Problème au démarrage ??? multiprise? - Matériels & problèmes divers - Hardware
Marsh Posté le 05-02-2018 à 18:58:41
Check HWMONITOR :
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.1.0
Monitoring
Mainboard Model Z270 GAMING PRO CARBON (MS-7A63) (0x000007CB - 0xE5BE7238)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6795
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xD3
LPCIO Revision ID 0x52
Config Mode I/O address 0x4E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 30 C0 10 00 FF FF
20 D3 52 FF 00 00 00 40 03 00 FF 58 00 10 00 00 18
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 20 0A 30 00 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A20
Hardware Monitors
Hardware monitor Nuvoton NCT6795
Voltage 0 1.26 Volts [0x9E] (CPU VCORE)
Voltage 1 1.01 Volts [0x7E] (VIN1)
Voltage 2 3.41 Volts [0xD5] (AVCC)
Voltage 3 3.30 Volts [0xCE] (3VCC)
Voltage 4 1.02 Volts [0x7F] (VIN4)
Voltage 5 0.14 Volts [0x12] (VIN5)
Voltage 6 1.33 Volts [0xA6] (VIN6)
Voltage 7 1.38 Volts [0xAC] (VIN7)
Voltage 8 1.26 Volts [0x9E] (VIN8)
Voltage 9 0.68 Volts [0x55] (VIN9)
Voltage 10 1.02 Volts [0x7F] (VIN10)
Voltage 11 1.01 Volts [0x7E] (VIN11)
Voltage 12 1.33 Volts [0xA6] (VIN12)
Voltage 13 1.01 Volts [0x7E] (VIN13)
Voltage 14 0.00 Volts [0x0] (VIN14)
Temperature 0 28 degC (82 degF) [0x1C] (SYSTIN)
Temperature 1 36 degC (95 degF) [0x47] (CPUTIN)
Temperature 3 63 degC (145 degF) [0x3F] (TMPIN3)
Temperature 5 35 degC (95 degF) [0x23] (TMPIN5)
Temperature 6 28 degC (82 degF) [0x1C] (TMPIN6)
Fan 1 845 RPM [0x34D] (CPUFANIN)
Fan 3 939 RPM [0x3AB] (AUXFANIN1)
Fan 4 946 RPM [0x3B2] (AUXFANIN2)
Hardware registers
bank 0
00 03 8A 03 8A 00 FF FF FF FF FF FF FF FF FF FF FF
10 03 93 03 93 03 93 03 93 40 7D AC 00 7E 55 C1 00
20 9E 7E D5 CE 7F 12 A6 1C FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 23 00 07 DF DF 00 2F FF 2D FF FF 10 00 55 00 A3
50 05 FF FF FF FF FF FF FF C1 FF FF FF FF 02 02 00
60 63 F0 FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 3F 00 3F 00 3F 00 3F 00 3F 00 3F 00 FF
80 FF 7F 3F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 01 00
B0 00 00 00 00 00 00 26 00 04 00 00 00 74 C0 04 00
C0 FF FF FF FF FF FF FF FF FF 0D 04 05 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 FF 1C 00 40 03 D7 FF FF FF
bank 1
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
80 9E 7E D5 CE 7F 12 A7 D5 00 7D AC 00 7E 55 C1 00
90 1C 23 09 06 7F FD 00 26 C0 3F 3F 3F 3F 3F 1F 3F
bank 5
bank 6
bank 7
Hardware monitor NVIDIA NVAPI
Voltage 0 0.68 Volts [0x2A3] (GPU)
Power 0 17.38 pc (GPU)
Temperature 0 51 degC (123 degF) [0x33] (GPU)
Fan 0 0 RPM [0x0] (GPU)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 1683.00 MHz [0x693] (Graphics)
Clock Speed 1 5005.00 MHz [0x693] (Memory)
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
Perf timer 4.102 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Name Intel Core i7 7700K
Codename Kaby Lake
Specification Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
Package (platform ID) Socket 1151 LGA (0x1)
CPUID 6.E.9
Extended CPUID 6.9E
Core Stepping B0
Technology 14 nm
TDP Limit 91.0 Watts
Tjmax 100.0 °C
Core Speed 4400.0 MHz
Multiplier x Bus Speed 44.0 x 100.0 MHz
Stock frequency 4200 MHz
Max frequency 4500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 4-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 00000016h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 42x
Max turbo ratio 45x
Max efficiency ratio 8x
Speedshift Autonomous
O/C bins unlimited
Ratio 1 core 45x
Ratio 2 cores 44x
Ratio 3 cores 44x
Ratio 4 cores 44x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Temperature 0 58 degC (136 degF) (Core #0)
Temperature 1 65 degC (149 degF) (Core #1)
Temperature 2 57 degC (134 degF) (Core #2)
Temperature 3 63 degC (145 degF) (Core #3)
Temperature 4 65 degC (149 degF) (Package)
Voltage 0 1.27 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Power 0 58.79 W (Package)
