Crash sur Deep Rock Galactic ... Sans Crash Loader
Crash sur Deep Rock Galactic ... Sans Crash Loader - Matériels & problèmes divers - Hardware
Marsh Posté le 20-05-2021 à 12:11:41
Salut tous!
Depuis que je joue à Deep Rock Galactic, j'ai des crash aléatoires sans crash loader.
J'ai fait un bug report: https://ghostshipgames.atlassian.net/browse/DRG-3258
Il y a un messages épinglés sur le discord sur les trucs à faire:
Troubleshooting & FAQ
FAQ https://i.imgur.com/nDb2o2K.png
FAQ Answers https://i.imgur.com/DQWpQFU.png
Advanced Troubleshooting
(for crashes, poor performance, or other miscellaneous bugs)
TAKE YOUR TIME AND READ THROUGH EVERYTHING SLOWLY!
MAIN SECTION: >>>>> https://i.imgur.com/6VqZDA4.png<<<<< REFER TO THIS IMAGE FOR ADVANCED TROUBLESHOOTING STEPS IF YOUR ISSUE WASN'T ANSWERED IN THE FAQ
Links from the main section troubleshooting are listed below.
Common crashes, strange bugs, and their solutions:
https://steamcommunity.com/app/5484 [...] 993864094/
AMD FX / Realtek audio fix:
https://steamcommunity.com/app/5484 [...] 339086202/
Broken, missing, or corrupt save files and its fix:
https://steamcommunity.com/app/5484 [...] 769202703/
C++ Runtime bugs (some crashes and failure to launch) and its fix:
https://steamcommunity.com/app/5484 [...] 203501698/
Additional troubleshooting provided by Zamboni:
https://discordapp.com/channels/257 [...] 3474453504
Step 14. https://www.microsoft.com/en-ca/dow [...] aspx?id=35
Step 15. https://www.microsoft.com/en-us/dow [...] x?id=34429
Step 16. https://www.microsoft.com/en-us/dow [...] x?id=30135
Side note regarding the downloads under steps 14 & 15. Microsoft has taken down the pages containing these files. I have located the files uploaded to download.cnet. Download using these links at your own risk as it is not an original source.
Step 14. https://download.cnet.com/Microsoft [...] 54826.html
Step 15. https://download.cnet.com/DirectX-9 [...] 07663.html
Raw text FAQ https://pastebin.com/ECvCNdb1
Raw text Troubleshooting https://pastebin.com/yA0Eativ
Updated 29 April 2021
J'ai TOUT fait, j'ai aussi réinstallé windows. Quand je dis tout, j'ai vraiment, vraiment tout fait un par un.
J'ai remarqué que mon GPU passe à 100% au moment du crash, que je sois en 720p low ou en 1440P Ultra.
Ma config est sur le bug report, mais je la remet ici:
Windows 10 64 Pro, 20H2, Ryzen 5 3600 @stock , GTX 1080Ti @stock , maxed settings, 1440P, except sharpness @ 75%, 144fps as a target/limit, 16Ggb @3200 16  @XMP, Game installed on an SSD. Using a sound card for my mic (not using mic ingame): Creative Audigy 5 RX
Voilà, je me demande si un test avec un CPU, GPU et CM différentes (changement 1 par 1 pour tester) changeront la donne, mais je suis vraiment perdu.
Marsh Posté le 20-05-2021 à 12:16:00
C'est quoi l'alim ?
Marsh Posté le 20-05-2021 à 13:06:10
Une Corsair HX850. Encore une fois, c'est le seul jeu sur lequel ça arrive.
Marsh Posté le 20-05-2021 à 13:31:48
Ben... Heu... Le jeu est codé avec les orteils, point ?
[:clooney5]
Marsh Posté le 20-05-2021 à 17:30:44
 [:clooney5]
Alors en fait je suis le seul à avoir ce problème, le jeu est sorti depuis presque 1 an, et il tourne très bien à part ça.
Le swap de hardware pourrait être utile? Je suis sur bruxelles, alors je pense pouvoir demander de l'aide sur le forum, mais bon, si y a plus simple je prends.
Marsh Posté le 20-05-2021 à 22:37:52
up :(
j'aimerais surtout un avis sur l'échange de composants, si c'est vraiment inutile autant pas le faire du tout.
Marsh Posté le 20-05-2021 à 22:47:34
fais un test OCCT GPU et global, pour voir ce qui se passe.
Si ça plante même en 720p/low, un problème hardware semble peu probable.
Marsh Posté le 20-05-2021 à 23:01:53
Ben si c'est vraiment que sur ce jeu que tu as des soucis, c'est que le souci vient de ce jeu... Et du coup faut te tourner vers eux
On ne pourra pas t'aider beaucoup plus
À la rigueur, je vois que ta version Windows est 21h2... Depuis les 20xx c'est bugué. Si tu as le goût, repasse en 1909, ça résoud souvent pas mal de problemes
Message édité par kenpachi07 le 20-05-2021 à 23:07:52
Marsh Posté le 21-05-2021 à 00:40:03
Je vais faire ça, je savais pas du tout pour la version de windows!
Comme dit je viens de réinstaller windows, donc j'en suis pas à une installation d'update près.
Je vais essayer tout ça, merci beaucoup!
Marsh Posté le 23-05-2021 à 00:35:27
Manque plus que le test OCCT pour être sûr, mais crash même sous 1909. C'est arrivé plus tard, difficile à dire si c'était de la chance ou si ça a amélioré le bordel.
De mémoire j'ai essayé une version driver plus ancienne pour le GPU, il vaudrait mieux en mettre une encore plus ancienne pour voir?
