probleme installation firmware d'un modem-routeur Zyxel
probleme installation firmware d'un modem-routeur Zyxel - Windows & Software
Marsh Posté le 27-10-2003 à 14:07:35
Bonjour!
je viens de telecharger le dernier firmware fourni par Zyxel pour son modem Prestige 650HW-31 et voici ce qu il est ecrit ds le readme :
Known Issues:
Update firmware issue :
a. Update firmware by FTP and Web: Can¡¦t update
firmware from 3.40(IS.0), 3.40(IS.1) and 3.40
(IS.2) to 3.40(IS.3) by FTP and Web
b. Only update firmware by console
We propose an alternative (by FTP twice) to help
ease the inconvenience of the firmware update by
console.
Please also note that because the data structure of
IS3 is also increased to support more function, user
may not be able to keep old configuration. Please
reset to factory default and proceed firmware upgrade
task. After f/w upgrade complete, please reconfigure
P650HW.
Below is the procedure:
1. Prepare a computer with FTP client
2. Extract the firmware package (.zip) to your local
computer
3. Reset P650HW to default configuration. (Press reset
buttom. Please refer to user's manual for more detail.)
4. Run FTP and load the file (340IS2_100103.bin) to
P650HW first
5. After P650HW completes f/w upgrade and reboots, then
reload the IS3 f/w (340IS3C0.bin)
6. P650HW f/w upgrade complete and reconfigure again
Effectivement il est impossible de le flasher depuis le ftp. Mais je ne comprends pas non plus leur methode.
J ai bullet proof ftp, que dois-je faire?
Message édité par raqi le 27-10-2003 à 14:18:42