Power 1 54.74 W (IA Cores)
Power 2 n.a. (GT)
Power 3 4.05 W (Uncore)
Power 4 2.60 W (DRAM)
Clock Speed 0 4400.00 MHz (Core #0)
Clock Speed 1 4400.00 MHz (Core #1)
Clock Speed 2 4400.00 MHz (Core #2)
Clock Speed 3 4400.00 MHz (Core #3)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x00000016 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000906E9 0x00100800 0x7FFAFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C30000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x00C0003F 0x000003FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00142120
0x00000006 0x000027F7 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x029C6FBF 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300404 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x0000001F 0x00000440 0x00000440 0x00000000
0x0000000D 0x0000000F 0x00000440 0x00000100 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x0000000D 0x00000040 0x000003C0 0x00000000 0x00000000
0x0000000D 0x00000040 0x00000400 0x00000000 0x00000000
0x0000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x00000010 0x00000000 0x00000000 0x00000000 0x00000000
0x00000011 0x00000000 0x00000000 0x00000000 0x00000000
0x00000012 0x00000000 0x00000000 0x00000000 0x00000000
0x00000013 0x00000000 0x00000000 0x00000000 0x00000000
0x00000014 0x00000001 0x0000000F 0x00000007 0x00000000
0x00000015 0x00000002 0x0000015E 0x00000000 0x00000000
0x00000016 0x00001068 0x00001194 0x00000064 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000121 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3037372D 0x43204B30 0x40205550
0x80000004 0x322E3420 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x00000770 0x00000000 0x00000001
MSR 0x00000774 0x0000019E 0x5400FF02
MSR 0x000000CE 0x00080838 0xF1012A00
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x2C2C2C2D
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88270808
MSR 0x000001FC 0x00000000 0x0038005D
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00000000 0x80000000
MSR 0x00000610 0x0042FFFF 0x001DFFFF
MSR 0x00000611 0x00000000 0x1A24E684
MSR 0x00000639 0x00000000 0x1764C2E8
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x00F4FD4A
MSR 0x00000614 0x00000000 0x000002D8
MSR 0x0000019C 0x00000000 0x88270808
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x0000291D 0x00002C00
MSR 0x00000199 0x00000000 0x00002A00
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x000906E9 0x01100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000001B1 0x00000000 0x88210808
MSR 0x00000611 0x00000000 0x1A251694
MSR 0x00000639 0x00000000 0x1764EED4
MSR 0x00000619 0x00000000 0x00F4FF18
MSR 0x0000019C 0x00000000 0x88210808
MSR 0x00000198 0x0000292C 0x00002C00
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x000906E9 0x02100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x000001B1 0x00000000 0x88260808
MSR 0x00000611 0x00000000 0x1A254919
MSR 0x00000639 0x00000000 0x17651E8B
MSR 0x00000619 0x00000000 0x00F500FB
MSR 0x0000019C 0x00000000 0x88260808
MSR 0x00000198 0x00002947 0x00002C00
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x000906E9 0x03100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x000001B1 0x00000000 0x88250808
MSR 0x00000611 0x00000000 0x1A2577D8
MSR 0x00000639 0x00000000 0x17654A15
MSR 0x00000619 0x00000000 0x00F50283
MSR 0x0000019C 0x00000000 0x88250808
MSR 0x00000198 0x000028D8 0x00002C00
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000906E9 0x04100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x1A25A857
MSR 0x00000639 0x00000000 0x176576B6
MSR 0x00000619 0x00000000 0x00F50438
MSR 0x00000198 0x00002930 0x00002C00
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x000906E9 0x05100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x1A25DCF7
MSR 0x00000639 0x00000000 0x1765A70B
MSR 0x00000619 0x00000000 0x00F5061D
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x000906E9 0x06100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x000001B1 0x00000000 0x88240808
