Depuis quelques temps, lorsque j'allume mon pc, j'ai un bluescreen, j'ai dl whocrashed pour découvrir la cause des ces crash, et voici les rapports :
Spoiler :
On Fri 11/12/2015 16:53:44 GMT your computer crashed crash dump file: C:\Windows\Minidump\121115-17531-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x14E2E0) Bugcheck code: 0xA (0xFFFFF685D7F000B8, 0x2, 0x0, 0xFFFFF800AE92D9A4) Error: IRQL_NOT_LESS_OR_EQUAL file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Spoiler :
On Fri 11/12/2015 16:53:44 GMT your computer crashed crash dump file: C:\Windows\memory.dmp This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0) Bugcheck code: 0xA (0xFFFFF685D7F000B8, 0x2, 0x0, 0xFFFFF800AE92D9A4) Error: IRQL_NOT_LESS_OR_EQUAL Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Spoiler :
On Fri 11/12/2015 05:10:53 GMT your computer crashed crash dump file: C:\Windows\Minidump\121115-9625-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x14E2E0) Bugcheck code: 0x19 (0x20, 0xFFFFC000167E8000, 0xFFFFC000167E8810, 0x5810000) Error: BAD_POOL_HEADER file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that a pool header is corrupt. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Spoiler :
On Fri 04/12/2015 05:04:37 GMT your computer crashed crash dump file: C:\Windows\Minidump\120415-10796-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x14E2E0) Bugcheck code: 0x139 (0x3, 0xFFFFD00033D4D550, 0xFFFFD00033D4D4A8, 0x0) Error: KERNEL_SECURITY_CHECK_FAILURE file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: The kernel has detected the corruption of a critical data structure. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Je précise que j'ai monté mon pc moi même, avec windows 10. J'ai cherché pour avoir des infos sur la cause de ce crash, sur le support il est indiqué qu'il s'agit de problèmes de drivers, mais mes drivers sont à jour.
Voila ma config: Intel i5 4690k kfa2 gtx 970 msi z97 gaming 5 noctua nh-u12s DDR3 Corsair Vengeance Pro, 2 x 8 Go, 1866 MHz, CAS 9 Samsung Série 850 PRO, 256 Go, SATA III Seagate Desktop SSHD, 2 To Asus DRW-24F1MT, Noir Asus PCE-AC68
Après j'ai recup d'anciens hdd, quand j''étais sur w7 je n'avais pas de bluescreen
Je vous remercie d'avance pour votre aide et je vous souhaite une bonne soirée.
Message édité par nukapanda le 13-12-2015 à 10:32:56
Marsh Posté le 12-12-2015 à 21:36:33
Bonsoir à tous,
Voila ma config:
Intel i5 4690k
kfa2 gtx 970
msi z97 gaming 5
noctua nh-u12s
Asus PCE-AC68
