kernel power - Matériels & problèmes divers - Hardware
Marsh Posté le 24-05-2020 à 16:05:29
Tu as tenté de baisser la fréquence sur la ram pour voir si ça change quelque chose?
Marsh Posté le 24-05-2020 à 21:49:47
Salut merci pour ta réponse,
oui j'ai déjà essayé rien a changé
si ça peux aider voici des rapports whocrashed :
On Sun 24/05/2020 21:33:36 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: Unknown (0x000000000000000D)
Bugcheck code: 0x116 (0xFFFFDE09AA946050, 0xFFFFF80674D809F0, 0x0, 0xD)
Error: VIDEO_TDR_ERROR
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error.
Google query: VIDEO_TDR_ERROR
On Mon 25/05/2020 14:51:17 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\052520-122375-01.dmp
This was probably caused by the following module: atikmpag.sys (0xFFFFF8063DB30818)
Bugcheck code: 0x116 (0xFFFFB485D5EA6270, 0xFFFFF8063DB30818, 0xFFFFFFFFC0000001, 0x3)
file path: C:\WINDOWS\System32\DriverStore\FileRepository\u0354308.inf_amd64_48534036afa0f0d8\B354265\atikmpag.sys
product: AMD driver
company: Advanced Micro Devices, Inc.
description: AMD multi-vendor Miniport Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.).
Google query: atikmpag.sys Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
Marsh Posté le 31-05-2020 à 01:04:20
Tu as tes driver amd a jour? Tu as flash la cg?
Marsh Posté le 31-05-2020 à 02:17:19
oui j'ai les derniers drivers amd et j'ai flash le bios de ma cg
Marsh Posté le 31-05-2020 à 03:12:18
J'pense que c'est peut etre ça le probleme.
Fait un OCCT memtest et un GPU.
Marsh Posté le 31-05-2020 à 07:45:00
3/4 du temps c'est dû a une alimentation qui n'est juste plus capable de fournir la puissance necessaire (en gros elle est semi-HS)
Et vu que c'est une corsair, comme coolermaster, je ne serait pas étonné malheureusement
Marsh Posté le 31-05-2020 à 15:23:36
j'ai fait fait tourner OCCT pendant une heure pour chaque test aucune erreur
mon alim a seulement trois mois c'est possible qu'elle sois déjà HS ?
Marsh Posté le 31-05-2020 à 15:47:57
C'est peut être le fait que tu ait flashé la CG qui est le problème. Tu as sauvegardé le firmware d'origine ? Si oui, il faut essayer de le réinstaller.
Marsh Posté le 31-05-2020 à 16:21:56
| mauricedupontel a écrit : Salut |
Bien memtest et gpu? Avec la cg poussée dans ses retranchement?
Ok, peut etre faire un ddu puis réinstaller les drivers graphique.
Marsh Posté le 01-06-2020 à 15:57:34
Malheuresement j'ai plus le firmware d'origine.
Oui j'ai bien fait le memetest et le gpu je réinstallerais mes drivers avec ddu plus tard dans las journée.
Marsh Posté le 01-06-2020 à 18:19:18
ouvre gpu-z et prends un screen chot et poste le on va voir si y a des bios de dispo
Marsh Posté le 20-05-2020 à 22:09:41
Salut !
Quand je suis entrain de jouer parfois j'ai un écran noir puis mon pc redémarre et l'erreur dans l'observateur d’événement est kernel power 41
Ma config:
amd ryzen 5 3600
16 go ram corsair 3000mhz cas 16
Msi b450 tomahawk pro max
Rx5600xt
et l'alim corsair tx550m
Merci d'avance pour votre aide
L'erreur :
Le système a redémarré sans s’arrêter correctement au préalable. Cette erreur peut survenir si le système ne répond plus, s’est bloqué ou n’est plus alimenté de façon inattendue.
XML de l’événement :
Nom du journal :System
Source : Microsoft-Windows-Kernel-Power
Date : 20/05/2020 21:31:01
ID de l’événement :41
Catégorie de la tâche : (63)
Niveau : Critique
Mots clés : (70368744177664),(2)
Utilisateur : Système
Ordinateur : DESKTOP-L63QTF3
Description :
BugcheckCode 278
BugcheckParameter1 0xffffb08015456460
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress 0
PowerButtonTimestamp 0
BootAppStatus 0
Checkpoint 0
ConnectedStandbyInProgress false
SystemSleepTransitionsToOn 0
CsEntryScenarioInstanceId 0
BugcheckInfoFromEFI true
CheckpointStatus 0
Message édité par mauricedupontel le 23-05-2020 à 01:26:49