MSR 0x00000611 0x00000000 0x1A260974
MSR 0x00000639 0x00000000 0x1765CFF4
MSR 0x00000619 0x00000000 0x00F50739
MSR 0x0000019C 0x00000000 0x88240808
MSR 0x00000198 0x0000295C 0x00002C00
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
CPUID
0x00000001 0x000906E9 0x07100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0x1A263DDF
MSR 0x00000639 0x00000000 0x176600D5
MSR 0x00000619 0x00000000 0x00F5094F
MSR 0x00000198 0x000028D7 0x00002C00
Storage
Drive 0
Device Path \\?\scsi#disk&ven_samsung&prod_ssd#4&28879c9a&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Bus Type 11
Name Samsung SSD 850 EVO 250GB
Capacity 232.9 GB
SMART Support Yes
Volume c:\, 232.3 GBytes (33.0 percent available)
Drive 1
Device Path \\?\usbstor#disk&ven_&prod_usb_disk_2.0&rev_pmap#07b11902bb4a08db&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Bus Type 7
Name USB DISK 2.0
Capacity 7.5 GB
SMART Support Yes
Volume i:\, 7.5 GBytes (65.6 percent available)
Drive 2
Device Path \\?\scsi#disk&ven_st1000dm&prod_010-2ep102#4&28879c9a&0&000200#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Bus Type 11
Name ST1000DM010-2EP102
Capacity 931.5 GB
SMART Support Yes
Volume d:\, 931.5 GBytes (33.1 percent available)
Drive 3
Device Path \\?\usbstor#disk&ven_lexar&prod_usb_flash_drive&rev_8.07#2012111715280335943d&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Removable
Bus Type 7
Name Lexar USB Flash Drive
Capacity 7.3 GB
SMART Support Yes
Volume g:\, 7.3 GBytes (56.8 percent available)
USB Devices
USB Device Dispositif de stockage de masse USB, class=0x00, subclass=0x00, vendor=0x05DC, product=0xC756
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x1B1C, product=0x1B33
USB Device Dispositif de stockage de masse USB, class=0x00, subclass=0x00, vendor=0x13FE, product=0x3D00
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x046D, product=0xC332
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 1080
Board Manufacturer Micro-Star International Co., Ltd. (MSI)
Revision A1
Codename GP104
Technology 16 nm
Memory size 8 GB
Memory type GDDR5X
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1462)
Model ID 0x1B80 (0x3362)
Performance Level 0
Monitor 0
Model SyncMaster (Samsung)
ID SAM030D
Serial HS3PC06269
Manufacturing Date Week 50, Year 2007
Size 22.0 inches
Max Resolution 1680 x 1050 @ 59 Hz
Horizontal Freq. Range 30-81 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 140 MHz
Gamma Factor 2.2
Monitor 1
Model PLG2788H (Idek Iiyama)
ID IVM6627
Serial 0
Manufacturing Date Week 0, Year 2015
Size 27.2 inches
Max Resolution 1920 x 1080 @ 144 Hz
Horizontal Freq. Range 159-159 kHz
Vertical Freq. Range 45-144 Hz
Max Pixel Clock 330 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Marsh Posté le 05-02-2018 à 19:52:10
Ton post est un chouilla court
Marsh Posté le 05-02-2018 à 20:08:58
Au moins tout est là pour répondre à ma question.
Maintenant tu aurais peut-être une réponse?
Sans animosité aucune !
Marsh Posté le 11-02-2018 à 13:26:10
Mon alimentation Amacrox Warrior AX-500-A me faisait des misères à chaque boot à froid.
Les disques durs commençaient à démarrer puis l'alimentation s'éteignait.
Après trois secondes l’alimentation redémarrait et s’éteignait à nouveau.
Au bout de plusieurs cycles le PC arrivait à démarrer.
Puis un jour il s'est éteint brusquement et n'a plus jamais redémarré.
J'ai changé l'alimentation par une Seasonic G-480 et depuis ça roule...
Marsh Posté le 11-02-2018 à 13:43:08
Disons que le log complet de hwmonitor est dur a lire et que le listing de registres sur 3 pages ne sert a rien. Une bonne capture écran serait 10x plus parlante.
Tout dépend de ton installation électrique, ce qu'il y a sur la multiprise, si tu as une prise de terre fonctionnelle etc.
Marsh Posté le 12-02-2018 à 12:00:28
Alors, pour l'alim c'est une evga 650w gold 80+ comme dit donc ça serait étonnant un souci de ce côté là.
