R5 3600 b450 tomahawk max 16go de ram alim corsair 650w rtx 2070 super
j'ai mis tout les pilotes a jour en passant par driver cloud et windows updates , mais voila j'ai des écrans bleu aléatoirement uniquement au démarrage...
j'ai testé :
alimentation , RAM , carte graphique, SSD pas de souci sur les composants a priori
je vous laisse le détail de whocrashed: sachant que ce qui revient a chaque fois c'est a cause de ntoskrnl.exe apparement
On Sat 31/10/2020 16:28:54 your computer crashed or a problem was reported crash dump file: C:\Windows\Minidump\103120-17812-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x3F45A0) Bugcheck code: 0x139 (0x3, 0xFFFFF683FC910070, 0xFFFFF683FC90FFC8, 0x0) Error: KERNEL_SECURITY_CHECK_FAILURE file path: C:\WINDOWS\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: The kernel has detected the corruption of a critical data structure. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sat 31/10/2020 16:28:54 your computer crashed or a problem was reported crash dump file: C:\Windows\MEMORY.DMP This was probably caused by the following module: ntfs.sys (Ntfs+0x1F7C0) Bugcheck code: 0x139 (0x3, 0xFFFFF683FC910070, 0xFFFFF683FC90FFC8, 0x0) Error: KERNEL_SECURITY_CHECK_FAILURE file path: C:\WINDOWS\system32\drivers\ntfs.sys product: Système d’exploitation Microsoft® Windows® company: Microsoft Corporation description: Pilote du système de fichiers NT Bug check description: The kernel has detected the corruption of a critical data structure. The crash took place in a file system driver. Since there is no other responsible driver detected, this could be pointing to a malfunctioning drive or corrupted disk. It's suggested that you run CHKDSK.
On Fri 30/10/2020 20:44:43 your computer crashed or a problem was reported crash dump file: C:\Windows\Minidump\103020-20468-01.dmp This was probably caused by the following module: ntfs.sys (0xFFFFF80320E87CB7) Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF80320E87CB7, 0xFFFF800F9F822208, 0xFFFF800F9F821A40) Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M file path: C:\WINDOWS\system32\drivers\ntfs.sys product: Système d’exploitation Microsoft® Windows® company: Microsoft Corporation description: Pilote du système de fichiers NT Bug check description: This indicates that a system thread generated an exception which the error handler did not catch. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in a file system driver. Since there is no other responsible driver detected, this could be pointing to a malfunctioning drive or corrupted disk. It's suggested that you run CHKDSK.
On Thu 29/10/2020 20:07:30 your computer crashed or a problem was reported crash dump file: C:\Windows\Minidump\102920-14812-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x3F45A0) Bugcheck code: 0x1A (0x403, 0xFFFFE4814EEF4770, 0x82000002C4163867, 0x0) Error: MEMORY_MANAGEMENT file path: C:\WINDOWS\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that a severe memory management error occurred. The page table and PFNs are out of sync . This is probably a hardware error, especially if parameters 3 & 4 differ by only a single bit. This is likely to be caused by a hardware problem. This error suggests a case of memory corruption because of a hardware problem. It is suggested you do a test on your RAM modules (memory test) and make sure your system is not getting overheated. This problem might also be caused because of overheating (thermal issue). The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Wed 28/10/2020 04:46:01 your computer crashed or a problem was reported crash dump file: C:\Windows\Minidump\102820-6484-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x3F45A0) Bugcheck code: 0xEF (0xFFFFBB86FA486080, 0x0, 0x0, 0x0) Error: CRITICAL_PROCESS_DIED file path: C:\WINDOWS\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that a critical system process died. There is a possibility this problem was caused by a virus or other malware. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Tue 27/10/2020 20:10:42 your computer crashed or a problem was reported crash dump file: C:\Windows\Minidump\102720-7531-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x3F45A0) Bugcheck code: 0x1A (0x41790, 0xFFFF8A8007E31290, 0x2D, 0x2E) Error: MEMORY_MANAGEMENT file path: C:\WINDOWS\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that a severe memory management error occurred. A page table page has been corrupted. This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue). The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Marsh Posté le 01-11-2020 à 10:16:19
bonjour a tous ,
Voila je me suis monté une configuration :
R5 3600
b450 tomahawk max
16go de ram
alim corsair 650w
rtx 2070 super
j'ai testé :
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
Merci de votre aide
