVG en france
Marsh Posté le 23-12-2003 à 15:24:25
ca risque de n'intéresser pas grand monde, mais voila ce qu'il faut taper pour que ca marche :
  1. [fullphil@localhost jb9_linux]$ ./per_install.bin LAX_VM /usr/java/j2sdk1.4.2_02/bin/java
en ayant ca :
  1. [fullphil@localhost jb9_linux]$ which java
  2. /usr/java/j2sdk1.4.2_02/bin/java
Message édité par full_phil le 23-12-2003 à 15:25:24
Marsh Posté le 23-12-2003 à 16:13:05
pourquoi n'as tu pas pris la version 10?
Borland rulez: http://pages.infinit.net/borland
Marsh Posté le 23-12-2003 à 16:32:55
pour linux il n'y a dispo que la version X entreprise trial (sans compter q'elle n'est pas en fr, mais bon c une demi excuse), la seule version libre c la 9 en personal edition