Côté installation électrique, je n'ai pas de terre, ni de multiprise parafoudre, un contrat 6kvar chez edf et la multiprise est occupé par le PC (alimentation + 2 écrans + box SFR) = 4/8 emplacements utilisés.
Côté software, si les informations ci-dessus ne suffisent pas à établir une réponse, que puis-je faire?
Merci de votre aide zonka et Col Hanzaplast.
Marsh Posté le 12-02-2018 à 12:59:29
La terre est quand même conseillée/obligatoire pour un PC ;(
Marsh Posté le 12-02-2018 à 19:08:12
| zonka a écrit : La terre est quand même conseillée/obligatoire pour un PC ;( |
Justement, j'en parlais avec un électricien, il me disait que la terre ne protège en aucun cas le matériel mais l'utilisateur.
Je dis ça parce que ça me stressait, chez moi pas de terre sauf dans les salles d'eau. J'ai quand même fait refaire entièrement mon tableau et mes pc se portent à merveille, j'ai même de très vieux pc : 386 SX 16, P200, PIV ect...
Par contre si tu veux une bonne multiprise qui gère les surtensions par exemple prise de terre obligatoire oui
Marsh Posté le 13-02-2018 à 07:42:39
Donc ce probleme de démarrage pourrait être lié à un pb de l'installation élerctrique plutôt qu'à l'alimentation?
Marsh Posté le 13-02-2018 à 08:14:54
Perso je ne pense pas sincèrement, sauf si ton installation/tableau sont vraiment anciens mais bon, j'ai des doutes...
Marsh Posté le 13-02-2018 à 08:30:01
Quand tu éteins ta multiprise ton alim cesse de recevoir de l'électricité et donc se décharge. Même si c'est une alim de qualité une petite panne peut toujours arriver (surtout sans prise de terre), essaye donc avec une autre alim.
PS : Efface ton rapport HWMonitor c'est inutile et très long...
Marsh Posté le 13-02-2018 à 09:37:05
le problème est récent? ou t'as souvent ça?
avant de se lancer dans une dépense pour une nouvelle alim, je testerais d'abord:
- vérifier s'il n'y a pas des travaux en cours sur le reseau (dans ta rue etc), au cas où ce serait la cause d'un souci électrique plus général
- ne pas éteindre le multiprise après avoir éteint le pc
- un autre multiprise
- dans une autre pièce
Si rien n'y fait, tu connais un peu le schema de ton installation électrique? Tu sais sur quel fusible tout ça est branché au tableau? Si y'a bcp de gros electros dessus? L'ampérage du fusible?
Marsh Posté le 13-02-2018 à 09:46:03
| kabyll a écrit : le problème est récent? ou t'as souvent ça? |
+ 1 : je ne coupe jamais ma multiprise, sauf quand je parts en vacances
Marsh Posté le 13-02-2018 à 11:45:20
Je suis le sujet pour ma part de temps en temps je coupe la multiprise ( je n'ai pas de terre aussi ) et quand je la ré arme j'ai des petits bruits de temps en temps , hormis samedi ou j'ai eu un gros boom avec un flash blanc dans la tour .... , la faute à qui ? je sais pas en tout cas l'alim est hs mais pas la multiprise.
J'ai eu le même discoure aussi d'un collègue électricien de formation la terre sert à nous protéger nous et non le matos ...
Marsh Posté le 05-02-2018 à 18:57:10
je viens de rentrer chez moi et en démarrant mon pc, je me suis rendu compte qu'au bout de 5s il s'éteignait...
Plusieurs essais, tjrs pareil
Ensuite, j'ai éteint la multiprise auquel il est branché, et en la rallumant et en rallumant l'ordi tout remarche.
Cependant, j'aimerai savoir quel peut etre le souci, car je ne suis plus serein maintenant.
Merci d'avance,
Config (pc monté en mai dernier)
Case : AEROCOOL P7 C1 TEMPERED GLASS
Motherboard : MSI Z270 GAMING PRO CARBON
Cpu : INTEL i7 7700k 4.2 GHz
Gpu : MSI GTX 1080 GAMING X
Dram : CORSAIR VENGEANCE DDR4 3200 MHz 2x8Go
Hdd : Seagate Barracuda 1 To
Sdd : Samsung Evo 240 Go
Psu : EVGA Supernova 550W 80+ GOLD
Sound card : ASUS Xonar DSX
Cpu Air Cooling : BE QUIET Pure Rock
