BSOD (0x124) aléatoires [RESOLU]
BSOD (0x124) aléatoires [RESOLU] - Matériels & problèmes divers - Hardware
Marsh Posté le 31-08-2013 à 01:00:26
Salut Hardware.fr!!
Bon, on va faire simple, voilà ce que j'ai marre de voir  :D :
http://pictures.korben.info/img508.imageshack.us/wp-content/uploads/2008/07/blue-screen.jpg
Plus sérieusement, c'est de ce blue screen là que je voulais parler :
http://blog.cheesesoft.com/wp-content/uploads/2012/11/168.jpg
Concernant la fréquence de ces BSOD, la tendance va à l'augmentation:
http://img4.hostingpics.net/pics/625451Dump.jpg
Quasiment rien de l'année et depuis Juillet et Aout, c'est infernal.
Sur Who Crashed, voici le rapport des 5 ou 6 derniers BSOD:
On Thu 29/08/2013 13:47:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082913-27970-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800B7CC028, 0xFA000000, 0x400405)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
On Sun 25/08/2013 12:15:16 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082513-24850-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800B7B8028, 0xFE000000, 0x70014A)
On Sun 25/08/2013 00:15:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082513-28064-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800B892028, 0xBE000000, 0x800400)
On Sat 24/08/2013 22:49:27 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082513-24304-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800B7F1028, 0xFA000000, 0x400405)
On Sat 17/08/2013 21:23:21 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081713-35193-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800BD50028, 0xFA000000, 0x400405)
On Sun 11/08/2013 15:40:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081113-29686-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800BCF8028, 0xBA000000, 0x400405)
Il s'agit donc de l'erreur récurrente "0x124" (Bugcheck code: 0x124 / Error: WHEA_UNCORRECTABLE_ERROR / file path: C:\Windows\system32\hal.dll).
En fouillant sur le net, j'ai remarqué que ce Bugcheck concerne très souvent un dysfonctionnement de la RAM ou une surchauffe matérielle (mauvais overclocking par ex) voire un défaut de Carte Mère (ma hantise).
A l'heure actuelle, j'ai effectué toute la nuit un test de mes 3 barrettes mémoire avec le logiciel inclus dans Windows 7 : "Diagnostic de mémoire Windows". Ce dernier m'a dit qu'il n'a détecté aucuns problèmes particuliers.
Je n'ai pas encore testé avec MemTest86+, car il faut créer un boot sur cléf USB ou CD. Si vous pensez que c'est hyper important d'effectuer ce test, dites le moi.
Pour information, voici l'intégralité de ma configuration :
- Carte mère Gigabyte GA-EX58-UD5 (Intel® X58 + ICH10R Chipset)
- Processeur Intel® Core™ i7-920 Processor (8M Cache, 2.66 GHz, 4.80 GT/s Intel® QPI) O/C à 3.7 GHz
- Pc Skill Mémoire système 12288 Mo (3X4go) (DDR3-1333 DDR3 SDRAM Triple Channel)
- Carte graphique Gygabyte GeForce GTX 670 TriForce GDDR5
- CORSAIR TX750M (750 Watts) Modulaire
- 1 Disque dur ST1000DM003-9YN162 ATA Device (1000 Go, 7200 RPM, SATA-III)
- 1 Disque dur ST2000DL003-9VT166 ATA Device (2000 Go, 5900 RPM, SATA-III)
- 1 Disque dur ST31000528AS ATA Device (1000 Go, 7200 RPM, SATA-III)
- 1 Disque dur ST3500320AS ATA Device (2000 Go, 7200 RPM, SATA-III)
- 2 Graveurs Lecteur optique Optiarc DVD RW AD-7200A SCSI CdRom Device
- 1 ventilo 12cm 4 leds pour boitier PC Avant
- 1 ventilo 12cm 4 leds pour boitier PC Arrière
- 1 ventilo 8cm 4 leds pour boitier PC Central
- 1 gestionnaire de ventilo AKASA facade avant
- 5 prises USB 2.0 utilisées (modem, imprimante, manette, web cam et micro)
- Moniteur Hannstar HH281 28pouces (027LK3QA00810)
- LCD Sharp - LC-46XL2E 100hz 46pouces (120cm) FULL HD 1920x1080
Ma config n'est plus dernier cri, mais je sais aussi qu'elle tient encore parfaitement la route pour les jeux présents et à venir.
Concernant l'overclocking, étant novice en la matière, dans le BIOS, plutôt que de mal faire, j'ai préféré quasiment rien faire. J'ai donc laissé toutes les valeurs de tension par défaut (en "Auto" ) et je me demande si en augmentant manuellement très légèrement le VCore* cela réglerait peut-être le problème...mais en même temps je n'en suis pas sur.
