Equivalent à Gigabyte GA-EP31-DS3L [Topic Minute] - Carte mère - Hardware
Marsh Posté le 25-11-2013 à 10:16:55
Processeur
Support for an Intel® Core™ 2 Extreme processor/ Intel® Core™ 2 Quad processor/ Intel® Core™ 2 Duo processor/ Intel Pentium processor Extreme Edition/ Intel® Pentium D processor/ Intel® Pentium 4 processor Extreme Edition/ Intel® Pentium 4 processor/ Intel® Celeron processor in the LGA 775 package
Support for Intel Hyper-Threading Technology
L2 cache varies with CPU
FSB
1600(O.C.)/1333/1066/800 MHz FSB
Chipset
North Bridge: Intel® P31/G31 Express Chipset
South Bridge: Intel® ICH7
Mémoire
4 x 1.8V DDR2 DIMM sockets supporting up to 4 GB of system memory
Dual channel memory architecture
Support for DDR2 1066/800/667 MHz memory modules
Because of chipset limitations
*To avoid the system being unable to start or the memory being incorrectly detected, if only one memory module is to be installed, we suggest that you install it on the DDR2_1 or DDR2_3 socket.
*To install two memory modules, we suggest that you install them on the DDR2_1 and DDR2_3 sockets, when the DDR2_2 or DDR2_4 socket is populated with a DDR2 1066 MHz memory module, the memory speed will be downgraded to 800 MHz).
*when using FSB 1333 MHz CPU with populating all DIMM sockets, memory frequency will be reduced from the original, and system instability or incorrect detection of memory module may be occur.
(Please refer "Memory Support List" for memory support information)
Audio
Realtek ALC888 codec
High Definition Audio
2/4/5.1/7.1-channel
Support for S/PDIF In/Out
Support for CD In
Réseau
RTL 8111C chip (10/100/1000 Mbit)
Port d'expansion
1 x PCI Express x16 slot
3 x PCI Express x1 slots
3 x PCI slots
Interface de Stockage
South Bridge:
1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
1 x floppy disk drive connector supporting up to 1 floppy disk drive
USB
Integrated in the South Bridge
Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Marsh Posté le 25-11-2013 à 11:32:29
Bon après renseignement, j'ai une config de vieux croûtons
J'ai trouvé cela : http://www.grosbill.com/4-intel_h_ [...] htpc_intel
Processeur Core i3-3220 3.30GHz
Carte mère MSI Z77A-G41 - Chipset Intel Z77
CORSAIR DDR3 Value Select 4Go (2x2Go) 1333Mhz
le tout a 208 euro
Sachant que j'ai une radeon 7780 (a quelque chiffre pret
Niveau rapport qualité prix c'est good ?
Marsh Posté le 25-11-2013 à 10:14:38
Ma CM a grillé hier, je vais courir ce midi à Montgallet pour en acheter une autre.
J'aimerai vos avis d'expert ( avant midi plz) pour acheter l'équivalent en mieux que la Gigabyte GA-EP31-DS3L
Mon proc c'est un Core I3 2,5Ghz/2M/800/06
Ma Ram DDR2 PC 6400
Merci pour les infos
J'aimerais ne pas dépasser les 70 euros, l'USB 3 serait un plus mais pour pas trop chère sinon je m'en passe.
www.pronovolley.fr Faites vos prono sur la ligue de Volley et défiez vos amis. Des cadeaux en fin d'année www.levoll.fr
