Looking for a graphics card suggestion to fit my current build - Carte graphique - Hardware
Marsh Posté le 02-02-2019 à 11:16:59
So what is your current build?
For 900 usd/euros and your requirements I would suggest an RTX2080, but it also depends on your current CPU.
Marsh Posté le 02-02-2019 à 11:34:58
Funny you found your way around here (there are zillions of US forums
Whats your build indeed?
Marsh Posté le 02-02-2019 à 11:36:47
Marsh Posté le 02-02-2019 à 06:50:36
Hi folks, Looking to get a graphics card suggestion to fit my current build (detailed below). The graphics card listed in the build has been largely unavailable/overpriced for awhile and I'm upcoming movies netflix free trial free netflix hoping to find a comparable alternative.
This build would be used for gaming. Ideally >80fps-1440p-highest-graphics-settings-possible gaming. I'm hoping for a build that can deliver amazing quality NOW, and solid quality over the next 4-6 years.
Budget for the graphics card is probably capped at around 900 but I'd entertain suggestions above that. Also I'd be ordering from within the USA.
Message édité par daryldixon le 06-02-2019 à 05:59:09