* (le Vcore est la tention appliquée à la RAM et au Pross je crois, mais je suis pas sur)
A noter enfin, que mon problème survient UNIQUEMENT en FULL et JAMAIS en IDLE (c'est important à savoir).
A noter aussi que j'ai déjà eu le BSOD en retirant complètement l'Overcloking, mais en laissant le mode Turbo du Pross, RAM, etc...
A noter encore que mon overcloking est "en auto", j'insiste sur ce point. Par exemple, quand j'overclock, je laisse le mode Turbo du Pross. Je suis pas sur que ce soit une bonne idée...
A noter toujours qu'à l'époque, quand j'ai overcloké, sur OCCT, quand je faisais un Benchmark, le test plantait systématiquement pour surchauffe dues aux mauvais réglages des tensions en "auto". A l'époque, cela ne m'inquiétait pas car mon overclock n'est pas de 100% (seulement de 39%).
A noter que les BSOD ont augmenté depuis Juillet, car n'ayant pas une carte graphique puissante avant ce mois de juillet, je ne jouais pas beaucoup à de gros jeux gourmands (GTA4, BF3 et Farcry3 essentiellement). Sans oublier la hausse spectaculaire des températures météorologiques (fatale à mon ancienne alimentation).
Merci d'avance...
Mes pistes sont peut-être pas les bonnes. Je suis ouvert à toutes suggestions.
Message édité par oll le 08-09-2013 à 11:04:28
Marsh Posté le 31-08-2013 à 01:28:20
Nouvelles informations en vrac :
- J'ai fais des stress tests de ma CG avec FurMark (en Full HD de 15mins) et tout est resté parfaitement stable (78° et ventilos à 51%).
- J'ai fais la même chose avec mon Pross en utilisant CPU Burn It (15mins aussi) et pas de BSOD
- Est ce que ce lien peut faire avancer les choses? => http://steamcommunity.com/app/4316 [...] /?l=french
Il y est sujet d'un rapport entre ce type de BSOD et le réglage du VCore (qui est sur Auto dans mon BIOS je le rappel).
Marsh Posté le 31-08-2013 à 08:25:18
Un mauvais vcore peut te faire planter mais aussi de mauvaises latences de rams te feront planter.
Essai de tout remettre par defaut en cherchant le vcore mini pour ta config ainsi que de bien regler tes rams dans un 1er temps,voir si tout fonctionne correctement
Marsh Posté le 31-08-2013 à 08:42:43
Salut Superradada,
Comment savoir si j'ai un mauvais VCore et de mauvaises latences de rams?
Quand je vais sur Everest pour lire les spécificités de mes 3 barrettes de RAM, je n'y comprends rien.
Voici ces infos:
DIMM1: G Skill F3-12800CL9-4GBSR 4 Go DDR3-1600 DDR3 SDRAM  (10-10-10-27 @ 761 MHz)  (9-9-9-24 @ 685 MHz)  (8-8-8-22 @ 609 MHz)  (7-7-7-19 @ 533 MHz)  (6-6-6-16 @ 457 MHz)
DIMM3: G Skill F3-12800CL9-4GBSR 4 Go DDR3-1600 DDR3 SDRAM  (10-10-10-27 @ 761 MHz)  (9-9-9-24 @ 685 MHz)  (8-8-8-22 @ 609 MHz)  (7-7-7-19 @ 533 MHz)  (6-6-6-16 @ 457 MHz)
DIMM5: G Skill F3-12800CL9-4GBSR 4 Go DDR3-1600 DDR3 SDRAM  (10-10-10-27 @ 761 MHz)  (9-9-9-24 @ 685 MHz)  (8-8-8-22 @ 609 MHz)  (7-7-7-19 @ 533 MHz)  (6-6-6-16 @ 457 MHz)
Concernant le BIOS, ce dernier est à jour (F13) et je vais faire un VALUE DEFAUT (F5 je crois).
Message édité par oll le 31-08-2013 à 08:45:34
Marsh Posté le 31-08-2013 à 09:19:27
Humm je regarderais la carte graphique en première intention.
Message édité par embar_go le 31-08-2013 à 09:20:12
Feedback: http://forum.hardware.fr/hfr/Achat [...] 5359_1.htm
Marsh Posté le 31-08-2013 à 12:14:58
Ok, merci pour cette intuition embar_go.
Cependant comment en être bien sur?
J'ai fais des stress tests avec Furmark sans trop pousser (Test sur 15min en 1920 par 1080 + MSAA à 0) => 4096 points et aucuns BSOD. Le PC ronronnait à merveille.
Par contre, je fais 30mins à 1h de BF3, Farcry3 ou GTA4 et j'ai le BSOD.
Que faire de plus?
Marsh Posté le 31-08-2013 à 13:06:45
L'idéale serait de la tester sur un autre PC (celui d'un pote?) avec les mêmes jeux afin de valider si c'est elle ou pas qui pose souci.
Marsh Posté le 31-08-2013 à 13:47:13
Salut fait un test de tes barrettes de ram avec memcheck .
J'avais le même soucis de BSOD aléatoire qui arrivait quand je jouais sur BF3 et pour moi c'est une barrette qui était défectueuse.
Si ça peut t aider
Marsh Posté le 31-08-2013 à 16:23:14
Tout peut m'aider, merci les gars.
Je vais tester avec Memcheck.
Je suis intimement persuadé que cela vient soit des réglages du Bios de la carte mère (augmenter le Vcore?), soit de la RAM.
La carte graphique, j'en suis pas trop convaincu, car je l'ai depuis début Avril et je n'avais quasiment aucuns BSOD.
J'ai également fait des Benchs hier, elle est monté à plus de 75°, idem pour le Pross et ça n'a pas flanché.
Par contre, je n'avais quasiment aucuns BSOD avant que mon alim ne me lâche (c'était une Corsair 620HX). Les BSOB récurrents ont commencé depuis que ma nouvelle est arrivée (une Corsair TX750M).
Je me demande si les "nouvelles" tensions fournies par ma nouvelle alim conviennent à mes vielles barrettes et/ou à mon pross.
A propos des barrettes, qui pourrait m'expliquer ou et comment savoir qu'elles sont leurs valeurs actuelles, si ces valeurs conviennent à ma config et si elles ne devraient pas être réajustées via le BIOS?
Message édité par oll le 31-08-2013 à 16:46:14
Marsh Posté le 31-08-2013 à 16:31:41
Concernant Memcheck, c'est une véritable usine à gaz. Tu as pas une petite appli plus simple?
EDIT: Je vais (re)faire un test avec une version de Memtest+86 sur CD bootable. Pour rappel, j'en avais déjà fait un avec l'outil de Diagnostic mémoire fourni dans Windows 7 et ce dernier n'avait détecté aucunes erreurs.
Message édité par oll le 31-08-2013 à 16:46:29
Marsh Posté le 31-08-2013 à 20:29:01
Ho Ho! ton Proc est O/C   ????????
Message édité par embar_go le 31-08-2013 à 20:29:33
Marsh Posté le 31-08-2013 à 21:23:12
Il l'était (voir premier post).
La j'ai remis les réglages d'usine, j'ai testé les barrettes avec MemTest+86, 0 erreurs détectées et là j'attends le prochain BSOD pour voir ce que ça donne avec les réglages d'usine.
J'avais déjà essayé en retirant les réglages de l'overclocking et j'avais eu un BSOD. Par contre, je n'ai jamais essayé avec les réglages d'usine.
Marsh Posté le 31-08-2013 à 23:05:50
0x124 sur nehalem c'est pas le vcore mais le voltage du sous système RAM il me semble.
son nom dans le bios dépend du constructeur de carte mère. QPI VTT chez moi.
Ne pas mettre VTT > Vcore + 0.5v
Cyrix 5x86 120MHz, Tseng Labs ET4000/W32p VLB, Doom@45FPS <3
Marsh Posté le 31-08-2013 à 23:52:30
Voici un document qui vaut de l'or à mes yeux:
=> http://dl.free.fr/ctf4fSQMW
Il s'agit du mode d'emploi du BIOS de ma carte mère, toutes les spécifications y sont mentionnées ainsi que la meilleure manière d'overclocker.
Marsh Posté le 01-09-2013 à 10:26:25
Pour info:
J'ai fais une Stress Test d'1h en 1980/1200 MSAA X8 sur ma CG avec Furmark...toujours aucuns BSOD.
J'ai remis les réglages d'usine ("Optimized Values"...touche F6 dans le BIOS), j'ai ensuite un peu augmenté le CPU VCore (1.36125v au lieu de 1.3500v) et QPI/VTT Voltage (1.1200v au lieu de 1.1100v) et j'ai laissé tourner GTA4 pendant 1h => pas de BOSD.
Je vais relancer GTA4 pendant 2h et je verrai bien. Je ne pense pas que mon problème soit réglé pour autant, car ce BSOD peut survenir au bout de 15min comme 3h de jeu...va comprendre.  :ange:
Marsh Posté le 01-09-2013 à 17:01:46
perso, j'ai le même BSOD, et dans mon cas c'est le processeur qui est la cause, dès que je dépasse 4Go ça plante, que j'ai plus de 4Go physique, ou que je swape parce que j'ai besoin de plus de 4Go.
ça a pas été le plus simple à diagnostiquer.
un jour, moi aussi, je serais grand...
Marsh Posté le 01-09-2013 à 18:45:45
Moi aussi c'est pas simple. Je regarde avec insistance de plus en plus en direction du microprocesseur.
Le dépassement des 4go, perso, j'y crois moyen me concernant. Que ce soit GTA4, BF3 ou FC3, je pense pas que ces 3 jeux consomment plus de 3go de mémoire.
Beaucoup de changements dans mon ordi ces 8 derniers mois:
- Passage de Windows XP 32 Bits à Windows 7 64 bits
- Passage de 3go de RAM 1333MHz à 12go de RAM à 1600MHz
- Passage d'une CG GTX470 à une GTX670 très gourmande
- Ajout de 2 DD en + (4 en tout)
- Alim Corsair 620W grillée pendant l'été (jamais bon pour le matos)
- Remplacement Alim pour une Corsair 750W (tensions différentes)
Le tout sur une CM qui commence à dater (2009) ainsi qu'un vieux I7 920 O/C depuis le début (2009) qui commence peut-être tout simplement à donner quelques signes de fatigue.
Et voilà où j'en suis à ce jour:
1/Pas d'overclocking:
Système stable (GTA4 sans BSOD pendant + de 2h), CPU Vcore et QPI/VTT Voltage modifiables (je sais, c'est con, y'a aucuns intérêt à modifier des valeurs sur un système non O/C, mais au moins je peux).
2/ Retour de l'overcloking (inchangé depuis 2009):
BCLK fréquence à 185 (au lieu de 133), multiplicateur à X20 pour une cadence de 3.7MHz (O/C de 39%) contre 2.6MHz d'origine.
Le CPU Vcore est modifiable, j'en ai profité pour le mettre à 1.3125v ou lieu d'1.3000v) si je descends en dessous de 1.3v, j'ai un loop reboot. Obligé de faire un CLEAR CMOS (vive cette petite option).
Si j'augmente le QPI/VTT, le système refuse de se lancer et revient au BIOS avec le Fail-Safe Defaut au bout du 2ème reboot.
Les BSOD font leurs retours aussi. Bug Check Error 0x101 (problème de vidage de mémoire) ou la 0x124.
Ce que je pige pas, c'est que lorsque j'ai le BSOD en FULL, le système est froid (environ 60°...et environ 45° en IDLE). Je pige pas vraiment si l'instabilité du système provient d'une surchauffe ou d'une insuffisance électrique.
En cas d'insuffisance électrique, le système ne booterait pas? n'est pas? (Je suis pas un pro de l'overclocking).
Je crois que le moment de passer à quelque chose de bien plus récent niveau Pross, CM et RAM est sur le point de s'avérer imminent. Cela ne m'arrange pas, car je pensais faire une année de plus avec ce matos sans trop être à la traine. Les évènements récents d'instabilité sont sans doute en train de me montrer que je me trompe...
Message édité par oll le 01-09-2013 à 19:02:00
Marsh Posté le 01-09-2013 à 19:57:33
45° en idle je trouve sa un peu chaud.
Apparemment tes latences de rams dans le bios devrait etre 9-9-9-24 et certainement 2T.
Regle deja convenablement sa avant de faire un quelconque O/C.
Retour a 133 de BCLK car d'apres ce que je lis je pense que c'est ton O/C qui ne vas pas du tout.
Essai aussi de trouver tout les bons reglage manuel sans O/C pour avoir un systeme qui fonctionne sans trop chauffer et surtout sans planter
Si Furmark fait pas de BSOD tu peut exclure la CG (regarde tout de meme dans le bios si elle est correctement detecter).
En cas d'insuffisance electrique le systeme peut booter mais en charge il reboot net et souvent sans BSOD.
Marsh Posté le 08-09-2013 à 11:07:44
J'ai résolu mon problème de BSOD.
Je n'en suis pas sur à 100%, mais je pense qu'en changeant d'alim et de carte graphique, mon O/C était devenu instable. Les tensions délivrées par la nouvelle alim n'étaient peut-être pas exactement les mêmes que celles fournies par l'ancienne?
J'ai fait un CLEAR CMOS, refait mon O/C (Micropross cadencé à 3.70MHz au lieu de 2.60MHz) et depuis plus aucuns BSOD. Même après des heures et des heures de jeux.
A noter aussi qu'il fait beaucoup beaucoup moins chaud qu'aux mois de juillet et août.
Merci à tous.
Message édité par oll le 09-09-2013 à 01:13:54
